Old 10-01-2012, 10:33 AM   #5866
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,619
Originally Posted by elsalvadorklr View Post
you lucky punks
havent been on the bike in almost 3 months now
I feel for ya man!
Maybe another shot will help/not hurt?
Note the gas hog that is a rich jetted XR650R...
rider milks the white cow...(up to the top, then goes on reserve)
650 rider, Mr Buzzcut, needed 12 liters to return to truck...
Deep in these woods on the duncan creek trail, I thought of the elsalvadorklr when my bike wouldn't start or even pop.
(trailtech going to reset mode/acting up/BD battery pack dead)
It would be a bad thing to be here and have a bike that wont start!
In the end, nothing wrong, just lugging too much downhill on a rocky singletrack with high gearing loaded up plug...
the lookout on duncan peak
the spectacular folage in the previously burned duncan canyon
we crawled all over the landscape and up to the lookout
2manyrides did the duncan creek trail for the first time in 'bout 30 years!
Gotta get that single track!
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is online now   Reply With Quote
Old 10-01-2012, 11:45 AM   #5867
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by kirbi69 View Post
im riding to the beach right now on my piggy :)
you suck
you know I ride beaches a lot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
beaches not the other type! jajajajaja
elsalvadorklr is offline   Reply With Quote
Old 10-01-2012, 12:23 PM   #5868
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,706
Originally Posted by pelkas View Post
I just managed to do the most idiotic thing for the month. Was about to change front wheel bearing on my 600R, did'nt check which way to press and just hammered on with our 80 Ton electro-hydaulic press. Need i say what happened next?
Well, one can only hope that this time, i'll actually learn something from my mistake. Mabye the fact that i need to spend hard earned $$$ on a new wheel hub will help making me think twice before doing anything stupid.
I just bougt a new hub on ebay from an -89 bike, though it looks identical, i'm not sure it'll fit my -95 bike. What do you guys think?
Originally Posted by speedmonkey7 View Post
The other guys will chime in I'm sure but I'm pretty sure the pre 91 bikes had smaller axles in the front. You may have to get conversion bearings. I hate making stupid mistakes like that...happens way too often lol.
Sent from my SAMSUNG-SGH-I997
you can double check here....lots of side scrolling involved...
http://www.oem-cycle.com/HondaXR200RBIKEID.shtml
S.t.t.G. is offline   Reply With Quote
Old 10-01-2012, 12:27 PM   #5869
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,706
well you have my exact same symptoms, bike running fine, park the bike, next day nothing...
all pointing to the stator...after A LOT of testing and even a new pg, cap, plug etc...
check volts at kickover...of your are not getting anything over 30volts, new stator time...at least for me this seems to be the issue
should be getting my stator soon, so Ill let you guys know...
The reason I say it might not be your cdi is I have 2 that I use, one was taken off the bike and running and kept as a spare...the red hot shots one...and the oem was on the bike when it died...
since I could not get my bike to start after swithcing back to the red cdi...we are all guessing my stator got cooked...
soooooo
yeah...Ill be looking for oil cooler mods...Ill see what that xr400 guy has to offer...I need cheap now...or save up some...jejeje
What kinda voltmeter you using? Analog or digital? Is one better or quicker reading to use?
Old 10-01-2012, 11:09 PM   #5870
Mike the Yank
Oddometer: 421
Eh?
Tried out my "new gearing" this weekend, 14-48 seams a little low for fast dirt roads, really reving at top end.
Going to swap the rear to a 45 and try again.
Mike the Yank is offline   Reply With Quote
Old 10-01-2012, 11:39 PM   #5871
rogervize
rogervize's Avatar
Oddometer: 75
Easier to change out the front for a 15?
Melbourne OZ..'92 XR600R '74 Yam TY250
rogervize is offline   Reply With Quote
Old 10-02-2012, 03:31 AM   #5872
Mike the Yank
Oddometer: 421
Wicked
started with
15-45 too fast to get over logs while lifting the back and feathering the clutch!
New rear because old had flogged out bearings, came with a 48
15-48 still a little fast on the take offs, feeling it's not perfect want more low end grunt!
