Old 11-12-2012, 09:14 AM   #6181
nikolic
Oddometer: 479
having a clutch problem too... what kind of additive? (I too have a 100mm piston) . I was thinking karbon too...
Home rides ;)
nikolic is offline   Reply With Quote
Old 11-12-2012, 09:35 AM   #6182
elsalvadorklr
southern xr rider
Oddometer: 4,154
STP zddp pil additive...its very thick
I usually only use maybe a 1/3rd of the bottle every oil change...
its my fault really I put in one whole bottle for the new camshaft and rocker set and should of changed it after 50 miles or so...
Now the oil is 200miles old or so...and the clutch is slipping in 5th when giving it a lot of gas...
Ill change the oil a couple of times...see what happens...
if I do need the clucth Ill get the ebc kevlar set...with heavy duty springs...
well see!
cheers
nice pics btw
elsalvadorklr is offline   Reply With Quote
Old 11-12-2012, 09:47 AM   #6183
mcma111
mcma111's Avatar
Oddometer: 12,574
FYI...
Heavy duty springs may be well and good but they sure give your left hand a workout on the trails or single track.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-12-2012, 09:54 AM   #6184
elsalvadorklr
southern xr rider
Oddometer: 4,154
yup! Im hating the thought of it...my clucth already sucks as is...its more the lever than anything...all floppy and hard to pull...
damn
Old 11-12-2012, 10:20 AM   #6185
nikolic
Oddometer: 479
Why does it say: do not use syntethic oil? And on the box, it doesn't say kevlar! http://www.ebay.com/itm/230820560178...fa3d32&vxp=mtr
Home rides ;)
Old 11-12-2012, 10:23 AM   #6186
mcma111
mcma111's Avatar
Oddometer: 12,574
damn
Here ya go. And a new Motion Pro cable. You'll be all set
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-12-2012, 10:35 AM   #6187
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
damn
Have CW set you up with a longer clutch actuator lever at the engine. He makes them for a reason.
xladv.com
MentalGuru is offline   Reply With Quote
Old 11-12-2012, 12:46 PM   #6188
SlickSix
SlickSix's Avatar
Oddometer: 185
I just welded 2cm to my clutch arm. Iīm not sure if itīs still heavy or not but it canīt hurt.
SlickSix is offline   Reply With Quote
Old 11-12-2012, 02:50 PM   #6189
elsalvadorklr
southern xr rider
Oddometer: 4,154
did you take the arm off? I know cw does that...cept with all the shipping and the favt that I just installed a new oem stator cover Im not feeling like taking off the damn arm off...
jajaja
Old 11-12-2012, 02:51 PM   #6190
elsalvadorklr
southern xr rider
Oddometer: 4,154
so you cant feel a difference?
Old 11-12-2012, 02:52 PM   #6191
elsalvadorklr
southern xr rider
Oddometer: 4,154
yeah one of these days...
motion pro clucth cable is already installed...
Old 11-12-2012, 03:52 PM   #6192
SlickSix
SlickSix's Avatar
Oddometer: 185
I welded it when I was still rebuilding it and since I still havenīt rode her...
Still waiting on the cam chain and hopefully thursday will be the break in.
Iīll tell you then, but it used to work.
When I was younger and still riding smaller bikes, the extended clutch arm, the shims under the springs and gp shifting were usual mods.
Old 11-12-2012, 04:11 PM   #6193
elsalvadorklr
southern xr rider
Oddometer: 4,154
well let us know man
I honestly think that a whole bottle of this stuff is what screwed me...that and leaving it in too long...
didnt do it before the cam swap and I more than doubled the amount I normally use...
my clutch was always smooth as heck and super easy to shift...yeah the clutch pull was a bit hard when singeltracking but that is because of the lever and or actuator arm...
wish I would of remembered about the arm extension before reinstalling the ricky stator...I was too eager to get her to start again and forgot
crap
Old 11-12-2012, 04:12 PM   #6194
elsalvadorklr
southern xr rider
Oddometer: 4,154
now that I remember the springs already have washers on them, do you add a similar size washer/shim?
Old 11-12-2012, 08:10 PM   #6195
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 391
No , just change from Mobil to castrol .
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Times are GMT -7.   It's 01:24 PM.
