Old 01-03-2012, 01:41 PM   #3001
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,512
Originally Posted by nikolic View Post
Is there any index on how-to-s and troubleshooting? I have tons of questions, or should I just shoot? :)
start here.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 01-03-2012, 01:53 PM   #3002
nikolic
Oddometer: 479
Thanks, when I get to the end, I'll probably figure out most thing on my own . So as I'm reading, should I make an index?
Home rides ;)
nikolic is offline   Reply With Quote
Old 01-03-2012, 05:02 PM   #3003
booniebasher
booniebasher's Avatar
Oddometer: 627
one of the cleanest xr600 ever, 250 orig miles
i bought this cherry xr6, i am using it as a dual sport bike. it will never look this good again because I live in the desert.I shot the pictures prior to putting it through the paces.
https://picasaweb.google.com/951kid/...eat=directlink
booniebasher is offline   Reply With Quote
Old 01-03-2012, 05:14 PM   #3004
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,655
Absolutely DELUXE!
Dam it's all set up.
Question though, what's the set up in the last two pic's?
And another...
The rear peg set up is that a system that works only with the frame guards?
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is online now   Reply With Quote
Old 01-03-2012, 05:50 PM   #3005
booniebasher
Oddometer: 627
thanks for checking it out. I am amazed what these bikes will do.
sweet, thanks....Nice chanell... I am gonna check it out more . The first set of buddy pegs i bolted to the frame guards, did not work well when my wife stood up in the bumps. So I had my machinest build the others, actually they are xr,s onlys but modified. the other pictures are of a surfboard rack
my you tube chanell, helmet cam stuff.
http://www.youtube.com/user/keithrit
Old 01-04-2012, 12:26 AM   #3006
nikolic
Oddometer: 479
Started making the pegs myself, so I'll post a progress! There is a lots of things to be done on mine.
Should do the choke plate, clean the oil pipe and filters... And yeah, is there any cheaper solution for
sphere bearings in the dumper?
Home rides ;)
Old 01-04-2012, 05:23 AM   #3007
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,655
Went there...
If I didn't have to be gearing up for work, I'd be checking your channel further...
OK, live in the desert and carry a surf board? on bike? he, he..
too many...
2manyrides screwed with this post 01-04-2012 at 05:34 AM
Old 01-04-2012, 11:04 AM   #3008
xr6
Oddometer: 27
Fitting a FCR-MX 39
Hi!
I just fitted a FCR MX 39 carb on my -95 xr600r. From my first testride it seems to be running great!
However, fitting it in the frame was a bit complicated. The upper throttle cable can not be used becaus its touching the tank.
I have heard that fitting the same carb on a XRL works just fine. One reason for this might be that the insulator between the engine and carb differs between the XR and the XRL, another that the tanks differ. Does the XRL insulator fit the XR engine?
Are any of you guys running a FCR-MX carb on your XR:s or XRL:s and know of any solution to this problem?
xr6 is offline   Reply With Quote
Old 01-04-2012, 11:13 AM   #3009
nikolic
Oddometer: 479
Originally Posted by xr6 View Post
Hi!
I've heard people having that problem... I'm planing on fitting TM40! Did you fit some kind of spacers or it fits the stock rubber intake?
Home rides ;)
Old 01-04-2012, 11:55 AM   #3010
xr6
Oddometer: 27
My FCR was from a yz 426f, the xr 600 intake rubber fits right on. Had to make a small spacer on the airbox side.
xr6 screwed with this post 01-04-2012 at 11:26 PM
Old 01-05-2012, 06:42 PM   #3011
DirtandBlood
DirtandBlood's Avatar
Oddometer: 29
Installed and tested the XRs Only goodies I got for X mas:
Big Footpegs: Definitly worth it. Im 6'2 250lbs plus gear. I am much more stable standing. i don't teeter fore and aft. Major reduction in arm and hand fatigue. Easy install and they are Chrome! haha
XRs Only Power up tip: Replaces the tip on Supertrapp-type mufflers. It has a cone inside that supposedly helps the exhaust get out more smoothly.
Verdict: Its louder with the same number of discs. Effin Loud! There was a definite increase in power though. It seems to have soaked up some of my aforementioned fat jetting. It really cooks along in the 1/4 to half throttle range. Zippy!
Gripper Seat Cover: Like it! Install wasn't too tough with a decent staple gun. Really helps me grip with my thighs while standing. Seated in the rough it was much easier to keep my ass where I wanted it. Its a little harder to slide back and forth through the turns.
XRs Only Skidplate: Easy install. You need a T40 Torx Bit. Built solidly but a little rough around the edges. Does not reflect as much engine noise as another skid plate I had.
Real happy with all these goodies. The combo of the Gripper seat cover and big pegs really enhanced my comfort and control.
DirtandBlood is offline   Reply With Quote
Old 01-06-2012, 08:53 AM   #3012
elsalvadorklr
southern xr rider
Oddometer: 4,154
I second the gripper cover...
its great and I have the same comments as above, it was a huge difference in the turns and staying put in the rough stuff, I like it a lot!
elsalvadorklr is offline   Reply With Quote
Old 01-06-2012, 09:43 PM   #3013
tim007
tim007's Avatar
Oddometer: 470
iiiimmm bbbaaaccckkkkk .. going to pic up my second xr600r after (( regretfully ))) selling my first one
pics tomorow
tim007 is offline   Reply With Quote
Old 01-07-2012, 04:31 AM   #3014
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
I really like those black side panel stickers, do you know who makes them?
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 01-07-2012, 01:06 PM   #3015
elsalvadorklr
southern xr rider
Oddometer: 4,154
me too!
they are custom made at a sticker/decal place down here...
I gave them the side panels and they put on some vynil/sticker sheets and heated it on.
They have survived a lot of brushes and a couple of good get offs...
I will be doing them again whenever I get these looking bad again...
It was cheap here about $15 for both covers...
dont know how much it would be in the states but im assuming more expensive!
Cheers!
Times are GMT -7.   It's 07:01 AM.
