Old 12-14-2008, 06:46 PM   #16
BAGSTR
BAGSTR
BAGSTR's Avatar
Oddometer: 571
Battery Life??
The unit in my 2007 US 990A failed to start today. The accessory socket reads 12.56 volts with the key off and 11.95 with the key on and the headlight off. (Euro headlight & Switch) 21 months seems short lived to me... What life are your Orange Monster batteries getting?
I will check the battery drain test tommorow. i.e. disconnect battery neg and measure current to ground. Manual standard is 2mA or less. Otherwise I have current drain somewhere.
BAGSTR is offline   Reply With Quote
Old 12-15-2008, 07:06 AM   #17
Chipper
Oddometer: 711
Battery?
Originally Posted by PowerCell
Powercell, Have you used this battery? Compatable with 9?0's?
Chipper is offline   Reply With Quote
Old 12-15-2008, 02:45 PM   #18
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,317
I've had one in my SE for about a year. I worry a bit about batteries as I run an auto clutch and ride in Mexico a lot. This batt is amazing! Because my FCR's don't have a choke circuit, some mornings I need to abuse the starter a bit. The Braille can really crank!
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 12-16-2008, 11:30 PM   #19
ErrinV
D Boon!
ErrinV's Avatar
Oddometer: 2,292
I'm in need of a new battery, and the OP lists the 14-BS from Sears. However, my battery is a 14-S. What is the difference, and will the 14-BS fit? The 14-S is listed as being available at my local Sears, but the 14-S is a special order.
Thanks.
Thunderbird 1 - '14 BMW F800GS ADV
"Love comes in spurts!"--Richard Hell
ErrinV is offline   Reply With Quote
Old 12-17-2008, 06:19 AM   #20
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 6,144
You do have a load on the battery-- it's the clock, and it's a good reason to buy a Battery Tender if you don't ride very frequently.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 12-17-2008, 06:21 AM   #21
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 6,144
And that reminds me: if you go to a gel battery and you own a battery charger/ maintainer, you may have to replace it with one compatible with a gel battery.
-Chris
Old 12-17-2008, 03:21 PM   #22
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Thanks.
The BS model is about 1.5" taller than the S model. It won't fit in the ADV battery box.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 12-17-2008, 08:10 PM   #23
silverdog
silverdog's Avatar
Oddometer: 553
does this fit correctly in the stock box ?
how about the leads ?
as much power as stock yuasa ?
thanks for the info........
silverdog is offline   Reply With Quote
Old 12-17-2008, 08:13 PM   #24
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,317
It's the same dimensions as the stocker. The posts just bolt on, so you leave 'em off. It kicks the stock Yuasa's butt...
~ Ken
Old 12-18-2008, 07:12 AM   #25
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,885
I am for Yuasa 14S.
Well..not quite, CCA of the Yuasa 14S is 230, while Braille is 210.
I did the following test:
Connected a capacitor 1000 microF to the two bare cables, connected to the battery poles. Then disconnected the battery, while keeping the revs around 2,5ks. The motor continued to run. When the revs droped lower than 2ks, the motor died. Seems the alternator can produce sufficient power only when running over 2-2,5 ks, which stabilized from the capacitor can operate all 950Adv electric comsumption. Anybody else nows the revs' threshold when the battery is charging or discharging?
Cheers.
gefr screwed with this post 12-18-2008 at 07:47 AM
Old 12-18-2008, 09:37 AM   #26
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,317
Originally Posted by gefr
Well..not quite, CCA of the Yuasa 14S is 230, while Braille is 210...
Maybe if you crank it for 30 seconds (I don't recommend it...). Otherwise, the battery is designed to start 4 cylinder race cars. I've had both, and there's no comparison, the Braille rocks.
Performance
Voltage: 12 Volts
Full Charge Voltage: 13.8 Volts
Short Circuit Current (Max Cranking Amps): 760
Pulse Cranking Amps (PCA) 5 sec @ 80F: 527
Pulse Cranking Amps (PCA) 10 sec @ 80F: 461
Pulse Cranking Amps 20 sec @ 80F: 407
Cranking Amps 30 sec @ 80F: 314
Cranking Amps 30 sec @ 32F: 283
Cold Cranking Amps 30 sec @ 0F: 210
Reserve Capacity: Less than 20 minutes
Capacity (C/20 rate): 10
Internal Resistance: 15.8 milliohms (.0158 ohms)
Life Cycle @ 10% DOD: 2000
~ Ken
Old 12-18-2008, 06:55 PM   #27
silverdog
silverdog's Avatar
Oddometer: 553
Thumb
Performance
Voltage: 12 Volts
thanks for the info Powercell, I m gonna get one.
do you use the standard case or the carbon fibre one ??
regular battery tender work ok?
where do you get yours ?
Old 12-18-2008, 07:05 PM   #28
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,317
Regular tender works fine. The Carbon fiber is just a gimmic.
~ Ken
Old 12-20-2008, 11:20 AM   #29
viatormundi
Citizen of the world
viatormundi's Avatar
Oddometer: 644
This Braille looks good but very expensive to ship to Europe, Spain (about 100 USD).
Can anybody recommend a battery than Yuasa which I can buy in Europe?
viatormundi is offline   Reply With Quote
Old 12-20-2008, 04:18 PM   #30
zmotomann
No Quarter
zmotomann's Avatar
Oddometer: 411
No No No
Originally Posted by Super Enduro R
is that before or after you fitted the odessey ?
I put the battery in after i did the pushing. The oddeesy is doing fine I left the light on for 15minutes the other day at home as a test and it still fired right up.
" Don't stop riding or you will stop "
zmotomann:
www.zmwadventures.com
zmotomann is offline   Reply With Quote
Times are GMT -7.   It's 08:46 AM.
