Old 04-25-2011, 02:14 PM   #1981
Brauhausbier
Focused
Brauhausbier's Avatar
Oddometer: 1,367
Originally Posted by bigtrailie View Post
Can someone out there post a nice clear photo of what the choke linkage stamping(?) should look like? I'm referring to the bit of steel (tin?) that is mounted on the end of the butterfly shaft. This thing is pushed by the choke lever and provides resistance to the lever via the spring around the shaft. My choke lever / linkage thingy interface is FUBAR'd. The choke lever gets past the thingy and the choke slaps open. A photo of a nice, unmolested item will help me twist and bend mine back into shape.
Had the same problem with my OE choke when I was putting on an XR's choke plate. My rod got loose and the spring unwound. There is a spring under the stamped steel end of the choke rod. Just hit the choke rod with a light hammer from the opposite end of the stamped metal and the stamped metal will pop out and see if you can fix the spring (careful that spring doesn't get lost). Unfortunately no new parts are available for the spring or spring plate. I tried to fix my spring, but it was just beyond help. You might be able to clip off a bit of the spring and reconfigure the metal bend that holds the end of the choke rod. Good luck!
I went ahead and got a nice new FCR41 Sudco kit. It is 1000 times better construction and quality than the OE Keihin and no choke. Pumper power!
A used OE Kehin will run around @ $120 off Ebay.
Brauhausbier is offline   Reply With Quote
Old 04-25-2011, 04:04 PM   #1982
elsalvadorklr
southern xr rider
Oddometer: 4,154
shock shipping?
stupid question:
how do you ship a shock overseas?
My idea is to get a used shock on ebay, send it to esp or somesuch place that revalves and resprings these puppies BUT they have about 285 psi of nitrogen in them and I do not know if I can find a place to do that down here, sooo...
by ship? by air?
whats the process for people that dont live in the us, or europe where this stauff gets done?
cheers and thanks!
christian
elsalvadorklr is offline   Reply With Quote
Old 04-25-2011, 08:19 PM   #1983
elsalvadorklr
southern xr rider
Oddometer: 4,154
ims tank includes mounts?
hey, can anybody confirm whether the ims tanks 4gal comes with the two triangular mounts and screws to fit or no?
I know I have to use the stock petcock...
thanks
Old 04-25-2011, 08:27 PM   #1984
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,488
thanks
Mine was used, and had no mounts, but the stock ones fit it.
Watch out for clearance for your compression release. I had to heat a spot, and enlarge the relief dent to make room to keep it from rubbing. My main concern was that it might keep the exhaust valve from closing completely.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 04-25-2011, 08:55 PM   #1985
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,519
this?
My spring came off the end of the shaft, the only way to get it back on was to tap out the tin cap holding the spring, reconnecting the spring and tapping the tin cap back into place.
I took the choke shaft out (before I put on the XR's Only choke plate) and used a skinny philips screwdriver in it's place to tap out the tin cap. It pops right out and fits snugly when you put it back - never gave me a lick of trouble afterward.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 04-25-2011, 09:15 PM   #1986
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,989
Don't go the way of Shinkos.....Next thing you know, you will be buying $18 footpegs off ebay.
Geez....sometimes I wonder about you girls. Keep bitching about a good deal and keep paying $150 for footpegs...and the Man will be happy.
Like I said before....those pegs stood up to shit I threw at them with my 290 lb body/gear...and more. They are just fine.
By the way.....the 244 was an awesome tire on our 600L's and my NX650. That tire was awesome on the Big Dig Ride I did.....
And those cheap ass, cast China footpegs will stand up to more than most of you can dish out.
Now granted....if I had a couple of sponsors and was running the Baja 500....I would have them buy the $150 pegs and the $200 tires. But for the rest of us....living on a "reality budget"....just chill.
Sorry for venting....but tired of hearing the girly complaining.....
Originally Posted by Alaskajeff View Post
Tell me about it, I've got NON DOT tires on my 88 and they do get squirrely..... WOW thats a gret looking Kendra tire! What size are you going to run?
Have you ever heard of these tires before?
http://www.amazon.com/Shinko-244-Dua.../dp/B001CD8POC
They are 4 ply DOT legal...
John
2004 KTM 950 Adventure S
2004 BMW R1150RT
2003 KTM 450 EXC
Pointing the Way http://www.gracemotoadv.com
Big_John is offline   Reply With Quote
Old 04-25-2011, 09:28 PM   #1987
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,989
By the way....isn't this the one you want.....a 5.10-18?
http://www.amazon.com/Shinko-244-Dua...3792005&sr=1-4
John
2004 BMW R1150RT
2003 KTM 450 EXC
Old 04-25-2011, 10:08 PM   #1988
elsalvadorklr
southern xr rider
Oddometer: 4,154
well darn I just bought all the mounting bits and pieces off cheapcycle, plus a new petcock as I dont have an original tank! yikes!!!!!!!!!!!!!!!! $$$$$$$$
Ill deal with the relief on the compression when I get it in...Im going with the 4gal natural? any pics of yours?
thanks
Old 04-26-2011, 08:22 AM   #1989
elsalvadorklr
southern xr rider
Oddometer: 4,154
can anybody confirm whether this sprocket will work on my bike?
http://cgi.ebay.com/ebaymotors/NOS-H...cessories#shId
88/600?
same part numbers except mine has an mk2 in the parts fiche...
thanks!
Old 04-26-2011, 08:32 AM   #1990
MortimerSickle
Semi-Adventurer
Oddometer: 12,488
thanks
Mine is white (pardon the mud spatters.)
I have no idea how old it is, but it does have some staining from fuel bleedthough. I don't know whether the compression release interference is from ill-design, from swelling, or just a peculiarity of the fit to my bike, but it is something to keep in mind.
G.H.W.S. 1878-1962
Old 04-26-2011, 09:13 AM   #1991
mcma111
mcma111's Avatar
Oddometer: 12,617
88/600?
thanks!
Thats the early, 6 spline sprocket. Just what you need.
But why would you spend $40.00 for that one when a new one from CCP is only $29.51???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 04-26-2011 at 09:31 AM
Old 04-26-2011, 09:56 AM   #1992
MortimerSickle
Semi-Adventurer
Oddometer: 12,488
I don't know what CCP is, maybe they sell good stuff, but I would recommend making sure the quality of a primary sprocket is the best available.
DAMHIK.
G.H.W.S. 1878-1962
Old 04-26-2011, 10:47 AM   #1993
mcma111
mcma111's Avatar
Oddometer: 12,617
CCP short for CheapCycleParts for those of us that have bought from them before.
Code don't you know.
Secret hand shakes.
Nod and a wink.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-26-2011, 01:20 PM   #1994
elsalvadorklr
southern xr rider
Oddometer: 4,154
good question steve!
the problem is I put the order in yesterday and forgot to add the sprocket and I already ordered it once from cheapcycle and they had it backordered for about 3 weeks holding off my other parts thinking it would arrive...
so thats the only one I could find on ebay! its the same number except it does not have the mk2 designation...
i also tried expedited shipping this time see how long it takes this time...
jejeje
thanks bud!
ooooh I need to paypal you btw...............................................
cheers
Old 04-26-2011, 01:22 PM   #1995
elsalvadorklr
southern xr rider
Oddometer: 4,154
DAMHIK.
steve hooked me up with a good looking old style shaft like mine, the one on my bike had about half your wear, and hence the OEM only sprocket...Ill guess Ill use the one have only 500 miles on it for a month or so untill I get the oem one...
thanks and good luck with that
Times are GMT -7.   It's 02:51 AM.
