Old 04-27-2013, 05:11 PM   #1606
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 2,112
Well I joined the Bandit club.....sort of. Found a great deal on an F model, so basically a Bandit with a fairing and different seat.
Loving the 650 engine, so smooth! And I was under the impression that a 600 class 4 cyl would be worthless below 5k RPM but with the efi it seems to pull from 2k without stumbling.
Don't lynch me because it doesn't say Bandit on the side
Jimmy the Heater is offline   Reply With Quote
Old 04-27-2013, 05:55 PM   #1607
Horsehead
Horsehead's Avatar
Oddometer: 84
Good looking bike!
Does it have a smilar ride height as the bandit? It looks lower...
Also, are the footpegs in roughly the same position, or is it a more cramped "sport" posture?
Horsehead is offline   Reply With Quote
Old 04-27-2013, 06:17 PM   #1608
Jimmy the Heater
Tilting the Horizon
Oddometer: 2,112
Originally Posted by Horsehead View Post
Good looking bike!
As I've never sat on a Bandit I can't say with absolute certainty but in doing my research the pegs are in the exact same position. When sitting on it, it is certainly not an extreme peg position at all and with a 32" inseam I tend to notice such things.
The seat is a tad higher than the Bandit with it's dual height seat in the tall position. 31.6 for the F model 31.1 for the Bandit's high position.
However they are directly interchangeable. Bandit 650/1250 seats will fit GSX 650/1250F's and vice versa
Old 04-27-2013, 06:36 PM   #1609
YJake
Roaming
Oddometer: 434
Originally Posted by gpounce View Post
Repeat test with tank filler open- ie maybe your tank vent line is constricted?
Got sidetracked and the carb Assembly is on the work bench now... The inside of the carbs are spotless except for some light rust in the bottom of the bowls and the jets are not clogged. However, in carb #3 when I removed the diaphragm cover and needle I noticed that there was no spring or shim on the needle. The needle was just sliding back and forth inside the valve piston.
Well that's one more issue I can clear up that should improve performance but I'm still on the hunt for the first. I'll just rebuild the carbs/holeshot rejet and take it from there.
-Jake
Touring The Gulf.
YJake is offline   Reply With Quote
Old 04-27-2013, 06:40 PM   #1610
SteelB12
SteelB12's Avatar
Oddometer: 3,151
I had to replace my oil cooler with an aftermarket unit. I also had to make oil lines. I hooked it all back together and now its leaking at the banjos. I used new OEM crush washers, but the oil is leaking very badly from the banjos. Any clue what I may have done wrong??
2003 Suzuki Bandit 1200S
2009 KLR650
SteelB12 is offline   Reply With Quote
Old 04-27-2013, 09:41 PM   #1611
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,910
Are those AN fittings? If so, are they metric or SAE. Measure it..ID(inside diameter) then order the correct crush washer. It's just a guess....hard to diagnose on the Internet n
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 04-28-2013, 12:17 PM   #1612
SteelB12
SteelB12's Avatar
Oddometer: 3,151
After much discourse with many other riders, it may be that because I didn't use a torque wrench, I tightened the washers too much and therefore crushed the crush washers too much and apparently that makes it so they don't seal well.
Never mind. I actually hadn't tightened them enough. DOH!
2009 KLR650
SteelB12 screwed with this post 04-30-2013 at 07:41 AM
Old 04-29-2013, 05:51 AM   #1613
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 3,646
Jimmy, I've got the liquid cooled 650 Bandit from '07. I think they added the fairing and the "F" the following year. Sat on an "F". I couldn't see a difference.
Lyle
skysailor is offline   Reply With Quote
Old 04-29-2013, 11:53 AM   #1614
MerlotMax
MerlotMax's Avatar
Oddometer: 61
Nice bike - congrats!!
MerlotMax is offline   Reply With Quote
Old 04-29-2013, 12:02 PM   #1615
Jimmy the Heater
Tilting the Horizon
Oddometer: 2,112
Lyle
Yup mine is an 08, first year for the F model. When you get to decimal points in seat heights, not surprising you couldn't tell a difference. Certainly not a make it or break it difference.
One more question for the 650 owners. I gave my Dad a ride on it yesterday and it felt very very light in the front end. I'm 170 and he's 185lbs. Plenty of power just not very confidence inspiring handling wise.
Any others experience this giving a comparatively heavier passenger a ride?
No problems giving rides on my Ninja 500 so I thought this was a bit odd.
Old 04-29-2013, 12:02 PM   #1616
Jimmy the Heater
Tilting the Horizon
Oddometer: 2,112
Old 04-29-2013, 12:26 PM   #1617
Crocodile Tears
Anti-Semantic
Crocodile Tears's Avatar
Oddometer: 3,512
anybody with a black bandit painted their wheels that bronze/gold color similar to a World Rally Blue Subaru WRX? I'm debating trying it out but wanted to see if anyone had pics before I made the jump.
I'm not going to censor myself to comfort your ignorance."
2014 CB500X
2009 KLX250S
2005 Bandit 1200S
Crocodile Tears is offline   Reply With Quote
Old 04-30-2013, 10:52 AM   #1618
Jimmy the Heater
Tilting the Horizon
Oddometer: 2,112
The R6's came in that scheme and I think it would look great on a Bandit.
Old 05-06-2013, 08:39 AM   #1619
jub jub
frumiousbandersnatch
jub jub's Avatar
Oddometer: 15,997
Corbin Seat
Just got my Corbin seat in for my GSX, unfortunately, it looks like I will have to remove, or at least loosen the frame mounted luggage rack in order to put the seat on. The seat is just slightly longer than stock and with it having a thick, fiberglass pan, there is no give.
Has anyone else a similar problem and if so, were you able to correct it?
jub jub is offline   Reply With Quote
Old 05-06-2013, 12:50 PM   #1620
TexanInSeattle
TexanInSeattle's Avatar
Location: Somewhere around Barstow on the edge of the desert
Oddometer: 326
Took mine out for some mountain fun yesterday
"Fucking computers! See all the trouble they cause!"
TexanInSeattle is offline   Reply With Quote
Times are GMT -7.   It's 11:57 AM.
