Old 04-30-2009, 09:47 PM   #166
RC Pilot
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,687
Originally Posted by Draechon
There's already a Bandit thread going at
http://www.advrider.com/forums/showthread.php?t=412653
but since I'm already here:
I searched for bandit, but I guess I did not look far enough.
RC Pilot is offline   Reply With Quote
Old 05-07-2009, 07:27 AM   #167
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,606
Cool2
My Bandit just passed State Inspection, now it's 100% legal.
Feels like my old BMW K1200RS with less weight.
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 05-07-2009, 08:09 AM   #168
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,125
Not that often that you hear someone call the Bandit a lighter something..
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 05-07-2009, 09:44 AM   #169
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,606
My 98 BMW K1200RS was about 650 lb..
03 Bandit 1200, perhalps under 500 lb.?
Old 05-07-2009, 09:48 AM   #170
RC Pilot
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,687
Around 485 dry so in the low 500s wet.
Old 05-07-2009, 09:59 AM   #171
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,606
Even tough I put on LED flush turn signals, removed barend weights and the tail end dead weight? Those barend weights are about 3/4 lb. each.
Old 05-07-2009, 10:37 AM   #172
RC Pilot
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,687
Depending on what all that weighs you may around 510 wet. I am going off of a 485 dry weight and then adding the weigh of 5.3 gallons of gas and the oil; a total just shy of 40lbs.
Old 05-15-2009, 10:10 AM   #173
lagcam
lagcam's Avatar
Oddometer: 731
Am I the only one that has problems with the little tie-down spools on my '02 Bandit? The straps on my tail bag are about 1/4" wider than the spools. I spent hours searching the internet and even the local hardware stores for an alternative, but ended up making my own at work. Problem solved, but I can't believe there isn't something out there that would work?
BTW, the threads are 8mm x 1.25.
The long threads go in the back. The stockers are plated steel, I think. I made the new longer ones out of stainless.
lagcam is offline   Reply With Quote
Old 05-15-2009, 10:59 AM   #174
RC Pilot
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,687
I use a Fieldsheer Expander tail bag which has hooks that fit the stock pegs just fine.
Old 05-28-2009, 09:19 PM   #175
lagcam
lagcam's Avatar
Oddometer: 731
Ok, so I finally sprung for some Nelson-Rigg saddlebags and I like them a lot. And only 81 bucks at Dennis Kirk for the standards. Took a pic today of the thing loaded up. Believe it or not I have a tent, air mattress, sleeping bag, feather pillow ( ) and a small air pump for the mattress in the tail pack. If I have to camp, I'm going to be comfy.
Only problem is the bike handles a little wonky now with all that weight back there. Feels a little like a weeble at slow speeds. Once I get up to 30-40mph it just feels a little top heavy.
Old 05-29-2009, 05:28 AM   #176
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,606
Cool2
I've traded my Bandit 1200 to a 09 SFV650.
I have a few Bandit items for sale: HERE
Old 05-29-2009, 07:31 AM   #177
ACDNate
ACDNate's Avatar
Oddometer: 689
I would feel the same kind of off the wall handling on my 01 when loaded, even wih the pre-load ramped all the way up. Swapping the rear shock out to a Busa unit made a world of difference in handling, particularly when loaded down.
Nate
Ocean Spring, MS
2008 Honda GL1800
2007 Honda CRF150R
2005 Honda CRF100F
ACDNate is offline   Reply With Quote
Old 05-29-2009, 09:06 AM   #178
lagcam
lagcam's Avatar
Oddometer: 731
I've seen something about the Busa shock swap somewhere else. Is it a straightforward fit or is there some fiddling?
Old 05-29-2009, 09:18 AM   #179
ACDNate
ACDNate's Avatar
Oddometer: 689
The 2007 and back shocks (or is that 2008???) have identical mounting points. The Busa shock raises the rear of the bike about 1.25" so a lowering link is reccomended to get back to the stock steering geometry. Additionally, the lower left (as sitting on the bike) air box cover mount tab and the slot it sits in needs to be cut off to accomodate the shock resevoir. No worries thought the airbox cover still holds on just fine. Otherwise a pretty direct fit
Quick easy job though. I went a little bonkers with the suspsension when I decided to do the Busa shock. Added racetech springs and a Holeshot steering stabilizer. All total ran about $450-$500 but was money well spent. It really changed the bike a lot. Handling got insanely better.
Nate
Ocean Spring, MS
2008 Honda GL1800
2007 Honda CRF150R
2005 Honda CRF100F
Old 05-29-2009, 09:30 AM   #180
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,471
Nate,
Did U do anything to the front end of the Bandit?
A '00 KLR 650 40,000 miles, A '07 1250S 74,000 , A '03 5.3L Chevy Truck 78,000 + '43 style dude , Simper Fi ;-)
achesley is offline   Reply With Quote
Times are GMT -7.   It's 07:56 PM.
