Old 05-16-2012, 01:11 AM   #4291
xr6
Oddometer: 27
Hi!
I have a pig with tm40 carb and crf 450 forks etc. I plan on trying to get a Acerbis 22 liter tank. Does anyone know if the bigger tank will interfere with the crf forks?
xr6 is offline   Reply With Quote
Old 05-16-2012, 05:40 AM   #4292
STFU
Found
STFU's Avatar
Oddometer: 397
Originally Posted by lstzephyr View Post
If it was my bike I would be looking for a single carb top end and a xr650L frame/swingarm. That way the bike would always be a "street legal" bike and not a converted dirtbike. Single carb for simplicity and the xr600 bottom end for kickstart and lightweight. Toss the xrl first gear, nx650 second gear and fmx650 fifth gear in along with a 628 kit and I think it would be one cracker of a xr600r. That is what I would (try) to do at least. I believe that it all should bolt together with the right supporting parts.
But with all that said I really liked my 85 xr6 and it was a blast stock. I'm sure you will have fun either way.
Im thinking somewhere inbetween the two. Probably wont pony up the money for a big bore, as I dont need crazy power and want to retain reliability (and I have an Aprilia SXV5.5 for big power fun).
Street legality isnt as much of an issue in NH, as we can register just about anything with 2 wheels, but a plated frame would be that much easier/better.
I already have the CR500 forks and Im working on a rear disc conversion, and the frame is already stripped down...might be easier to find a doner bike with a bad lower end and build off of that.
Tiger 955i
450 EXC
450 XC-F
XR250R
TR200 FATCAT!
STFU is offline   Reply With Quote
Old 05-16-2012, 05:42 AM   #4293
mcma111
mcma111's Avatar
Oddometer: 11,865
Originally Posted by xr6 View Post
Hi!
Not first hand knowledge but it most likely will. I have a 4.0 Clarke on my XR and I welded stops to the side of the frame. It's right below the wire harness keeper loop. See it? Just a small block of steel. Dry fit the forks and ground away until the forks got max turn without hitting the frame.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2012, 06:56 AM   #4294
xr6
Oddometer: 27
Yea, I see it - nicely done!
However I might buy one and test...
Would welding the frame need stripping it down totally (could engine and electrics be damaged otherwise)?
xr6 screwed with this post 05-16-2012 at 06:57 AM Reason: spelling...
Old 05-16-2012, 07:47 AM   #4295
elsalvadorklr
southern xr rider
Oddometer: 4,154
just disconnect the stator ground and coil ground at the frame and use ample wet newspaper...to cool down
if tig welding then just do it fast...
no need to strip down anything
just take off tank
cheers
elsalvadorklr is offline   Reply With Quote
Old 05-16-2012, 08:13 AM   #4296
mcma111
mcma111's Avatar
Oddometer: 11,865
You can leave everything connected but I'd pull the CDI just cause.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2012, 10:23 AM   #4297
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
Hi!
lil bit, but you can adjust the tank a little. and a little flex in the mounting points adds up to being able to go full lock.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 05-16-2012, 10:25 AM   #4298
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
like steve said. I'd add to pull the neg on the battery because why not, and place the welding ground as close to the area as possible and as always, amke sure you have a good connection. Helps keep the heat and the juice in a confined spot.
Old 05-16-2012, 10:55 AM   #4299
xr6
Oddometer: 27
Ok, nice! I see you drive a XRL, is this the same for Xr600r?
Old 05-16-2012, 10:58 AM   #4300
xr6
Oddometer: 27
Thnx all for the comments on the welding issue. Ill just disconnect the cdi and stator ground.
Old 05-16-2012, 11:09 AM   #4301
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
only difference I can think of is the two little shrek ears on the 600. My XRL doesn't have the stock fuel tank mounting points and hasn't for a while, so I don't remember what it looks like, but I think that's the only difference.
and in case you don' tknow, the 88 XR600R + and the 94 XR650L have the same parts, with a few exceptions. If it interests you, there's threads somewhere on the swappable parts. A cursory search should turn them up. There's some info over at thumpertalk as well.
Old 05-16-2012, 11:14 AM   #4302
mcma111
mcma111's Avatar
Oddometer: 11,865
The XR600 and XR650l have TOTALLY different gas tank mounting systems and a tank from one will not fit the other unless you find an aftermarket brand that makes one tank for both models.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2012, 11:20 AM   #4303
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
like... the acerbis 22L?
Old 05-16-2012, 11:23 AM   #4304
mcma111
mcma111's Avatar
Oddometer: 11,865
Don't know about the Acerbis. There is a tank in the flea market currently for sale that does have both type of mounting points on one tank. Go look see.
Correction. There WAS one, It's gone.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2012, 11:26 AM   #4305
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
ah, well it does. there's 3 different mounting positions for the front supports. Having had the tank on there since I got it, I can't say that there were 3 different supports however. I think the 650L,600R and maybe the 400?
Times are GMT -7.   It's 12:10 PM.
