Old 09-17-2009, 04:17 AM   #481
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,426
If you upgrade the lighting and stator to supply 200 watts to the lights you should probably recable the switch wires, or run a relay, as the switches and cabling are really only rated for 35 watts, and the heat from resistance can burn stuff out.
GodSilla is offline   Reply With Quote
Old 09-17-2009, 05:08 AM   #482
ThereisnoSpoon
Wall of Death Rider
ThereisnoSpoon's Avatar
Oddometer: 1,508
When I got the Rickystator stator there was the option to run one 200w circuit ot two 100w ones. I did the 100 x 2 and used the stock wiring to run one light (the flood) and ran a new circuit to run the second light (spot) and heated grips. The new circuit has a switch for both the light and the heat which is off most of the time. I've been running it for three months with no problems. Don't forget the heavy duty regulator.
ThereisnoSpoon is offline   Reply With Quote
Old 09-19-2009, 03:35 PM   #483
chummpo
rock bashin
chummpo's Avatar
Oddometer: 17
after putting a 19Lt clarke tank on it, what weight springs do I need in the front?
im just going to wind the back spring up, and ill see how it goes
ps. blackbird, to you have the scout or the ranger dirt-bagz?
ridin the big white pig :P
"I am the Nightrider. I'm a fuel injected suicide machine. I am the rocker, I am the roller, I am the out-of-controller!"
chummpo is offline   Reply With Quote
Old 09-19-2009, 03:58 PM   #484
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 12,177
That's the way my Baja Designs 250w stator is wired - 125w x2.
One goes to AC, one to DC on mine.
The Rangers.
IBA #11735 . 1968-present
Blakebird is online now   Reply With Quote
Old 09-21-2009, 01:24 PM   #485
OzRoundin'
OzRoundin''s Avatar
Oddometer: 177
Originally Posted by RidingQWERTY
Hi Guys,
I'm looking at doing a trip through NZ on my '93 XR600 (about 5000km) over a couple of weeks. One of the major things I want to do is upgrade the lights. I've looked at the Ricky Stator option - cost about $390 for the stator and a pair of 100w lights. Is any other hardware required?
I see there is also the option of a nicad batteries to drive the lights - anyone done this? How long does a charge last?
Also looking at a screen - what do you guys recommend?
http://www.procycle.us/dskits/dskit.htm this screen should do. The cheapest universal one i have found
OzRoundin' is offline   Reply With Quote
Old 09-24-2009, 09:55 AM   #486
UK Jimbo
UK Jimbo's Avatar
Oddometer: 211
Just found this beauty on eBay. I could well end up being the owner of two XRs...
http://cgi.ebay.co.uk/1996-HONDA-XR6...d=p3286.c0.m14
UK Jimbo is offline   Reply With Quote
Old 09-28-2009, 04:23 PM   #487
UK Jimbo
UK Jimbo's Avatar
Oddometer: 211
Oops - I am!
Old 09-28-2009, 05:41 PM   #488
ThereisnoSpoon
Wall of Death Rider
Oddometer: 1,508
Oops - I am!
Nice! You can never have too many XR's. £1,650.00, what is that like 10,000 US $ ?
Old 09-29-2009, 01:11 AM   #489
UK Jimbo
UK Jimbo's Avatar
Oddometer: 211
$2600 which is a fair bit for an XR but finding one with 4k miles on the clock and fully farkled isn't that common.
Old 09-29-2009, 04:16 AM   #490
OzRoundin'
OzRoundin''s Avatar
Oddometer: 177
Why is my Xr6 such a bitch to start when cold with half choke. When it's a warm day it starts in three kicks no problem. But when it's cold... took me 20 kicks last night to get it going. couple that with sweat and swearing i has made me think twice about using it around australia next year.
Old 09-29-2009, 08:12 AM   #491
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,099
What happens when you go full choke? Don't give it any gas until after it starts. If it pops and tries to start, then go to half choke. No throttle. Should light right up.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
JAB is offline   Reply With Quote
Old 09-29-2009, 08:26 AM   #492
OzRoundin'
OzRoundin''s Avatar
Oddometer: 177
my full choke position is almost non-existent. The lever has sheathed. Come to think of it, when I'm on half choke it coughs but then when I put it on "full choke" accidentally, it screams to life. This choke thing, when I put it full choke do i wait a few minutes then try kicking it over or can I just hop on and kick it immediately?
Old 09-29-2009, 09:28 AM   #493
screwit
One more time
screwit's Avatar
Oddometer: 831
corbin for XR6
I'm not in the market so i'll pass it along...... If anyone is interested there is a corbin for an XR600 on fleabay right now. No it's not mine, i don't need another
screwit is offline   Reply With Quote
Old 09-30-2009, 07:12 AM   #494
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,099
Full choke when cold is the easiest way to start. Good excercise otherwise.
Not sure why you would wait. Switch on, gas on, choke on, kick and ride.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
Old 09-30-2009, 05:07 PM   #495
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 12,177
If mine is ridden every day or every other day, it will start in one or two kicks with full choke, no gas.
If it goes a week without being ridden and the gas off, I have to kick it thru ~10x and give it gas to re-prime the works. Not a huge deal, you just know it's going to take 10 priming kicks if it's sat. Riding every day...first kick.
I have enough stator for much more light, I just haven't gotten around to it.
The first sign of snow, the tank's coming off, the valves adjusted, and the grip heaters and Hella's go on.
Probably
Times are GMT -7.   It's 11:04 PM.
