Old 01-09-2013, 09:56 AM   #6586
elsalvadorklr
Oddometer: 3,955
Originally Posted by mcma111 View Post
Royal Cub's post up the page some ^^
DONE!
next!!!!!!!!!!!!!!!!!!!!!!!!!!!
jajaja kidding
im a bit sick
and bored
elsalvadorklr is online now   Reply With Quote
Old 01-09-2013, 10:43 AM   #6587
The Shred
Airventurer
The Shred's Avatar
Oddometer: 392
I'm finally getting a rod for my 93. The machinest is a HotRods dealer but said I could bring him any rod I wanted.
Is the ProX better?
The Shred is offline   Reply With Quote
Old 01-09-2013, 10:51 AM   #6588
mcma111
mcma111's Avatar
Oddometer: 7,965
Is the ProX better?
I have used the Pro-X rods on a few rebuilds. I don't care for the Hot Rod products.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-09-2013, 07:56 PM   #6589
T4EaterJonny
Not too hip...
T4EaterJonny's Avatar
Oddometer: 27
So absolutely none of the 15t sprockets are made as thick as the oem one? So you think i should just stay OEM and throw like a 40T in the back for my dualsport? My drive sprocket doesn't look very worn at all, neither does the chain or stock rear sprocket. Should I just be cheap and get the rear sprocket and rock it?
1994 XR600R - Plated
2007 Yami R6
and a turbo neon and turbo Furd.
T4EaterJonny screwed with this post 01-09-2013 at 09:14 PM
T4EaterJonny is offline   Reply With Quote
Old 01-10-2013, 04:37 AM   #6590
Royal Club
Royal Club's Avatar
Oddometer: 293
Originally Posted by elsalvadorklr View Post
aja!
read my thread bud!
basucally you have the old style which is damper rod only, and can only be adjusted for compression on the bottom...it works fine
newer style cartridge again has bottom compression adjustemnt only however the damping style has a cartridge "ROD" however its a very basic shimless type pretty much where the rod goes into a valve on the bottom with different sized holes that can be "revalved"
the only discernable and quite pleasing attribute the newer style forks have against the old style forks is that of withstandind SHARP EDGED HITS better...this because the cartridge rod does a better job of bleeding off oil pressure than the damper rod on the 90 and lower year forks
so in other words there is no physical benefit other that that of better valving action at speed against for example sharp rocks...
with a brace and respring and playing around with oil weights I got my cartridge forks to work pretty damn well, really good actually, what I still hated was that every crash or tipover the damn forks still twsited and bent like spaghuetti even with the fork brace, and that made me even more mad as after a crash with the brace unless you loosened everythying up you now had fork BINDING
very bad!
thats my cents
lastly the bleeders are just that...play with fork springs and weights equally with the two styles, also the compression screws on the bottom work quite well...especially if you have the cotrrect weight oil in there...5w for new style 10w for old style...dexron 6 atf works the best for fork oil
Too much hassle for me. I think I'll just build an CRF fork in my XR and then take it to Hyperpro and let them set it for supermoto use. Thanks a BUNCH broski.. Gonna save your reply for later reference!
Royal Club is online now   Reply With Quote
Old 01-10-2013, 04:44 AM   #6591
duxrneet
duxrneet's Avatar
Oddometer: 591
Naw, the moose sprockets for the xr650 fit and are non hardened. They are much wider than stock.
"Pay no attention to that man behind the curtain!"
Current: 1987 CBR600, 1995 XR600R - Past: 1993 DR350 (Dirt Model)
duxrneet is offline   Reply With Quote
Old 01-10-2013, 08:27 AM   #6592
elsalvadorklr
Oddometer: 3,955
^^^^tis true...you can do that if yo have a 91 and up xr6, same shaft as the xrls.
Old 01-13-2013, 12:37 PM   #6593
booniebasher
booniebasher's Avatar
Oddometer: 212
stiffer springs ?
i have a 98 xr600, stock springs, i need to go stiffer cause it is being used as a loaded up dual sport, can anyone tell me what shocks and forks cross reference with the xr6 so i can mayby save some money on ebay etc ???
booniebasher is offline   Reply With Quote
Old 01-13-2013, 02:18 PM   #6594
elsalvadorklr
Oddometer: 3,955
the cheapest way to stiffen up the xr is to buy XRL springs...they are .44kg instead of .41 on the xr
that or cut 2 inches off the stock springs and add a 2 and 1/2 spacer on top...thats enough preload and stiffening for most under 200lb riders or semi loaded
I did it on my xr6 before swapping over to usds and and xrl shock
on the rear if you have a 91 and up shock...you can put the xrl spring which is 10.5 versus 10 or 9.5 for the xr6 I cant remember
Im running a revalved xrl shock on my 88 xr6, the improvement is beyind simple words...
christian
Old 01-14-2013, 10:12 AM   #6595
elsalvadorklr
Oddometer: 3,955
hey Im installing a donated clutch pack...and I forgot which way the numbers go on the actual disks...
My oem disks show no numbers but do have that semicircle
Im using a donated xrl clutch pack and they have numbers too...as well as full sem circle cutouts...
Im brain farting here...
to notice is that my old springs are not sagged...they are exactly the same hieght as the new ones(ebc) however the olds disks look a little thiiner and dark...also the metal plates were slightly grooved or polished looking...
I also took the time to smooth out some nothces I didnt get rid of the first rebuild...both on the inner and outer basket
please help me remember!
thanks
christian
Old 01-14-2013, 10:56 AM   #6596
nikolic
Oddometer: 413
Tried washing my plstics but couldn't wash them, they looked like s*it. But just found the way to make then new-like:
Scrubed them with dish-wash abrasive detergent and a dish sponge!
Home rides ;)
nikolic is offline   Reply With Quote
Old 01-14-2013, 07:19 PM   #6597
elsalvadorklr
Oddometer: 3,955
nice nikolic
now anybody experience a grabby clutch after install??????????????
I seem to have my power back or new if you say, damn bike explodes now off idle
but the clutch is very grabby and jerky...hmmm
not enoough oil to coat it all yet?
thanks
Old 01-14-2013, 08:41 PM   #6598
mcma111
mcma111's Avatar
Oddometer: 7,965
Did you soak the plates prior to installation?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-14-2013, 08:58 PM   #6599
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 502
Christian, are you still using the ZDDP in your oil?
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S
1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 01-15-2013, 05:02 AM   #6600
Royal Club
Royal Club's Avatar
Oddometer: 293
He guys, me and a friend have set up a facebook page called endurofools, with the intention of creating original content from offroad/singletrack/enduro video's asap, but for the time being we need some picture material to gain audience.. Would anyone of you like to have their picture on our wall?? If preferred with photographer name and rider name added under the picture!
http://www.facebook.com/Endurofools
The page is by the same people who created this content
http://www.facebook.com/Supermofools
Times are GMT -7.   It's 01:14 PM.
