Old 01-23-2013, 01:28 PM   #6661
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,641
Originally Posted by JAB View Post
Please take this in the spirit intended, but the quieter our bikes are the better it is for all of us. Most folks in town can't tell the difference between a Harley with open pipes vs. Dual Sport without an insert. They just hear a noisy moto. You should be able to look up the test info to see how you are doing. Some riders have also added a turn down on the pipe to bounce the sound off of the ground first to help dampen some of the noise. The exhaust sound from a big 4 stroke will also carry farther than a 2 smoker for example.
I am sure my SuperTrapp is not the quietest pipe option, but I keep the packing fresh and have played with the disks and found the compromise between quiet and performance I can live with. Like to know how that app works.
That's essentially what I'm trying to do. I want decent performance, but not overly loud. The factory insert, even after modifying it a little was very restrictive. I'm happy with the performance of it without the insert, but it's a bit loud. I have a friend of mine welding up a turn-down for it right now which should help a little, but if I need it quieter than that I'll make a custom insert (like the old re-packable Thumper Racing inserts).
If I had an extra $300 I'd throw down for an FMF Q4, but I don't have the money. When I got the bike it had a god-awful loud old Supertrapp IDS that fell apart in multiple pieces when I tried to repack it. Picked up the 600R muffler for $30 shipped to replace it.
Evan
2013 Husqvarna Strada
'93 XR650L (Gone, but missed)
Ooh-Rah! Once a Marine, always a Marine!
Originally Posted by kenny61 View Post
figures...my stud was rusty I played with my nuts a little and it cranked right over
Mossy-Back is offline   Reply With Quote
Old 01-23-2013, 02:04 PM   #6662
elsalvadorklr
southern xr rider
Oddometer: 4,154
nice
I would try to have a muffler shop make you a pointed down tip like the xrsonly one back in the day...
I did this for my stock klr650 muffler which was stainless btw...so I tig welded a stainless 2 1/4inch tip...it quited down beleive it or not and flowed better...not only that but my headers stopped glowing! jajjaja
elsalvadorklr is offline   Reply With Quote
Old 01-23-2013, 02:04 PM   #6663
rogervize
rogervize's Avatar
Oddometer: 75
I used 638 retaining compound. This was on a smooth shaft rather than a spline but if the male and female splines are not too worn I guess it would help. If the teflon tape is taking up space from worn parts, that might be a different story. Could it be the shaft splines are harder than the lever causing the lever splines to wear out and fit poorly?
I have used standard type loctite with success. It is basically doing the same as what it does for threads.
Great for worn splines etc... fills all the gaps and stops any movement. It is the movement which causes the wear.
Also I find the metal surfaces seem to be protected from rust. JFYI
And Christian.... doing fine tnx same back
Melbourne OZ..'92 XR600R '74 Yam TY250
rogervize is offline   Reply With Quote
Old 01-23-2013, 02:19 PM   #6664
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,641
Originally Posted by elsalvadorklr View Post
nice
It would be pretty easy for me to fab up an insert like this one that Thumper Racing used to make.
For now I'll try just the turndown. If it's still too loud for my taste, I'll stick a re-packable baffle onto it like in the picture.
Evan
Old 01-23-2013, 02:43 PM   #6665
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,270
^^That's cool! I've tried to picture a turn down for the SuperTrapp, but it would be like hanging a mailbox off the pipe.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 01-23-2013, 02:49 PM   #6666
Royal Club
Royal Club's Avatar
Oddometer: 392
did some work on the XR today,
Filled up with oil, kicked it over so the oilpump would move out the air.
set the valve lashes (0.15mm/0.20mm Hotcam..)
Mounted the FCR, with some swearing and cutting the adapter I need... :)
Fiddled with mounting the airbox so it wouldnt hit or barely hit the shock (single carb airbox/twincarb frame)
removed a piece of fender bracket under the rear fender which didnt support anything.
and tried on a CRF silencer to see if it would look good..
And of course one of my friends felt the need to set it on fire.
anddddddddddddddd
*drums*
Put the worlds most badass valvecaps on the wheels...
Royal Club screwed with this post 01-24-2013 at 04:05 AM
Royal Club is offline   Reply With Quote
Old 01-23-2013, 02:54 PM   #6667
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,641
What model CRF is that silencer off of? And how does it sound?
Evan
Old 01-23-2013, 03:07 PM   #6668
Royal Club
Royal Club's Avatar
Oddometer: 392
Not sure, crf450, think 2003-ish
Not sure how it sounds too
Old 01-23-2013, 03:26 PM   #6669
Royal Club
Royal Club's Avatar
Oddometer: 392
http://www.youtube.com/watch?v=LopmJ5IFTpk
liek dis..
pretty loud is my gues
Old 01-23-2013, 04:24 PM   #6670
elsalvadorklr
southern xr rider
Oddometer: 4,154
so it didnt get on fire from reeving it at idle
Old 01-23-2013, 04:25 PM   #6671
Royal Club
Royal Club's Avatar
Oddometer: 392
Doesn't run yet
Need a fuelline and the carburettor vent hoses are missing
Old 01-23-2013, 04:49 PM   #6672
elsalvadorklr
southern xr rider
Oddometer: 4,154
so he lit it on fire as a ceremonial initiation ritual to the gods or something? I guess that doesnt happen around here much
I do however see idiots revving the hell out of bikes on the stand like its and old honda total loss system that need to be revved constantly
jejejeje
cheers post a vid when you get it going bro!
Old 01-23-2013, 05:34 PM   #6673
Royal Club
Royal Club's Avatar
Oddometer: 392
jejejeje
Nothing ceremonial. friends and me included just want to set fire to everything they see. The 'hairs' on a new tire? Most of them are gone..
box in which I carried my engine to a friends shop?
gone..
XR engine not co-operating?
dynoing a drz? flame it!
and much more..
Old 01-24-2013, 09:57 AM   #6674
Royal Club
Royal Club's Avatar
Oddometer: 392
Found the carby venthoses!!11!!1!!! yeah!!
Did swap a few with the original XR carby hoses, FCR's were too short on 2 or 3 spots.
Mounted the header, need to take it off once to put some heatwrap near the carb, its sitting a bit close. to the accelerator pump housing..
Cut a new piece of fuel hose, the FCR sits a bit farther away from the fueltap compared to the original dual carbs, note that the fueltap has a 6mm outlet and the FCR has a 8mm inlet.. needed some eh.. 'help' from mister lighter and some lube to slide it over.
pics inbound, will try and fire it up after dinner. Mom wanted me to come over so I have to leave the garage for once
some random pics, as seen, the twin/single carb swap is tight.
Old 01-24-2013, 11:20 AM   #6675
elsalvadorklr
southern xr rider
Oddometer: 4,154
royal kudos on the good work
Id be interested in a few things you are doing
1. a pic of the heat shield wrap you plan on using and how you did it, or what wrap you end up using.
2. Im interested in knowing what adapters you made used for the intake boot and or airbox boot in order to fit the quite big fcr.
lastly are you planning on dynoing the bike? do you have one near you? Id love to see what you end up with...
or maybe just an a/f measurement?
thanks
good work!
Times are GMT -7.   It's 08:33 PM.