New front 14 because counter shaft showing wear and I got an Unkown JT 14 spocket with a nice wide hub to counter the wear. Had to modify so very tight, not coming off in a hurry!
So 14-48 too many RPM, next change rear to 45 and see how that goes.
My first BRP so the learning curve might be a little on the low side.
Old 10-02-2012, 09:45 AM   #5873
elsalvadorklr
southern xr rider
Oddometer: 4,154
I use either 14-45 or 14-50
14-50 for races/dirt only
anytime Ill be riding dualsport or anything tarmac I put the 45 on the back...
the 45 on back does a nice job of taming down the revs, however I still feel that on the road the xr needs a 15 front so I will be looking for a 15-45 like you had...
what was your top speed with 15-45?
cheers
Old 10-02-2012, 09:48 AM   #5874
elsalvadorklr
southern xr rider
Oddometer: 4,154
3 or 4 pages back you can read the benefits of each with schraubers posts, ghost mutants posts and rogers posts!
all good info
what I could gather from all the posts is that a good analog meter is EASIER to read while kicking over to get a reading, however only a really good digital meter will give you the peaks in volts which is what you are after when looking for volts at kickover...
at least I think thats what I read...
Old 10-02-2012, 10:03 AM   #5875
ID XR600
ID XR600's Avatar
Oddometer: 245
XR600 motor
http://advrider.com/forums/showthrea...0#post19728020
"Endeavor to persevere."
ID XR600 is online now   Reply With Quote
Old 10-02-2012, 10:19 AM   #5876
pelkas
Oddometer: 6
well I dont understand why a press was needed but yeah and 89 has a 15mm axle, 91 and up has a 17mm axle..
you can use the 89 hub just fine...just get the newer style bigger bearings and install them along with a new internal hub spacer, seals, and odometer drive off a new model year xr...
this is what I did to my 88 hub when upgrading to newer style cartridge forks..excel wheel, etc...
Man I have all this too for sale, but nobdoy knows or want any of this stuff down here...jajaja
you can also buy and xrsonly speedo drive eliminator...if you do not want to buy a new odo drive...
Well, a press was probably not needed, i blame it on a very tired monday morning
Thanks though for the info, i guess i can use the bearings, spacer, seals and speedo drive i have for the -95 model then
-95 XR600R with NX650 engine
-04 Weestrom
pelkas is offline   Reply With Quote
Old 10-02-2012, 10:20 AM   #5877
error cooled
anything but asphalt
error cooled's Avatar
Oddometer: 1,181
The only OEM sprocket available for the 6 spline XR600R is 14. Given what I have seen with counter shaft wear I don't want to use anything non-OEM.
I am running a 14/43 combo which I really like on the road and fire roads. I would gear down if riding more technical terrain.
Honda XR600R
The Blue Ridge Trail - Virginia via gravel, dirt, two track and backroads.
USFS Motorized Access in Virginia - Protect your dual sporting access in the commonwealth.
error cooled is offline   Reply With Quote
Old 10-02-2012, 10:39 AM   #5878
elsalvadorklr
southern xr rider
Oddometer: 4,154
you sure can bud, its really easy...just switch everything over thats useable from the old hub THAT IS NOT BROKEN! jjajajajaja
new bearings for sure!
cheers
P.S. remember that once you remove bearings you must tnot REUSE them unless in an emergency...jejeje they get damaged when removing, its almost impossible to remove them without taping them in an axial manner...
Old 10-02-2012, 10:41 AM   #5879
elsalvadorklr
southern xr rider
Oddometer: 4,154
this is true, there is no oem 15 tooth for our 6 splines however I bet THERE ARE OEM sprockets for other bikes with the same design as ours with 15 teeth,
whoever finds that EL DORADO wins a big hug, or a beer, jajaja
Old 10-02-2012, 02:08 PM   #5880
error cooled
Oddometer: 1,181
The NX650 has 6 splines and was spec'ed with 15T up front. That has been discontinued.
The GB500 also was spec'ed for 15T -- and is now discontinued.
Honda XR600R
Times are GMT -7.   It's 03:05 PM.
