Old 10-04-2012, 04:04 PM   #5911
benno.h
cageracer
Oddometer: 437
Originally Posted by kirbi69 View Post
you can use a smallblue neon light for the highbeam indicator. they work on ac
Hm ok I might look into it. What do they look like?
I have just cannabilised the stock speedo unit and harvested a few bulb sockets and the indicator/high beam light panel. I might try and figure out how to integrate that.
Originally Posted by GodSilla View Post
I'll step out on a limb here and state that bikes without kick starters are just plain gay, for pansies, ladyboys, and suchlike. Furthermore, they should have to ride at the back, not speak until spoken too, and set everyone else's tents up, then cook and wash up afterwards, before sitting up all night guarding the real men's bikes.
benno.h is offline   Reply With Quote
Old 10-04-2012, 05:00 PM   #5912
lookfar
from the land of OZ
Oddometer: 655
Does the stock speedo unit still work? I am after one for my resto.
The one that I have is buggered.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 10-04-2012, 05:20 PM   #5913
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,239
Braided front brake hose
What is a good source to find a braided steel brake hose for the front of my 88 XR600? What is everyone else using, and where did you get it? I am planning on flushing the system and adding new fluid (who knows how long the fluid thats in it has been there) so I might as well replace the stock hose with something better.
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 10-04-2012, 06:25 PM   #5914
kirbi69
Oddometer: 219
you need something like this. its what i use. found one at a local autoparts store. radioshack or someplace similar might have one.
http://www.directindustry.com/prod/m...88-595099.html
1994 XR600R dual sport
kirbi69 is offline   Reply With Quote
Old 10-04-2012, 07:14 PM   #5915
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
Anyone want an 88 non disc swing arm? Just need to get shit out of the way. If you throw me some cash ill leave the linkage on it....
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 10-04-2012, 08:03 PM   #5916
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
I also have some 88 maybe forks. The axle is 15mm.
Old 10-05-2012, 08:42 PM   #5917
Jabba600
WA Adventurer
Jabba600's Avatar
Oddometer: 116
Fork swap again
Hi guys
i have bought a set of 95 cr250r forks and need the specs to put them on my XR600 96
which clamps should i buy (i only bought forks)
can i use my XR wheel axle speedo drive brakes on the CR forks
i presume i just press out the CR stem machine to suit bottom and top XR bearings and bolt it all together,
cheers
Jabba
Jabba600 is offline   Reply With Quote
Old 10-05-2012, 08:49 PM   #5918
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
Originally Posted by Jabba600 View Post
Hi guys
cheers
Jabba
I can turn the stem for you or I can send the spec sheet so you can take it to a shop for them to do. That way you can use XR bearings on the CR/CRF triples and so on.
Old 10-05-2012, 09:15 PM   #5919
Jabba600
WA Adventurer
Jabba600's Avatar
Oddometer: 116
If you could PM me the spec sheet that would be great as I have access to a lathe
Old 10-05-2012, 09:25 PM   #5920
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
Ok. Gimme a day or two. I have to start my computer to get the link. And I don't plan on doing that until its time to go back to work.
Old 10-06-2012, 01:38 AM   #5921
Mike the Yank
Oddometer: 442
Question mid range stumble
Any quick advice on a mid-range stumble? While in the middle of a ride sometimes my BRP sounds like it wants to cut out, I just gas it and it gets through. Or I gear up and it chugs on like the tractor it is but I always wonder why it doesn't want to run clean in the midrange?
Mike the Yank is offline   Reply With Quote
Old 10-06-2012, 01:18 PM   #5922
Royal Club
Royal Club's Avatar
Oddometer: 392
watch out with milling down stems..
Royal Club is offline   Reply With Quote
Old 10-06-2012, 04:13 PM   #5923
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Any chance you are rich on the needle? Is this a new issue? Have you made any other changes to the bike?
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 10-06-2012, 04:43 PM   #5924
Dino3310
Oddometer: 673
i had a simular stumble after a rebuild, was running a 1mm o/s with old stock jets, i put the scott summers size jets in and the stumble went away and performance was better all round... i think mine just wasnt getting enough gas, although in the past i have had choke problems(sticking) to have the same effect
Dino3310 is offline   Reply With Quote
Old 10-06-2012, 05:57 PM   #5925
Mike the Yank
Oddometer: 442
New problem, just started to act up. I don't have a temp gauge but it could be only when it gets hotter as it doesn't seem to do it when it is cold.
Times are GMT -7.   It's 08:30 AM.
