Old 11-10-2010, 07:20 AM   #1546
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,560
hot
Originally Posted by mcma111
Perhaps you have seen Prince Rubens 700 mile Hot Cam from his XR650l?
http://i122.photobucket.com/albums/o...-04-47_894.jpg
And No, I am not a fan of the Hot Cam
You mean overheated cam?
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 11-10-2010, 07:53 AM   #1547
mcma111
mcma111's Avatar
Oddometer: 7,984
Ruben had confirmed oil flow to the top end, set the valve lash to supplied specifications.
It's my opinion that the Hot Cam is not the way to go. I would rather run an OE cam than chance one of theirs.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-10-2010, 09:39 AM   #1548
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,100
Bar risers and taller bars
Can I have your opinions on bar risers and taller bars? I am running the bars that came with the bike, and it seems that I would be more comfy with the bars higher up. I have read the "cockpit" on the XR is tight, but I do not have any experience with this kind of "tuning". Seems the Rox riser is popular, has anybody had them slip? Thanks!
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
JAB is offline   Reply With Quote
Old 11-10-2010, 10:05 AM   #1549
mcma111
mcma111's Avatar
Oddometer: 7,984
Take a look at this triple clamp and riser set. I have his triples on my XR650l with the 3" risers. I'm 6'2
http://www.rswracing.com/xr600r.htm
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-10-2010, 10:38 AM   #1550
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,100
Thank you, Steve. How does a tall bar position help you?
Where my bars are now, it feels like in some cases that I am too far forward and my arms are bent too much for good control. Seems a taller bar position would push me back some, right?
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
Old 11-10-2010, 12:37 PM   #1551
boingk
boingk's Avatar
Oddometer: 262
Originally Posted by Blakebird
I put a Hotcam in my XR600 during the last rebuild. You'll lose the decompress apparatus...
Righteo. To be honest the decompressor is pissing me off a bit at the moment, I'd rather be able to find TDC without having to baby it. Is that both auto and manual decompressors? Also, hows your bike going with the new cam... did you happen to dyno the bike before and after?
Cheers - boingk
'97 XR600, '84 GSX-1100EF
boingk is offline   Reply With Quote
Old 11-10-2010, 01:53 PM   #1552
zipper2680
couch traveller
zipper2680's Avatar
Oddometer: 67
Im running a Hotcam on my 600R..high comp JE piston, HRC Cylinder lowered to increase comp (11:1) 640cc,Mikuni TM40 ,full exhaust line, lightened flywheel, Prox rod, intake and exhaust port and polish, Iridium plug, Twinair air filter, KTM oil cooler, Kibblewhite valves...
Running on a SM setup...no savings...revs like a maniac...so far, so good..3500kms plus on it and the Hotcam runs like new...
http://s282.photobucket.com/albums/k...afilter=videos
94 XR600R
2000 Transalp 650
zipper2680 is offline   Reply With Quote
Old 11-10-2010, 01:56 PM   #1553
Michelangelo
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,527
So I've got this like new Scotts/BRP forward mount stabilizer post setup that I took off my XR650R. Supposed to fit the XR250/400 bikes. Though one of you may be interested.
This is a stock photo. It doesn't include the stabilizer arm. Like new: $100
PM if you want.
Im also selling my deliciously tricked out and delicately cared-for XR650R. Here's a sneak. More trick bits than I can throw a stick at: Trail Tech Vapor, BRP submount triple clamp, Clarke 4.3 gal tank...etc...etc. The list goes on and on.
6th Gen VFR800, '08 KTM 690E, '05 CRF450X
'96 XR600TT, '00 Bandit 1200, '01 TTR-150L
Michelangelo screwed with this post 11-10-2010 at 02:05 PM
Michelangelo is offline   Reply With Quote
Old 11-10-2010, 04:51 PM   #1554
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 12,189
I had CR Hi bend on my XR600, but for stand-up riding they were too low.
With the Rox Risers it was much better, and no I never had them slip at all.
'12 VFR 1200 . '13 TR650 Terra . IBA #11735 . 1968-present
Blakebird is online now   Reply With Quote
Old 11-10-2010, 05:37 PM   #1555
boingk
boingk's Avatar
Oddometer: 262
Originally Posted by zipper2680
I'm running a Hotcam on my 600R...[lots of other engine mods]...3500km plus on it and the Hotcam runs like new.
Sounds good to me. And no offence to Prince Ruben, but if he didn't have serious engine problems before installation of the cam, he sure did after. Camshafts don't disintegrate like that for no reason. I'm thinking sustained oil starvation from a blocked passage or extended running on low oil level. Hell, throw in some overheating and you'd just about be there... but geez thats not a pretty picture.
Might get my oil cooler together before I throw a cam in there.
Cheers guys, much appreciated - boingk
Old 11-13-2010, 01:39 PM   #1556
HRC37
Week-End Warrior
HRC37's Avatar
Oddometer: 3
Hey boingk,
I am using a oil cooler off an XR400, seems to work well...
http://s852.photobucket.com/albums/a...5.jpg&newest=1
1998 XR 630
HRC37 is offline   Reply With Quote
Old 11-14-2010, 11:04 PM   #1557
boingk
boingk's Avatar
Oddometer: 262
Cheers HRC37, but for now I'm rigging my own oil cooler up out of copper pipe, t-pieces & 90' elbows. Bit controversial but I'll see how it goes.
It gets plumbed into the frame reserviour return line, right?
- boingk
Old 11-15-2010, 02:52 AM   #1558
Emile
Emile's Avatar
Oddometer: 104
right ;)
here is my setup, a Yamaha XJ 650 oilcooler and a pair of hydrolic hoses 60 € all together.
http://www.honda-xl.nl/forum/viewtop...&sd=a&start=60
Emile
Emile is offline   Reply With Quote
Old 11-15-2010, 04:17 AM   #1559
boingk
boingk's Avatar
Oddometer: 262
Looks alright, although I'll be looking at about 15 Euro (AU$30) all up including fittings. Just have to make the thing now...
Also, whats the consensus on aftermarket ignition units for the XR600R? Something like this is what I'm thinking of getting:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
What do you reckon?
- boingk
Old 11-15-2010, 06:54 AM   #1560
Emile
Emile's Avatar
Oddometer: 104
I don't know :) but sounds nice :)
thats a good price indeed 15 eu
Emile
Times are GMT -7.   It's 07:54 PM.
