Old 11-13-2011, 01:56 PM   #2776
Callahan
Callahan's Avatar
Oddometer: 1,124
Originally Posted by elsalvadorklr View Post
Cafe Carburo in Ataco, Ahuachapan, El Salvador awaits you....
Free first beer for all adv members! jejje
Cheers
Christian
Coordinates ?
Callahan is offline   Reply With Quote
Old 11-13-2011, 02:18 PM   #2777
Owyhee
Ran when parked
Owyhee's Avatar
Oddometer: 505
Originally Posted by Callahan View Post
I have seen this or a very similar questions raised at differnrt times amongst posts in this thread and often the answer, when asked if someone should or should not go with hot cams is, go stock as you can.
Steve will hopefully drop a note in here soon.
That's pretty much what I've gathered too, stock is best, but I've painted myself in a corner with the rest of the aftermarket parts. The stock cam with a high compression piston is supposed to build up some dangerous dynamic compression.
Time to unload some stuff laying around on eBay to raise the $400 to buy the hard weld top end.
Port job and fin comparison 1988 head vs. stock 1991 head.
-Owyhee
Owyhee is offline   Reply With Quote
Old 11-13-2011, 02:40 PM   #2778
elsalvadorklr
Oddometer: 3,964
Coordinates ?
Keep forgetting...I do have them though for when I have to come back home from a long ride and get lost sometimes...
Give me a sec...
P.S. If you want to use google maps, look up Ataco, Ahuachapan, El Salvador and it will show up...Its a small town, cant miss it.
30 Minutes from the Guatemalan border!
Cheers
elsalvadorklr is offline   Reply With Quote
Old 11-13-2011, 03:36 PM   #2779
olyflyer
olyflyer's Avatar
Oddometer: 1,195
Give me a sec...
Cheers
Damn I'm back in Australia was over that way not long ago on an old XL350
Oly
'Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living.' Miriam Beard
olyflyer is offline   Reply With Quote
Old 11-13-2011, 04:02 PM   #2780
elsalvadorklr
Oddometer: 3,964
you serious? I would of seen you, jajja
well come back...
we have a little wood lodge were friends can stay at...sort of a "b and b" but for friends and family...
whenever you do come back were open doors!
Paellas, tapas, beer, and a nice ride through coffee plantations(this is the good sh...t)
anywhoo
see ya around
I would love to have some ridrs down...
anything you want... we are here to help
christian
Old 11-13-2011, 07:54 PM   #2781
mcma111
mcma111's Avatar
Oddometer: 8,011
Owyhee,
I wouldn't use a Hot Cam if you paid me.
Does that answer your question???
You have to much $$ and time invested to risk using a POS Hot Cam.
I don't want to be saying I told you so.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-13-2011, 11:44 PM   #2782
Callahan
Callahan's Avatar
Oddometer: 1,124
Originally Posted by mcma111 View Post
Owyhee,
there you go, it was only a matter of a little time and he has spoken
Old 11-14-2011, 04:54 AM   #2783
brucifer
brucifer's Avatar
Oddometer: 1,627
Owyhee, have you read this thread? http://www.advrider.com/forums/showthread.php?t=740463
My personal experience has been good with Hot Cams.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is online now   Reply With Quote
Old 11-14-2011, 06:42 AM   #2784
Owyhee
Ran when parked
Owyhee's Avatar
Oddometer: 505
Owyhee,
Thanks for the direct answer. This week I'm going to give Megacycle and Webcam and call and see what they recommend grind wise for my application.
Actually, yes, and it was that thread and the bike peeking at me from the corner of the garage that prompted me to finally figure out what to do to finally get that bike done (correctly).
Here's where the bike sits as of August 2010, the last time I worked on it:
It shares parts/farkles/wheels with my stock 1999 XR6 but is currently sporting a 5.8 gallon tank, 1995 CR500 forks, and there's a WP Superadjuster floating around in the garage somewhere.
Something I found out the hard way was that while CR500 forks fit with the big Acerbis tank, CR125/250 forks will not. The 125/250 fork's lower pinch bolts install from the side rather than the front and hit the tank at about 30 degrees of fork movement.
-Owyhee
Old 11-14-2011, 07:03 AM   #2785
brucifer
brucifer's Avatar
Oddometer: 1,627
Looking good, man!
Old 11-14-2011, 08:46 AM   #2786
elsalvadorklr
Oddometer: 3,964
coordinates!
Coordinates ?
here are the GPS coordinates for those of you who are interested!
13*52.050N
089*50.936W
thanks!
christian
Old 11-14-2011, 09:43 AM   #2787
Callahan
Callahan's Avatar
Oddometer: 1,124
13*52.050N
089*50.936W
thanks!
christian
Thxu
Old 11-15-2011, 02:10 PM   #2788
Michel77
Oddometer: 62
Hey all,
Just a quick question, probably pretty simple to answer for the XR600 guru's but I need to get confirmation so I can get some parts ordered. I am working on a 1986 XR600 and along the way decided to open up the carbs and give them a good clean. When I put them back on and opened the fuel, it started leaking from the bowl gaskets which, as it turned out, are pretty well toast..
I need to order a gasket set but can't figure out what type carb it is, the only indication is the Keihin logo and "PH" on the side, not much else. Being the first time I work on these bikes, I figured I'd ask before getting orders wrong, etc..
Below two pics for reference, thanks in advance guys!
'86 XR600 - Street Tracker
Michel77 is offline   Reply With Quote
Old 11-16-2011, 11:20 AM   #2789
elsalvadorklr
Oddometer: 3,964
fork springs and rates you like?
hey guys...
what rate fork springs have you guys used and how much do you weigh?
I think I weigh a bit much for the stock springs in my 98 forks, and I also have a 4galon tank on, I think I ride aggressively and need something better up front.
I am getting a revlaved an reworked shock for the back so Im stoked about that but need some beefing up in the forks.
Racetechs' site is weird, they recommend .51 but offer a .46 for a 170lb rider for desert/enduro
what have you guys used that works?
heard eibach's are great but they offer a .42 and .44
I read somewhere that for a 180lb rider .43 where good but really want to make the right choice!
Thanks dudes
Old 11-16-2011, 11:29 AM   #2790
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 505
Originally Posted by Michel77 View Post
Hey all,
Just order the OEM original bowl gaskets from your local shop or from Cheapcycleparts.com. I don't think there are any aftermarket options...
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S
1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Times are GMT -7.   It's 05:14 PM.
