05-08-2012, 08:29 AM
#4126 |
Unsprung Weight
Oddometer: 1,099
Be patient Grasshopper.
I tried the find a K&N breather with a nipple at the local Auto-rama, but nobody had them in stock. Found a small push-on breather filter and used a nylon elbow from the sprinkler section a Home Depot. The hose is black vinyl (5/8" I think). This starts at the top of the case, comes in next to the upper shock mount and just lays into the air box. I had to trim a tab on the bottom of the seat pan to keep from pinching the hose. Seems like a little mist/blowby residue is on the inside of the air box, but only a little. If anything, it is just another surface for dust to stick to before it hits the filter. I opted for the air box mount thinking it is the most shielded place to have the filter, and it's higher than the carb so in theory, this filter or opening will be the last place water can go. What ever filter you choose needs to breath as good as possible. That piston moves a lot air. Pics to follow.
1991 Honda XR628R 1978 Yamaha XT500 1965 Hodaka Ace 90 |
05-08-2012, 08:31 AM
#4127 |
Yeah yeah yeah patience, how long will that take?
05-08-2012, 11:38 AM
#4128 |
Oddometer: 3,964
like guns and roses said
yeeeeeeeeeeeeeeeeeeeeeeeeah yeaaaaaaaaaaaaaaaaaaaaaaah "just a little patience......yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeah yeah" cept I GOT NONE whta the heck is that? jajajaja kidding thanks man thats my next project right now Im fixing my old 4x4 montero, got a rally ride to the mountains to my bar getting planned for saturday! how cool is that? cheers buds |
#4129 |
couch traveller
Oddometer: 67
crankcase filter...you can place it higher...if you leave it open all sort of shit will get sucked in...
94 XR600R 2000 Transalp 650 zipper2680 screwed with this post 05-08-2012 at 11:39 AM Reason: spelling |
05-08-2012, 11:41 AM
#4130 |
Oddometer: 3,964
hmmm yours is low but its a sumo
and its pointed down for a reason? nice bike once again zipper! thanks |
05-08-2012, 11:55 AM
#4131 |
couch traveller
Oddometer: 67
Like i said you can place it higher.Right now its in a higher position.No longer a sumo.No special reason to point it down.
94 XR600R 2000 Transalp 650 |
05-08-2012, 12:09 PM
#4132 |
Oddometer: 689
Quick chain/sprocket question?
I'm planning on a longish roadtrip soon and going to go with a 14/40 OR 15/40 combo on my 88 XR600. Was wondering IF I need to get a 110 OR a 112 link chain to go with it. I have a 14/45 right now with a 112. Didn't know since I would be going dow quite a bit in rear sprocket size if a 110 would be better.
Jeff Reichel Palmer, Alaska 1 Tim 6:11-12 "FIGHT the GOOD Fight" funinak@mtaonline.net PLATED 88 XR600R & 92 FATBOY (in rebuild status) |
05-08-2012, 12:38 PM
#4133 |
Oddometer: 7,983
14/40?? Geeeezzzzzzzzzz
Planning on Salt Lake Speed runs?
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
05-08-2012, 12:53 PM
#4134 |
Oddometer: 689
It's not THAT high geared.... I was told by a 650L owner who has done this trip that he had a 14/40 combo on and it was very good. My 14/45 gets a little buzzy at 60+ now
05-08-2012, 01:22 PM
#4135 | |
Semi-Adventurer
Oddometer: 9,829
I have 14/47 on my '88 XR right now, and it does get buzzy on the highway. But, it is as tall as I want to go for off road. It is taller than I would like in tight spots. 14/50 is better for trails, but of course miserable on the highway. For good gearing both on, and off-road, I think the best solution is to add a TE610.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
05-08-2012, 01:25 PM
#4136 | |
Oddometer: 689
05-08-2012, 01:38 PM
#4137 |
Oddometer: 7,983
Correct. 1 front = 3 rear. Your idea of going from a 48 to a 40 rear seemed to be a bit excessive. And yes the XR and XRL do have similar transmissions with the exception of the main shaft which is 1 tooth different. So that does make for a difference.
05-08-2012, 02:32 PM
#4138 |
couch traveller
Oddometer: 67
I was running 15-43 with a 17" SM. With the 18" i saved a lot of fuel, but for off road was too tall..A 40 rear is too tall for a stock 600R...Just my 2 cents.
Best luck for the trip.
05-08-2012, 02:38 PM
#4139 |
Oddometer: 3,964
sucking ziploc filter goooooop take 1.
soooo
this is my technique for oiling and storing filters now Im a cook by trade and souvide cooking is very popular...it seals in the juices, well I did this with my filters first you pour two or so capefull of uni filter oil in a new zilpoc bag.... you then smear it in a pattern similar to the shape of your filter then you blow the bag up using air you can gingerley put the filter in the middle of the oil sandwich then you seal the zilpoc bag up leaving a small hole or aperture where you can either use the tremendous SUCKING ability us humans have jajajaja OR use a vacum tube or safesail machine they sell at the walmarts... this is what it looks like all sucked up ![]() easy peasy...oooops thats someonelses line OH you then need to airdry the hell out of it in the sun!!!!!!!!!!!!!!!!! my issue was I was lame in not using solvents or cleaners, and it took me forever to clean the old oil off the filters and gunk, not too mention that process was not as good as using solvent which does it in seconds...yeah maybe I lose some filter life but hey beats spending a morning cleaning the damn thing cheers dudes |
05-08-2012, 02:40 PM
#4140 | |
Oddometer: 3,964
I used 14-45 and the bike didnt feel as peppy I love my 14-50 now...but Im strictly offroad... tarmac is point a to point be only to get to the dirt so I dont care cheers |
