Old 01-24-2013, 02:03 PM   #6676
elsalvadorklr
southern xr rider
Oddometer: 4,154
lets get this thread rolling
In the interest of saving money nowadays and having parts that I cant use etc...for some reason or not here is my next question
long time ago I bought a jt48 tooth rear sprocket...I wanted to have a middle between my 50 tooth and 45 tooth rear.
Problem is they sent me a wrong model sprocket used on standard disc hubs which have a smaller circumference where the sprocket attaches to
so mu question is do you think a hogh quality machine shop would have the ability to BORE the smaller sprocket to a correct size using one of my correct sprockets as a GUIDE?
the reason I ask is I wouldnt mind using a newer chain I have as my current one is on its last legs
and please people dont say buy a whole new set of sprockets and chains...mk?
Ive been doing my chain and sprocket swaps with standard roller chains forever now and suffer NOT from any adverse wear...
not to mention trying to sell off stuff here is as hard as can be
thanks
elsalvadorklr is offline   Reply With Quote
Old 01-24-2013, 02:31 PM   #6677
mcma111
mcma111's Avatar
Oddometer: 11,881
Christian,
Next time you come up this way bring me the 48' sprocket.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-24-2013, 03:38 PM   #6678
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by elsalvadorklr View Post
royal kudos on the good work
Id be interested in a few things you are doing
1. a pic of the heat shield wrap you plan on using and how you did it, or what wrap you end up using.
2. Im interested in knowing what adapters you made used for the intake boot and or airbox boot in order to fit the quite big fcr.
lastly are you planning on dynoing the bike? do you have one near you? Id love to see what you end up with...
or maybe just an a/f measurement?
thanks
good work!
1: its just plain old glassfiber heatwrap you see used in car engine bays. and on bobbers and the likes..
2. I bought the FCR/head/etc from the person who made it to fit, as far as I can see its an STOCK intake manifold for the carb, and a silicone piece which goes around the carb on the filterbox side, this silicone piece holds a steel pipe which then inserts into the original airbox pipe..
I WILL be dynoing the bike and I'll film it. Don't expect wonders, the piston is not new, just new rings.
The old pig fired, FIRST KICK!
Royal Club is offline   Reply With Quote
Old 01-24-2013, 07:48 PM   #6679
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by mcma111 View Post
Christian,
how about anna takes it up when she comes down with all your cam stuff?
I kind of wanted it to work out but probably not worth it...
both my 50 and 45 sprockets are still good
anyways
Old 01-26-2013, 08:13 AM   #6680
The Dogger
Oddometer: 135
Hi Royal Club
Does your FCR have a metal locator tab that the manifold fits into? Same side as the choke etc ?
I'm interested to see how you get on with this , I've just bought one
What's happened to your fuel tank ? One of your mates set it on fire ?
I have one on ebay if you need one ??
http://www.ebay.co.uk/itm/XR-600-R-X...item337f7ba0d8
Cheers
The Dogger is offline   Reply With Quote
Old 01-26-2013, 08:34 AM   #6681
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by The Dogger View Post
Hi Royal Club
Cheers
Having a bit trouble understanding the highlighted part.. Maybe you could take a picture of what you mean?
I have two fuel tanks, one ugly one, one 'o.k.' one.. (well actually they both are fugly.) but BOTH had the Oring dried out that sits between the tank and faucet (whats the proper word for the on/off/reserve thingy?)
I've been soaking the orings in gasoline since yesterday.
Old 01-26-2013, 08:46 AM   #6682
Royal Club
Royal Club's Avatar
Oddometer: 392
Oh, I think I understand what you mean, like a locator that meets with a locator on the intake manifold, to align the carburettor in the right position? Yeah I think it has that, but the manifold side has been cut away since the fcr/XR dont align.
this thingy?
Royal Club screwed with this post 01-26-2013 at 08:54 AM
Old 01-26-2013, 09:13 AM   #6683
The Dogger
Oddometer: 135
this thingy?
That's it , yes. I tried mating mine together , and think I may grind that locator tab off with a dremel. Other than that , it appears to want to fit OK.................are you saying your inlet manifold is shorter than standard ?
Are you leaving the hot start on ? What have you done with the TPS ? I'm guessing just leave it alone ? I saw a blanking plate on ebay a couple of weeks ago , and now I can't find it
The "on/off/reserve thingy " is a fuel tap ( faucet is Merkinese for tap so same thing )
Cheers , Stu
The Dogger screwed with this post 01-26-2013 at 09:14 AM Reason: Smilie in wrong place
Old 01-26-2013, 09:16 AM   #6684
joexr
Oddometer: 3,773
Fuel petcock.
Old 01-26-2013, 09:20 AM   #6685
Royal Club
Royal Club's Avatar
Oddometer: 392
Cheers , Stu
I'm pretty sure the manifold is stock, could see the parts that were cut off.
Leaving the hotstart on it yeah, done a itty bit of reading on it and it says it helps starting big cc engines...
The TPS is just dangling. didnt do anything with it.
If you have not done it yet, I'd advice you to just buy an CRF450 (2005ish) throttle tube and cables assembly, XR cables can be made to fit, but requires a bit of effing around with one of the cables and the stroke on the throttle tube will be pretty long. I bought a crf throttletube/housing/cables as a set for just 25euros...
Oh, and while you are ebaying around, find a roll of heat wrap, the acceleratorpump housing sits pretty close to the header in the case of an 2in1 header, if you have the 2/2 header which mates IN the silencer you're gonna have a problem, you either have to rotate the carb and have it hold a strange angle (not even sure if the fueltank will fit in that situation) or you need to cut the upper header pipe and reweld it so it runs around the carb instead of hitting it.
Royal Club screwed with this post 01-26-2013 at 09:27 AM
Old 01-26-2013, 09:30 AM   #6686
The Dogger
Oddometer: 135
Well the good news is , the carb came attached to the throttle cables and tube . Result ! 30 posted to the door
The bad news is that the grip on the tube is very badly worn , I may have to splash out on a new one [ sits down in darkened room hyper ventilating at the thought of such a rash move ]
Cheers , Stu
Old 01-26-2013, 09:31 AM   #6687
Royal Club
Royal Club's Avatar
Oddometer: 392
Cheers , Stu
nuoh my gawd.. You got a fcr for 30quid posted?
Old 01-26-2013, 10:26 AM   #6688
The Dogger
Oddometer: 135
Yep , a bit grubby , but I can live with that
Not sure if you can see the link still ?
http://www.ebay.co.uk/itm/2810448777...84.m1497.l2649
Old 01-26-2013, 10:50 AM   #6689
Royal Club
Royal Club's Avatar
Oddometer: 392
hot damn.. I payed 190euros...
Old 01-28-2013, 12:40 PM   #6690
Royal Club
Royal Club's Avatar
Oddometer: 392
yeaaaah
Times are GMT -7.   It's 02:43 AM.
