Old 12-26-2012, 05:56 AM   #6511
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
Big announcement
Too all my 600 pals...
The Great Moderators in the sky have granted me my Christmas wish.
I have now taken my chosen handle for which I am known on all other boards.
You can look for me here, and on the trail as 2manyrides...
I am no longer over the top with 20 too many, just generaly excessive and unaccountable with TOO.
Now, being that I have the acerbis tank with removeable name plates I shall create a proper insert to replace the original.
(acrylic? wood?...stand by)
None of this taky tape job which I used to identify my self during the 40+ rider assualt on tahoe for which the plated 600 was created.
And now celebrate with me, relive the elustrious lake tahoe event....(if you must)
http://www.youtube.com/watch?v=hNvKPDOuAkM AOT 1
http://www.youtube.com/watch?v=ixN0mcaaSv0 AOT 2
Name plate change coming soon to a trail near the creek.
Of course, it's a bit of a mute point since the bags cover it up...
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 12-26-2012, 06:11 AM   #6512
brucifer
brucifer's Avatar
Oddometer: 2,483
Well, congratulations 2 many! That's the first thing I noticed when eyeballing the latest posts--you were missing a 2.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 12-26-2012, 06:41 AM   #6513
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
Thank you, thank you...
Better than a missing 2ooth.
too many...
Old 12-26-2012, 08:00 AM   #6514
Krono
Speed Junkie
Oddometer: 193
Hi !
Don't know if it's posted in the appropried tread, whatever ..
Im about to bid on a used XR600R / 03.1994 / 12'500 km
No pics of the bike but this comment : "Bike dosen't run - carburation issue : stalls at high RPM"
I'm interested to buy it, but cheap , and ... if it's not a big deal to fix it.
I have all basic tools and average mecanic knowlege, but dont know this bike at all
Can you comment about the mentionned problem, if you have any idea about it ? Maybe fuel filter, jets, stator ... ?
Thank's
SM510R
Krono screwed with this post 12-26-2012 at 10:28 AM
Krono is offline   Reply With Quote
Old 12-26-2012, 10:30 AM   #6515
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
Simplest thing, which at prolly aint, would be a clogged air vent for the gas tank.
I think other's might want to know what year it is and any mods done.
too many...
Old 12-26-2012, 11:35 AM   #6516
Krono
Speed Junkie
Oddometer: 193
Thank's for your answer !
I suspect also a little of issue like that :)
About specs and mods, the only infos i have are these
http://auto.fr.ricardo.ch/acheter/ve...w/an698436776/
One of this kind, but with dot tires (I suppose)
http://www.anibis.ch/fr/moto,v%c3%a9...lf=True&scid=0
Note : 1$ is more or less 1 swiss franc
L
SM510R
Krono screwed with this post 12-26-2012 at 11:47 AM Reason: add note
Old 12-26-2012, 11:48 AM   #6517
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by Krono View Post
Hi !
Thank's
why no pics? I would be very wary of that...unless you get a bike for like $200 thats a big gamble
your issues might be from among other things:
ignition related(shorted wires, fault stator, bad cdi, coil or any combination of these items) price to repair ranges from simply changing a sparkplug to 2-300 hundred dollars for a new stator and or cdi or coil.
carb simple, get a complete gasket kit and repair kit for about $70 for both kits and you will resolve issues related to sputtering, overflowing gas, leaks, stumbles, bad jetting etc...
but the commnt says does not run, then quits at high idle...so which is it? will it not start or will it die after starting and running at high rpms?
if it dies at high rpms it might be as simple as bad float level and it runs out of gas
if it doesnt start then the above solutions issues might be your problems
this is with no engine teardown...if it is engine related then you are looking at more $$$$ to fix up
cheers
elsalvadorklr is offline   Reply With Quote
Old 12-26-2012, 12:04 PM   #6518
Krono
Speed Junkie
Oddometer: 193
Exactly my point of view : a gamble ... that why im asking
I will ask the seller if it starts
12'500 km is low mileage. Anyway 500$ will be my upper limit, even in case of positive advise here
Thx for your comments
L
SM510R
Old 12-27-2012, 06:28 AM   #6519
Krono
Speed Junkie
Oddometer: 193
As the seller is almost a neighborg, i could see the bike and get some infos
He already changed the stator and cleaned the carb .. then gave up.
The bike starts, but stalls on throttle open. That could be resolved, i suppose.
Beside this, she's not been runned for 10 years, all the plastics are cracky.
Ad minima, she needs a complete stripping, frame paint, plastics changing.
I took few pics
The seller gives also a 20 liters tank with
My bid on it would not be more than 400$, i guess
What you guys think about it ?
L
SM510R
Old 12-27-2012, 06:53 AM   #6520
wazz
Oddometer: 28
Just picked up a basket-case XR600R, needs a full rebuild from the ground up, but otherwise complete.
EXCEPT (always a catch....)...it needs a head.
Is there a good supplier or rebuilder for XR heads ? This is the early model with two carbs, will other model or later heads work ?
Second issue will be to get a street title in Indiana.....
-greg
wazz is offline   Reply With Quote
Old 12-27-2012, 08:24 AM   #6521
elsalvadorklr
southern xr rider
Oddometer: 4,154
I took few pics
L
not a bad deal at all now...new stator means you got that off the list..it starts but dies thats all carb...clean and boil the carb, new gaskets and jet correctly and you are good to go...
you can do a complete rebuild do a complete rebuild in a few months and ride as is for the moment after cleaning the carb or do a little at a time, your choice
since the bike sat for 10 years you have your answer...new oil and filter, new gas and a carb cleaning and you are in business
I would say that the seller will not accept 400 for the bike...jajajaj
ps...the seller probably put the carb together wrong after cleaning it and gave up...I wouldnt be surprised if he messed up installing the floats upside down or missing a part...it could be as simple as that
I would take the gamble!
Old 12-27-2012, 08:52 AM   #6522
Krono
Speed Junkie
Oddometer: 193
Thanks for your help here Elsalvadorklr !
As this is an auction, I'll place a bid accordingly in the last minute, if its not already higher.
L
SM510R
Old 12-27-2012, 09:24 AM   #6523
bokkom
Oddometer: 100
To Krono
If you can verify the mileage, I think it might be worth it.
What bothers me from what I can see in the photo's is that there are pillion pegs fitted, our XR's was never designed to carry a pillion, unless you upgrade the rear shock. Also, the front headlight looks like it might be from an XL600R or a XR650L. Check the wattage of the headlight, the standard stator is not happy with much more than 35W IIRC. (Mine is an Australian model)
I bought my 1998 XR600R 2 years ago at 13000km's, and the plastics were like new. For that matter, the bike was like new, I have not needed to do anything to mine except service items, chains and sprockets and several rear tyres in 18000km's.
Good Luck!
bokkom is offline   Reply With Quote
Old 12-27-2012, 09:30 AM   #6524
elsalvadorklr
southern xr rider
Oddometer: 4,154
some euro countries have them stock...or as an add on stock...
look at the headlight shroud too...stock for those models...
aussies came with a dc converted dualsport kit, huge restrictor plate..etc...
in guatemala the xr600 and xr650r came plated and dualsported off the showroom floor...blinkers gauges and all
just sayin
christian
Old 12-27-2012, 09:52 AM   #6525
bokkom
Oddometer: 100
Times are GMT -7.   It's 06:22 PM.
