Old 07-09-2011, 01:49 PM   #781
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
Originally Posted by yeti1 View Post
Okay dont rip me apart on this!......What wieght oil do most of you use for summer traveling?
Come on guy's hurry I've been standing in Walmart for 3 hours.....tap! tap!
Tito's vodka a weber grill and the rocky mountains,...it all goes away!
Utah Bones is offline   Reply With Quote
Old 07-09-2011, 01:55 PM   #782
KEN PHENIX
. . . thinks he likes it
KEN PHENIX's Avatar
Oddometer: 514
Buy the wet oil - the one in the plastic bottle. It'll be fine.
Ken Phenix
IBA #47092
The 919 Transalp Project
KatanaBandit (sold)
smugmug pics
KEN PHENIX is offline   Reply With Quote
Old 07-09-2011, 02:03 PM   #783
Jeff Watts
Oddometer: 52
I'd suggest 5w-20
Due to a change in employment, and loss of a company truck, I'm in serious need of a cheap street legal bike. Like one or two paycheck cheap!
Jeff Watts is offline   Reply With Quote
Old 07-09-2011, 02:21 PM   #784
KEN PHENIX
KEN PHENIX's Avatar
Oddometer: 514
I use 5w 40 Mobil1 for diesel. It's the only 5/40 synthetic readily available in my climate. I don't think you can make a bad choice of the premium brand oils these days. Now FILTERS! There's a subject. Lots of guys with nothing better to do make youtube clips of themselves cutting into various brands. Invariably, WIX seems to have the best quality construction.
Ken Phenix
IBA #47092
KatanaBandit (sold)
smugmug pics
Old 07-09-2011, 02:45 PM   #785
Draechon
Draechon's Avatar
Oddometer: 952
I use Rotella T 5W40 full synthetic year-round.
On a related note: after 3 years of weak after-market headlight set-ups (cool looking one, Acerbis Cyclops, and then generic naked 7"), I've finally relented and gone back to the original fairing and headlight. It looks weird/cool though, since I had painted the rest of the bike after pulling the fairing off when I had just gotten the bike. What do you guys think, should I paint it?
Draechon is offline   Reply With Quote
Old 07-09-2011, 03:52 PM   #786
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
I agree with the WIX filters, used them on all my cars.
Old 07-09-2011, 10:28 PM   #787
lookatdirt
lookatdirt's Avatar
Oddometer: 88
I just ran my Bandit from Zion NP, UT, through Mesquite, NV, down along Lake Mead (to bypass Vegas,) and hit the 95 to Needles. At a spirited (!) pace and it was freakin' hot. 112 in Needles. Spectro 10-40 and no signs of heat related engine stress. As a matter of fact, on the trip, I hit passes as high as 11,000+ and hit near sea level and never noticed any differences in performance in my naturally aspirated Zook. Stock Suzuki filters exclusively. The engine is as reliable as a claw hammer. Don't over-think it.
lookatdirt screwed with this post 07-09-2011 at 10:35 PM
lookatdirt is offline   Reply With Quote
Old 07-10-2011, 07:19 AM   #788
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,889
Naah!
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125
My Flickr gallery
Cortez is offline   Reply With Quote
Old 07-10-2011, 09:42 AM   #789
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
I agree....
Old 07-10-2011, 12:23 PM   #790
lookatdirt
lookatdirt's Avatar
Oddometer: 88
Last year in Borrego Springs. Day 1 of 18.
Old 07-13-2011, 08:27 AM   #791
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
I parked my Bandit for the winter at my place in Wisconsin and headed out to Utah with intentions of comming back and winterizing it.....wellthat didn't work out. It sat in the garage all winter ,had to get a battery,new gas,oil change and started it up....I thought for sure the carbs would of been gummed up. Ran great! The clutch on the other hand would engage as soon as you released then flop open.....I hit the road for an hour and it came back to where it should be, Wierd? What would of made it do that?
Old 07-13-2011, 05:57 PM   #792
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
The petcock on my Bandit say's res,pri,and on......is there no off? I think one of the carbs is not seating and leaking gas in cylinder?
Old 07-13-2011, 06:23 PM   #793
R-A-M-O-N
Oddometer: 297
No theres no off, at the on and res position it should not deliver any fuel, if your carbs are empty then there is the prime position to let fuel flow. If it lets fuel through at "on" then its leaking and its not working as it should like mine I hope i can fix it
If fuel is passing through the carbs solve it as soon as posible. Temporarly i put an in line fuel filter and maybe ill try to fit a shutoff valve in the hose if my petcock cannot be fixed.
R-A-M-O-N is offline   Reply With Quote
Old 07-14-2011, 10:44 AM   #794
jiggliemon
Nobody
jiggliemon's Avatar
Oddometer: 91
if your petcock is leaking then i bet you just need to take it apart and stretch the spring that is inside of it then put it all back together... takes like 20 min. this spring compresses when a vacuum is applied to it but after a while it will remain compressed slightly and let fuel leak out when no vacuum is applied. inspect the gaskets while you're in there to see if you need a rebuild kit but i bet they will be fine. it is seriously such an easy job and it only needs to be done every few years max... not too often
jiggliemon is offline   Reply With Quote
Old 07-14-2011, 09:29 PM   #795
lagcam
lagcam's Avatar
Oddometer: 681
Send a message via Yahoo to lagcam
Most likely the slave cylinder for the hydraulic clutch leaked down as it sat. Mine does it sometimes too. If the lever travel changes at random times, usually a quick bleed will make it behave.
During times of universal deceit, telling the truth becomes a revolutionary act. ~ George Orwell
lagcam is offline   Reply With Quote
Times are GMT -7.   It's 03:39 AM.
