Old 11-16-2012, 01:47 PM   #6211
booniebasher
booniebasher's Avatar
Oddometer: 212
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Hey quys while installing this case saver I noticed my sprocket has play In it ? It is very new as is the shaft? Are they this way even when new or are jt sprockets junk
booniebasher is offline   Reply With Quote
Old 11-16-2012, 02:02 PM   #6212
kubiak
Oddometer: 4,141
its normal, brand new they have slop in them and jt seem to be good sprockets. you can check out the write ups on swithing to a xr650r sprocket, they take all the slop out with a better fit.
kubiak is online now   Reply With Quote
Old 11-16-2012, 02:03 PM   #6213
kubiak
Oddometer: 4,141
oops i thought i was looking at the xr650l thread, im not sure on the xr600 sprockets? the xr600 guys will know.
Old 11-16-2012, 03:11 PM   #6214
Dino3310
Oddometer: 624
Send a message via MSN to Dino3310
play as in side to side or back and forth?
hey with that chain gaurd... the top bolt is that on the engine mount?
Dino3310 is offline   Reply With Quote
Old 11-16-2012, 03:15 PM   #6215
booniebasher
Oddometer: 212
Side to side
Old 11-16-2012, 03:19 PM   #6216
Dino3310
Oddometer: 624
Side to side
all good, some use the xr650r sprockets as they are wider but the side to side movement is normal providing the retainer and sprocket are in good nick
Old 11-16-2012, 04:00 PM   #6217
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
You've got the answer right.
Side to side
Calling SPUD!!!!
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 11-16-2012, 05:15 PM   #6218
mcma111
mcma111's Avatar
Oddometer: 7,984
Since the gear retainer index's in the slot on the counter shaft there should be almost no movement side to side. Fore and aft rotation = worn gear and shaft.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-16-2012, 06:03 PM   #6219
booniebasher
Oddometer: 212
So the xr650 sprocket will work and is better. Does it just bolt up with no mods.?
Old 11-17-2012, 04:05 AM   #6220
lookfar
from the land of OZ
Oddometer: 253
Hey All,
I have a problem with my XR.
I am attempting to line up everything on TDC so that I can replace the timing chain, and the markings on the flywheel are nowhere near the inspection hole when on TDC. With the flywheel marks lined up in the inspection hole, the piston appears to be on BDC prior to the compression stroke. Needless to say, the markings on the cam sprocket are way out.
The engine was running before I removed it from the frame..
The marks are on the flywheel are: | | |F |T
got me stumped....any ideas???
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL600R
1988 XR600
lookfar is offline   Reply With Quote
Old 11-17-2012, 06:57 AM   #6221
mcma111
mcma111's Avatar
Oddometer: 7,984
In the small hole on the stator cover you should see the T sideways. The piston will be at TDC. If the cam chain is off it doesn't matter about compression or exhaust stroke. Get the chain on the bottom gear and the top gear like this:
Be sure that the cam lobes are DOWN.
Unless you have removed the stator rotor and installed it 180' out there's no way the piston will be at BDC with the T mark in the hole.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-17-2012, 05:40 PM   #6222
Captain115
Captain115's Avatar
Oddometer: 99
New '89 XR600
Hi everyone,
Bought my first offroad bike the other day, 1989 XR600 which has been bored out for a 630 kit. Also came with bashplate, frame protector, larger pegs, new spring, hand protectors, aftermarket headlight and renthal bars.
Previous owner just replaced the front axle, wheel bearings and exhaust valves so shouldn't need to pull apart the engine for a while. Choke lever was broken so I have ordered parts to replace that.
Pretty keen to learn to ride on the dirt too! Pics to follow:
Cheers,
John
Captain115 screwed with this post 03-17-2013 at 03:34 AM
Captain115 is offline   Reply With Quote
Old 11-17-2012, 08:55 PM   #6223
lookfar
from the land of OZ
Oddometer: 253
Cheers for that, Steve, It appears to be that sometime in the past, the flywheel has been installed 180' out.
I cannot get the marks to line up with the piston on TDC.
The last guy that was in here didn't own a set of allen keys either, apparently. There are a few allen headed bolts that have been minced by a cold chisel and a lock nut from the tappet adjustment was loose and floating around.
My guess is that it was dropped, and rather than find it, it was just replaced.Luckily, it did no damage while it was loose in there.
Stu in FNQ
1985 XL600R
1988 XR600
Old 11-17-2012, 09:03 PM   #6224
Alaskajeff
Alaskajeff's Avatar
Oddometer: 689
Originally Posted by Captain115 View Post
Hi everyone,
Cheers,
John
WELCOME to the kick start club John! Let the modding begin
Jeff Reichel
Palmer, Alaska
1 Tim 6:11-12 "FIGHT the GOOD Fight"
funinak@mtaonline.net
PLATED 88 XR600R & 92 FATBOY (in rebuild status)
Alaskajeff is online now   Reply With Quote
Old 11-18-2012, 12:50 AM   #6225
lookfar
from the land of OZ
Oddometer: 253
Hi everyone,
Cheers,
John
Very nice John,
Whereabouts in QLD are you?
Stu in FNQ
1985 XL600R
1988 XR600
Times are GMT -7.   It's 05:07 PM.
