Old 07-30-2012, 09:05 AM   #5161
mcma111
mcma111's Avatar
Oddometer: 12,063
Kirbi,
If you want a performance cam get one from Cycle Wizard. About $180.00 but you will also want to get your rocker arms treated at $55.00 each. Your engine will thank you.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-30-2012, 10:22 AM   #5162
kirbi69
Oddometer: 219
ok i wont buy it. ill just remove the decompressor stuff. i just take everything off the cam right? and weld up that little hole on the cam?
1994 XR600R dual sport
kirbi69 is offline   Reply With Quote
Old 07-30-2012, 10:26 AM   #5163
mcma111
mcma111's Avatar
Oddometer: 12,063
Why in the world do you want to remove the decom stuff? It's there for a reason.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-30-2012, 10:56 AM   #5164
kirbi69
Oddometer: 219
it makes too much noise. and it beat my right exhaust valve all to hell. i heard others say i dont need it. justneed the manual decomp lever
Old 07-30-2012, 11:09 AM   #5165
elsalvadorklr
southern xr rider
Oddometer: 4,154
yup you can do this
I tool it off because I didnt know what mileage my engine had when I bought it
reasons for taking it off are:
redundant
they fail when high mikeage
they actually cause the bike to stall a lot when high mileage, so you really have to keep a high idle
reasone to keep it are:
if you are lazy and want to just kick instead of learning the drill
they are supposed to prevent kickbacks, dont know how it does that really
yes MUST weld up hole or plug it up or you will suffer from oil depravation in the cam area...
what fails is the actual sprag gear or clutch and they start to rattle, the springs inside lose tension too..
lastly
some people take them off because they beleive that less rotational mass will make the cam spin more freely
thats far fetched BUT it is true you will save a couple ounces of rotational mass
if you want details I can send pics if you want
lastly
I do however agree with steve THERE IS NO REASON TO TAKE IT OFF
however they do eventually fail especially on high mileage bikes and you will start getting mad at the bike when it stalls, makes a racket, etc...
there is plenty of info on the nets about this if you want to search for yourself
anywhoo
elsalvadorklr is offline   Reply With Quote
Old 07-30-2012, 11:13 AM   #5166
elsalvadorklr
southern xr rider
Oddometer: 4,154
exactly YOU have a reason to take it off...you are one of the few but you have evidence
press off sprocket on cam...
weld hole under mechanism for decomp
make sure the weld does not use the cam as a ground in other words tell the welder that you must not get any "arching" on any part of the cam...
you do not want any imperfections anywhere near the lobes!
I had a small imperfection on one of the lobes but it does not make any noises or anything...
then press sprocket back on and your done
the manual decomp works flawlessy
this is a case of honda redundancy in an effort to prevent rider discomfort! jajajajaja
Old 07-30-2012, 11:44 AM   #5167
kirbi69
Oddometer: 219
yeah i always use the starting drill. hot or cold. fires up first kick everytime. i really dont think i need the autodecom. christian, didnt you say you took yours off first thing when you got the bike?
Old 07-30-2012, 12:01 PM   #5168
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,166
I've owned my 88 XR600 since last spring. The decomp cable was broken when I got it. Never really needed it, just learned how to start it by finding TDC and never looked back. Removed the lever, and all other associated stuff. Just have the mechicnizm on the top end still attached.
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 07-30-2012, 12:02 PM   #5169
elsalvadorklr
southern xr rider
Oddometer: 4,154
yup i sure did!
since I didnt know the mileage on the bike I took it off just in case
I read a lot about it and found out its a possible failure source so I just took it off
headtrauma among others use no autodecomp too
Old 07-30-2012, 01:25 PM   #5170
elsalvadorklr
southern xr rider
Oddometer: 4,154
alright paging techforlife?
can someone tell me the magnet trick used to test the pg is triggering or not?
I have the clutch cover off
everything looks good
the airgap for the pg is about.5mm
sooooo
a weird thing is the gap seems smaller than before
that could mean what? my damn crank is wobbling?
also there is a concave shape to the pulse generator tab or sensore, like if the tab on the crank gear is wearing a pattern on the pg?
anywhoo
I cant rememebr if I noticed this last time
but if anyone know the trick to test the pulse generator can trigger please let me know
I remember brian explained this to us a while back but I CANT seem to find it.
thanks
christian
Old 07-30-2012, 02:10 PM   #5171
elsalvadorklr
southern xr rider
Oddometer: 4,154
alright update:
bad news I guess
my gap on the pg to crank tab is .20mm
it should be .7mm
this explains the wearing of the tab on the pg
the pg is magnetised and I can get my meter to register movement..
but if the gap is too close what will this do?
too much voltage?
could I file the tab on the pg or could I try bending the bracket to get more gap?
this might of been caused by my old crank that was wobbly
thoughts?
thanks
Old 07-30-2012, 02:22 PM   #5172
BSW
BSW's Avatar
Oddometer: 82
( weld hole under mechanism for decomp ) I removed the autodecomp on both my 96xr to help easier starting and like wise it does not stall any more,i took the info off an old Australian bike mag about xr 600s used in the Aussie Safari Rally .No where did it mention to weld the hole in the cam,will this be a problem for me in future?
BSW is offline   Reply With Quote
Old 07-30-2012, 02:31 PM   #5173
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,127
yes. much more rapid wear of the cam and rockers.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 07-30-2012, 03:48 PM   #5174
mcma111
mcma111's Avatar
Oddometer: 12,063
The reason a XR engine may stall with the auto decom is because the idle is set to low. The whole decom thing is really a anti kick back and to assist with low RPM engine starting.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-30-2012, 04:20 PM   #5175
elsalvadorklr
southern xr rider
Oddometer: 4,154
steve any thoughts on my tight air gap on the pg?
it was way tight
should of been .7mm
anywhoo
think a pg is on order...
maybe next week
jajaja
Times are GMT -7.   It's 07:19 AM.
