Old 01-08-2013, 04:53 AM   #6571
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by hiauthority View Post
1996 XR 600R - USD Fork conversion, Pro Tapers, Pro Circuit exhaust, titled and tagged in Florida. Excellent running and looking.
I got a hundred right here for ya...
MentalGuru is offline   Reply With Quote
Old 01-08-2013, 06:12 AM   #6572
Dual Sport Armory
Dual Sport Armory's Avatar
Oddometer: 211
Originally Posted by elsalvadorklr View Post
damn! impressive, what races? any pics?
Not only is he a great Mechanic but he can ride the wheels off one if he chose to.
Dual Sport Armory is offline   Reply With Quote
Old 01-08-2013, 08:40 AM   #6573
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by MCCOYBOY View Post
Next is the rear shock. I believe a stiffer rear spring will fix most of my problem and I'll find out whenever it gets here. The front felt like a chopper in some sections but like I said I'm on the stock 10kg/mm spring with crf450x forks with .48kg/mm springs so I'm not very well balanced yet.
Sorry for the long post. Ultimately the big XR kicked ass and too me to 18th overall out of 180 riders and Thad Duvall took the overall.
For the shock install a revalved and resprung(if you need it) XRL shock
XRL shocks have bigger pistons slightly than xrr shocks...they also come woth a tad hogher spring rate cause of the extra heft of the xrl weight...also by revalving it for racing or aggressive riding like I did, it eliminates the bad shimming that xrl shocks have from the factory, they have too many compression and rebound shims making flow bad...
in any case the revalved XRL shock on my 1988 xr6 works awesome in fact it made more of a difference than USD fors upfront because of the traction and control improvements...
night and day
cheers
I have pics if you want...
christian
elsalvadorklr is offline   Reply With Quote
Old 01-08-2013, 01:48 PM   #6574
duxrneet
duxrneet's Avatar
Oddometer: 670
Originally Posted by Dino3310 View Post
cheers mate, i got one of those at work....
local bike shop found a couple of second hand ones in a box out back of the shop
might have to wait a couple of months till i catch up with the over spending at Xmas so lucky for me he's putting one aside till then
The hard part is getting an airbox adaptor set up. I had to make my own. Also, I got a set of crf throttle cables and throttle. Makes install a load easier.
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 01-08-2013, 02:49 PM   #6575
nikolic
Oddometer: 479
Just in
took the old girl appart, pics soon ;)
Home rides ;)
nikolic is offline   Reply With Quote
Old 01-08-2013, 04:49 PM   #6576
Royal Club
Royal Club's Avatar
Oddometer: 392
Other than wheel axle diameter, how does the newer type XR (cartridge? ) fork compare to the old type?
does the newer type have any tuning abilities? My old type fork only has bleeders on top..
Royal Club is offline   Reply With Quote
Old 01-08-2013, 04:52 PM   #6577
mcma111
mcma111's Avatar
Oddometer: 11,902
Paging Christian to the white courtesy phone.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-08-2013, 10:09 PM   #6578
error cooled
anything but asphalt
error cooled's Avatar
Oddometer: 1,169
AWESOME!
Honda XR600R
The Blue Ridge Trail - Virginia via gravel, dirt, two track and backroads.
USFS Motorized Access in Virginia - Protect your dual sporting access in the commonwealth.
error cooled is offline   Reply With Quote
Old 01-08-2013, 11:39 PM   #6579
T4EaterJonny
Not too hip...
T4EaterJonny's Avatar
Oddometer: 64
HAY YOU GUISE!!! I want to regear to 15t 45t. The bike is plated. What brand of Drive sprockets and rear sprockets do you guys prefer? I read somewhere in past threads that some chew up the splines or something. Do you know how long the chain has to be with these gears? You think 15/45 is tall enough for the highway? Tell me what to buy. .
1994 XR600R - Plated. Kenda trackmaster rear, Maxxis front, geared 15/43. I'm a street rider- help me learn! Hopefully soon a speedometer and a big ol'e gas tank.
T4EaterJonny is offline   Reply With Quote
Old 01-09-2013, 01:33 AM   #6580
Dino3310
Oddometer: 673
i use OEM on the front sprocket and JT on the rear
Dino3310 is offline   Reply With Quote
Old 01-09-2013, 10:43 AM   #6581
elsalvadorklr
southern xr rider
Oddometer: 4,154
yes? how can I help?
what is the nature of this call kind sirs?
Old 01-09-2013, 10:51 AM   #6582
elsalvadorklr
southern xr rider
Oddometer: 4,154
old style vs. new style forks!
aja!
read my thread bud!
basucally you have the old style which is damper rod only, and can only be adjusted for compression on the bottom...it works fine
newer style cartridge again has bottom compression adjustemnt only however the damping style has a cartridge "ROD" however its a very basic shimless type pretty much where the rod goes into a valve on the bottom with different sized holes that can be "revalved"
the only discernable and quite pleasing attribute the newer style forks have against the old style forks is that of withstandind SHARP EDGED HITS better...this because the cartridge rod does a better job of bleeding off oil pressure than the damper rod on the 90 and lower year forks
so in other words there is no physical benefit other that that of better valving action at speed against for example sharp rocks...
with a brace and respring and playing around with oil weights I got my cartridge forks to work pretty damn well, really good actually, what I still hated was that every crash or tipover the damn forks still twsited and bent like spaghuetti even with the fork brace, and that made me even more mad as after a crash with the brace unless you loosened everythying up you now had fork BINDING
very bad!
thats my cents
lastly the bleeders are just that...play with fork springs and weights equally with the two styles, also the compression screws on the bottom work quite well...especially if you have the cotrrect weight oil in there...5w for new style 10w for old style...dexron 6 atf works the best for fork oil
Old 01-09-2013, 10:51 AM   #6583
mcma111
mcma111's Avatar
Oddometer: 11,902
Royal Cub's post up the page some ^^
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-09-2013, 10:55 AM   #6584
elsalvadorklr
southern xr rider
Oddometer: 4,154
smart man my friend
oem is the only way to go upfront...in the rear whatever...
the xr6 does not suffer as much from the shaft stripping common to xr650ls(weight and street use is what damages them vs dirt only xr6 riding)...however having said this using non brand front sprockets that are HARDENED and have a thinner shaft spline area is what damages otherwise good condition countershafts
Old 01-09-2013, 10:56 AM   #6585
elsalvadorklr
southern xr rider
Oddometer: 4,154
DONE!
next!!!!!!!!!!!!!!!!!!!!!!!!!!!
jajaja kidding
im a bit sick
and bored
Times are GMT -7.   It's 02:46 PM.
