Old 05-09-2012, 11:54 AM   #4171
elsalvadorklr
Oddometer: 3,967
Originally Posted by mcma111 View Post
Patience is over rated.
I want it all NOW
no shit
you know me!
but dealing with the carb im like mama grany
slow as hell
even put gloves on
jajaja
elsalvadorklr is offline   Reply With Quote
Old 05-09-2012, 11:58 AM   #4172
elsalvadorklr
Oddometer: 3,967
Originally Posted by deejay_xr View Post
Fuck yeah !! I love my Dremel !
Check this out
Drilled into the screw, managed to loosen it and got it out.
Hole goes straight into the screw, thread in the slide is 100% undamaged
I love being stubborn, haha
well you showed us
care to show what tip you used??????????????
doesnt count unless you show pics of tools used
yeah thats right!
good job
heres a beer on me
Old 05-09-2012, 12:05 PM   #4173
deejay_xr
deejay_xr's Avatar
Oddometer: 471
Originally Posted by elsalvadorklr View Post
well you showed us
yeah thats right!
good job
heres a beer on me
Something to look at while you're sipping on that beer
Used a 1.2 mm drill-bit and the flexible thingy to get into tight spots
I think I'll pop open a cold one myself, cheers !
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 05-09-2012, 12:11 PM   #4174
mcma111
mcma111's Avatar
Oddometer: 7,989
That screw is a heck of a lot bigger than the last slide screw I worked with. Good job.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-09-2012, 12:18 PM   #4175
deejay_xr
deejay_xr's Avatar
Oddometer: 471
I thought it was small enough , thanks man !
Now the whole dilemma with the different carbs is solved, both needles on my own carbs are loose, just put in some new screws (flathead instead of philips this time ) and voila
Old 05-09-2012, 12:41 PM   #4176
mcma111
mcma111's Avatar
Oddometer: 7,989
Flat head?? Why not allen/hex cap screw??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-09-2012, 12:45 PM   #4177
deejay_xr
deejay_xr's Avatar
Oddometer: 471
Yeah I just thought of that too.
I'll swing by a hardware store tomorrow to see if they have any little allen bolts with the correct size
Are the needle clip positions stated in the manual referred to as starting from the top of the the needle?
i.e. the leanest state (needle as low as it gets) would be 1st groove?
Old 05-09-2012, 12:53 PM   #4178
mcma111
mcma111's Avatar
Oddometer: 7,989
#1/top groove is the leanest. Usually have five grooves. Bottom being the richest. Start in the middle and tune from there. I remember jetting my XL600 and what a PITA removing the carbs was. One tip is to use a heat gun or hair drier on the intake boots to soften them up. A shot of WD40 and the carbs slide on like butter.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-09-2012, 12:57 PM   #4179
deejay_xr
deejay_xr's Avatar
Oddometer: 471
I pretty much have the carb removal down by now, but it's still a pain yea.
As it turns out my needles were in the right position (as listed in manual) all along, but atleast now I know
And as we all know
deejay_xr screwed with this post 05-09-2012 at 01:06 PM
Old 05-09-2012, 01:20 PM   #4180
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,100
Breather pictures
OK Grasshopper, here are your photos.
The tube follows an open space next to the frame and the filter hangs into the air box.
Used a square(ish) barbed elbow from HomeeD's. The filter is a Uni from the parts store.
Tube routing is real simple. It think it's good to have a length of vertical tube to allow the oil to collect and run back.
Had to cut a notch in the seat pan to keep from pinching the hose.
Pretty simple. Just makes me feel better to have a filter on it. The Honda "krazy straw" thing works (I guess) but this seems like cheap insurance.
Cheers, Jeff.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
JAB screwed with this post 05-09-2012 at 02:50 PM
JAB is offline   Reply With Quote
Old 05-09-2012, 06:41 PM   #4181
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,560
Gasmask bags $9,99
French bags from army/navy surplus store, leather and rivits.
This is how far I got today, A little more tweaking and I'll put them through some rigous testing.
Just had a look on line at wolfman tank panniers they are 79.99...
Their front fender tool pack is 24.95...cheap enough.
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides screwed with this post 05-11-2012 at 06:33 AM
2manyrides is offline   Reply With Quote
Old 05-10-2012, 02:34 AM   #4182
boomshakalaka
Oddometer: 137
So I finally dug into my leaky top end. Tomorrow, when I wake up, I'm going to drop the top end off at the machine shop to have them check tolerances and give it all a bath in their parts washer. I'm a little worried as there was a bit of play in the piston pin, and also there is a little bit of wiggle from the connecting rod. I'm working in a dimly lit carport, with minimal tools, so I really don't think I'll be doing the bottom end myself. I have a video that is loading from my phone right now that I will post showing the play in the connecting rod. Worst case... I live at the top of a hill, and at the bottom of the hill is a small motorcycle shop who I've been buying chain lube and whatnot from, which appears to have competent people working for it.
Anyways, I'll be ordering some parts soon, and I was wondering what spark plug people are running. The Honda parts fiches have five or so to choose from, and I don't know much about these bikes, so I'm open to suggestions.
When the pics/video finally load I'll post them up here so you guys can tell me if my bottom end is screwed.
connecting rod video:
http://www.youtube.com/watch?v=y1si1...ature=youtu.be
oops
guess I need a new 10mm allen socket and a crank bolt cover thingy..
boomshakalaka screwed with this post 05-10-2012 at 02:48 AM
boomshakalaka is offline   Reply With Quote
Old 05-10-2012, 04:02 AM   #4183
deejay_xr
deejay_xr's Avatar
Oddometer: 471
Is that JBweld or something?
Did it work?
How 'cold' a spark plug you should run has mostly to do with outside temperatures and elevation I believe, I just went with the NGK plug my local dealer recommended me, I can;t check right now which one that was, sorry
Old 05-10-2012, 04:28 AM   #4184
mcma111
mcma111's Avatar
Oddometer: 7,989
Boom,
that side to side play is normal as is the small play on the wrist pin.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-10-2012, 06:04 AM   #4185
elsalvadorklr
Oddometer: 3,967
Cheers, Jeff.
thanks a lot masta!
appreciate it!
Times are GMT -7.   It's 09:20 PM.
