Old 05-06-2013, 01:20 PM   #1621
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Originally Posted by jub jub View Post
Just got my Corbin seat in for my GSX, unfortunately, it looks like I will have to remove, or at least loosen the frame mounted luggage rack in order to put the seat on. The seat is just slightly longer than stock and with it having a thick, fiberglass pan, there is no give.
Has anyone else a similar problem and if so, were you able to correct it?
Bummer. Not sure what you could do other than try to build an adapter that moves the rack back a 1/2 inch or whatever is necessary. Or get a different rack.
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 05-06-2013, 01:42 PM   #1622
TexanInSeattle
TexanInSeattle's Avatar
Location: Somewhere around Barstow on the edge of the desert
Oddometer: 324
Hey jub-jub, check with the guys over at maximum-suzuki.com
They may have a solution for you.
"Fucking computers! See all the trouble they cause!"
TexanInSeattle is offline   Reply With Quote
Old 05-06-2013, 01:47 PM   #1623
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Finally got the PLX V35 bags i've been lusting after. Complete setup with factory racks, sidecases, and top case was $625 shipped. Couldn't pass up that deal!
Old 05-06-2013, 05:11 PM   #1624
jub jub
frumiousbandersnatch
jub jub's Avatar
Oddometer: 15,553
Good idea! Thanks.
jub jub is offline   Reply With Quote
Old 05-06-2013, 06:20 PM   #1625
beeper
Badger tickler
beeper's Avatar
Oddometer: 782
Best year and color!!
'12 F800GS
'00 Bandit 1200
'74 Honda CL360
beeper is offline   Reply With Quote
Old 05-07-2013, 08:48 AM   #1626
jub jub
jub jub's Avatar
Oddometer: 15,553
TexasinSeattle gave me some good advice about going over to Maximum Suzuki. There were several threads talking about the same problem. The easiest thing would be to shorten the seat slightly. I think that's what I'll do.
Old 05-07-2013, 07:22 PM   #1627
Horsehead
Horsehead's Avatar
Oddometer: 84
Lookin' good. Why'd you decide to go with those over the pelicans you used on your trip?
Horsehead is offline   Reply With Quote
Old 05-07-2013, 08:39 PM   #1628
jub jub
jub jub's Avatar
Oddometer: 15,553
What seat do you have and does it use the stock seat pan?
Old 05-07-2013, 09:27 PM   #1629
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Looks and passenger room. No way I could take a passenger with the Pelicans unless they were VERY narrow.
Sargent seat, comes complete.
Old 05-08-2013, 04:34 AM   #1630
scoon66
Who is the Coon?
scoon66's Avatar
Oddometer: 2,744
There is a Bandit in there. :)
scoon66 is offline   Reply With Quote
Old 05-08-2013, 04:41 AM   #1631
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,107
..I only see a nutcase.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 05-08-2013, 10:46 AM   #1632
Draechon
Draechon's Avatar
Oddometer: 1,307
Swapped the body pieces on my Bandits last weekend and did a naked conversion this weekend. Also added a Corbin seat!
Before:
After:
I wish my motorcycles had real model names for when I get asked what I ride.
Draechon is online now   Reply With Quote
Old 05-08-2013, 06:42 PM   #1633
gpounce
Oddometer: 113
I think you need a different color tank to complete the look...
'02 Bandit 1200S
gpounce is offline   Reply With Quote
Old 05-09-2013, 12:08 PM   #1634
YJake
Roaming
Oddometer: 407
Pulled the carbs, rebuilt all of them, and added a Holeshot stage 1 jet kit.
Holy Smokes Batman!
This is what the thing should have been like from the factory!
Starts easier, idles smoother, accelerates smoother, deceleration pop is gone(Just a light rumble now), and I can feel a good difference in HP/Torque through my Butt Dyno.
I haven't put the timing advancer in yet but Dave's instructions make it sound like it makes things even better so I'll probably do that today.
-Jake
Touring The Gulf.
YJake is offline   Reply With Quote
Old 05-09-2013, 02:18 PM   #1635
Horsehead
Horsehead's Avatar
Oddometer: 84
-Jake
Very nice! I was just looking at those the other day. Are you running stock exhaust or something aftermarket?
Times are GMT -7.   It's 05:32 PM.
