Old 11-13-2012, 04:23 PM   #6196
elsalvadorklr
southern xr rider
Oddometer: 4,154
well a little good news...
changed the oil and gave it some nice smooth shifts up and down and did not use any additive...
will change out again in the next week or so...maybe the flushing will help
and turning in my air screw in a half turn helped with the cold start...it DID NOT DIE once it fired which is a good sign...
instead if dying 2 or 3 times after firing now it idled steadily
so a step forward for those that want to know
so well see what happens with the slipping clutch after a few rides..
wish me luck
christian
elsalvadorklr is offline   Reply With Quote
Old 11-14-2012, 04:50 AM   #6197
adventurer
Oddometer: 70
crankshaft primary gear direction?
Gday Guys,
Can someone please tell me, the crankshaft gear that drives the clutch basket has a bump/marker on one side, which way is this supposed to go , bump inward or outward?
Thanks for your time,
Graeme
adventurer is offline   Reply With Quote
Old 11-14-2012, 06:00 AM   #6198
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by adventurer View Post
Gday Guys,
Graeme
outwards, will post picture in a sec
here ya go
Royal Club is offline   Reply With Quote
Old 11-14-2012, 06:15 AM   #6199
Royal Club
Royal Club's Avatar
Oddometer: 392
ayeah, I'm pretty sure some of you are familiar with this technique but for the newbies, here is a neat little trick to change the colour of your fueltank (and other plastics) without having to buy it new...
Thumpertalk has a thread about this, but here is the TL;DR version made by a friend of mine.
Old 11-14-2012, 08:46 AM   #6200
elsalvadorklr
southern xr rider
Oddometer: 4,154
iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiinteresting!
Old 11-14-2012, 01:26 PM   #6201
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
The gas tank color-change brings up another question. How does one refinish
side panels, fenders, plastic bits? Tried sanding out the scratches, but I just get bigger/more scratches.
1991 Honda XR628R
1978 Yamaha XT500
JAB screwed with this post 11-14-2012 at 08:41 PM
JAB is offline   Reply With Quote
Old 11-14-2012, 04:06 PM   #6202
Royal Club
Royal Club's Avatar
Oddometer: 392
side panels, fenders, plastic bits? Tried sanding out scratches, but I just bigger/more scratches.
have a vid for that too, give me a sec
Old 11-14-2012, 04:12 PM   #6203
Royal Club
Royal Club's Avatar
Oddometer: 392
here ya go
I think you'll wanna go for the heatgun part..
or perhaps this, also read the comments below the vids on youtub
Royal Club screwed with this post 11-14-2012 at 04:20 PM
Old 11-14-2012, 08:46 PM   #6204
lookfar
from the land of OZ
Oddometer: 655
Originally Posted by Royal Club View Post
here ya go
If you use a steel wool scourer, it does a better job than the boxcutter blade..and a hell of a lot quicker too!!!
My .02
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 11-14-2012, 09:55 PM   #6205
bamfslap
Oddometer: 205
I tried the heat gun. Doesn't help much.
Wet sand paper worked great: 100 - 200 grit (to get out big scratches, if you don't have big ones skip) then get higher grit gradually to 2000 or more. Then go over with the heat gun for kicks (seemed to make it a tad shinier). Then clear coat.
Even with the clear coat it's not factory shiny but I prefer it that way. As long as it has a bit of gloss it looks good.
A lot of work but side plastics are expensive on the 650. For other fenders I'd just buy a UFO one.
Someone should test out that tank dye and tell my how it holds up. ;)
bamfslap is offline   Reply With Quote
Old 11-15-2012, 02:34 PM   #6206
elsalvadorklr
southern xr rider
Oddometer: 4,154
could someboy help me on how to change the font on here?
I hit something and the damn font is miniature I mean like 8! I got good eye sight but this is ridiculous...
dont know how to switch back to 12 or 14
pleeeeeeeeeeeeeeeeeeeeeeeeeeeease?
Old 11-15-2012, 03:04 PM   #6207
rogervize
rogervize's Avatar
Oddometer: 75
Christian...try hitting (control +)This works for me to adjust the display size
Melbourne OZ..'92 XR600R '74 Yam TY250
rogervize is offline   Reply With Quote
Old 11-15-2012, 04:35 PM   #6208
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks man!
asked on the xrl forum since they get more business...jajaja!
i feel dumb but hey at least Im not going blind! geeeze!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-16-2012, 12:46 PM   #6209
kirbi69
Oddometer: 219
or you can hold control and scroll the mouse wheel :)
1994 XR600R dual sport
kirbi69 is offline   Reply With Quote
Old 11-16-2012, 01:47 PM   #6210
booniebasher
booniebasher's Avatar
Oddometer: 628
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Hey quys while installing this case saver I noticed my sprocket has play In it ? It is very new as is the shaft? Are they this way even when new or are jt sprockets junk
booniebasher is offline   Reply With Quote
Times are GMT -7.   It's 09:50 AM.
