Old 01-28-2013, 02:19 PM   #6691
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
Seeking the trick
2:19 pm monday choke blues
Hey!
I need some help...
Steve? anybody.
1992 600r carb...
So it was like no choke after the XR's only plate conversion...
Finaly decided that wont do. Took of the carb and I could see the spring wasn't bringing the choke into action. Disengauged spring or binding plate...
Anyway, now I need the trick on how to re-engauge the little spring.
See pic...
After getting the screws and plate off you can turn the shaft around when the choke lever is clear, but I wasn't gripping anything. So in working that back and forth I pulled the shaft back too to look in there. I guess there's a flat spot, but I can't get it to engauge.
I'm off to the store to look for replacement screws cause I had to do surgery to get one of them out. I'll be checking the site soon as I get back...
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 01-28-2013, 02:48 PM   #6692
mcma111
mcma111's Avatar
Oddometer: 12,286
Sorry John. My XR still has the OE choke on it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-28-2013, 03:09 PM   #6693
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
Yes I know that, but thought you mught have fiddled with one of these...
Christian does a lot of fiddling...
How 'bout it Christian? Are you out there? Got the trick?
Back from the hardware and got 3mmx6mm stainless allen screws. They look just like the ones XR's only supplies.
Upon removal I had one allen strip and had to hacksaw a slot in the bugger. Man am I glad I got it out cause the slot was even giving way!
Loctite was doing it's job.
The original phillips screws are mulled over to prevent accidental falling out. They had to be ground up on their threaded ends prior to unscrewing, so I wasn't gonna try to use them over.
But hey, Is this the spring people have talked about that they wish they hadn't undone it when they were doing carb work? If so...I need the trick!
There's that plugged off area on the outside of the carb. If ya gotta get in there how do you do that?
I await your answer!
2many
too many...
Old 01-28-2013, 03:24 PM   #6694
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
XR's only says to pop the cap off from inside where the shaft was, reset the spring giving it one turn of preload, and reinstall the cap...
I'm heading for the garage to give it a try...
too many...
Old 01-28-2013, 03:31 PM   #6695
elsalvadorklr
southern xr rider
Oddometer: 4,154
hey bud, my oe carb has a homemade plate on there...it looks like they did a good job except for the fact that they did not drill any backfire holes in it...
BUT like your post above thats what I read too...just like the return spring on the pulley arm you got to wind it, keep it in place while inserting the shaft...
I THINK? ajjajaja
good luck!
christian
elsalvadorklr is offline   Reply With Quote
Old 01-28-2013, 06:25 PM   #6696
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
Houston, we have a choke
OK, seems to choke good now. I was getting no choke and that was a BIG pain!
The spring has a tang bent over to ride the flat on the shaft, but it leaves too much room to jump the flat at 1 full turn. I think the normal must be a 1/2 turn in the spring.
I had some other issues going on too. While the thing was on the bench with choke off the lever could bypass the stopper on the arm and unwind. That was a combo of worn plastic lever, loose holdown screw for the indent and I tweaked the indent a bit to keep things in place better. Hadn't ridden it in a month or so. After reinstall I got it started on the 4th kick. But I could tell it was gonna be good to go on the 2nd.
I entered today's arena prepaired to put the original plate back on, but once I saw it wasn't actuating I looked into the problem. Should be good to go on the next ride. Did a jaunt including freeway and yep she's wanting to do some dualsport again!
too many...
Old 01-29-2013, 09:46 AM   #6697
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 644
Royal Club,
Nice bike. I used to have an 87 here in the states. Still wish I had it.
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 01-29-2013, 09:54 AM   #6698
Royal Club
Royal Club's Avatar
Oddometer: 392
Thanks mrfixit! When I got mine it was a piece of trash..
Did a little fine-tuuuuuuuuning on the mixture/CO screw on the FCR. The XR takes quite a while to heat up properly, but now when its warmed up it picks up pretty good allready and drops back to idle pretty fine. Now we wait for the dyno run and see some figures
Royal Club is offline   Reply With Quote
Old 01-29-2013, 11:49 AM   #6699
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by mrfixit54016 View Post
Royal Club,
Thats what I want for my next XR...
xladv.com
MentalGuru is offline   Reply With Quote
Old 01-29-2013, 12:46 PM   #6700
mrfixit54016
Oddometer: 644
My current 1985 XR was a bit-o-trash when I got it too:
But later she looks like a new bike:
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
Old 01-29-2013, 01:13 PM   #6701
Royal Club
Royal Club's Avatar
Oddometer: 392
Got mine in same ish state..
pic does make it look better than it actually is lol.
Old 01-30-2013, 04:39 PM   #6702
elsalvadorklr
southern xr rider
Oddometer: 4,154
ebay tm38 flatslide blowout!
Hey dudes since Im a convert I just wanted to let you guys know that they are selling the exact same carb I have and that xrsonly sells at a nice profit in ebay at a very special price of $157!
here they are:
http://www.ebay.com/itm/Mikuni-TM38-...item231583a762
the only difference is that it does not come with the intake adapter...but thats pretty much a sleeve they put on...so you could have one made or get one.
comes with the exact same jets and needle and needle jet the xrsonly comes with except that Im not 100 percent sure on wether its bored out, Im not sure mine is either but at this price it be nice to play around with...
Its no fcr41! pumper but its halfway between the oem carb and a pumper...
my performance is pretty damn good now, and you get the benefits of a dual float system that makes stalling and deflooding much easier, etc...
just thought Id put the word out dudes!
christian
Old 01-31-2013, 09:29 AM   #6703
Royal Club
Royal Club's Avatar
Oddometer: 392
here they are:
christian
Aint that a 2stroke carburettor?
Old 01-31-2013, 10:44 AM   #6704
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
did some work on the XR today,
Royal,
Which handle bars & what bend do you have on the bike?
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 01-31-2013, 12:07 PM   #6705
elsalvadorklr
southern xr rider
Oddometer: 4,154
yes
but if you read a bit youll find out it was used a lot on many fourstrokes...ballards WON like 6 asutralian safaris on a slightly modded tm38 flatslide...on his xr600
PS. Xrsonly sells a kit for our bikes NEW for only $260, comes bored, with jets, throttle and new cable...also the intake adapter I speak of
they are cheap because they are more simple in design, have less metal parts and initially were designed for 2 strokes, they are also on a million bikes...meaning price is lower...how many bikes can you name off hand with a 38mm keihin roundslide like our bikes have stock?
mikuni flatslides right off the bat, bmws, kawasaki triples, etc...the list is long!
even the atk605 came stock some years with a mikuni flatslide on the XR600 ENGINE...look at the complete atk thread for proof!
cheers dudes
Times are GMT -7.   It's 04:44 AM.
