Old 02-02-2013, 03:41 PM   #6721
Michel77
Oddometer: 208
Runner!
So I finally had some time to dig into the old beast over the past few weekends and got her running today! Took a quick spin, not perfect yet, but super stoked! Not sure what the problem was in the first place, checked all electrical connections and improved the ground connection, cleaned the carbs again and kicked until I nearly puked before she fired up!
Also got some more pics now that she's seen the light of day, yes I'm showing off :loll
'06 KTM 640 ADV'
Michel77 is offline   Reply With Quote
Old 02-02-2013, 11:27 PM   #6722
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 390
XR ???? at least the Engine is from a XL
But what Tires are this
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 02-03-2013, 09:26 AM   #6723
kubiak
Oddometer: 4,829
thats a good looking bike. looks mean!
Old 02-03-2013, 09:56 AM   #6724
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,652
Either shinko 244s or kenda 270s
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 02-03-2013, 12:19 PM   #6725
nikolic
Oddometer: 479
Nead some advice, I've bought a TM40 with adapters that don't fit XR. How do I take them off? Are they
glued in some way or just pushed on the carb body?
Someone has an idea why should I not make a new ones out of polypropilen?
Home rides ;)
nikolic is offline   Reply With Quote
Old 02-03-2013, 12:34 PM   #6726
Royal Club
Royal Club's Avatar
Oddometer: 392
maybe the adapters are screwed on??
Royal Club is offline   Reply With Quote
Old 02-03-2013, 03:42 PM   #6727
Schrauberklaus
***ifyer
Oddometer: 390
Or IRC GP1
guessing don't help
Klaus
Old 02-04-2013, 01:32 AM   #6728
Dino3310
Oddometer: 673
looks identicle to my shinko 244,
The street tracker looks cool
Dino3310 is offline   Reply With Quote
Old 02-04-2013, 07:11 AM   #6729
Schrauberklaus
***ifyer
Oddometer: 390
Ah ha , now we get closer
@dino 3310 , how you like the shinkos , how they perfom onroad Dry/wet , offroad?
somebody here with the kendas or the IRC
Klaus
Old 02-04-2013, 08:55 AM   #6730
Michel77
Oddometer: 208
Hey guys, sorry missed the replies.. Yes, they are Shinko 244's. Obviously not the best choice for road, but good on gravel and fire roads. Think I'll probably throw on some Twinduro's after these, they're more expensive though..
'06 KTM 640 ADV'
Old 02-04-2013, 09:05 AM   #6731
elsalvadorklr
southern xr rider
Oddometer: 4,154
yes I have the kendas 270, they are the perfect traveling or dualsport tire...they look identical to those above...they also last very long...
they do not perform well in mud obviously and hard offroad terrain, but for gravel roads, dirt roads, and street they are awesome.
cheers
expect 6k miles at least upfront and around 4-5k miles out back for dualsporting...they will last longer only on street with high pressures
elsalvadorklr is offline   Reply With Quote
Old 02-04-2013, 09:11 AM   #6732
booniebasher
booniebasher's Avatar
Oddometer: 627
Question?
98 xr6 stock motor
What oil is best and how often ?
Do I need a oil cooler ?
Thanks experts
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
booniebasher is offline   Reply With Quote
Old 02-04-2013, 09:17 AM   #6733
elsalvadorklr
southern xr rider
Oddometer: 4,154
the best oil is the one you change often
2. get an oil temp gauge and if you ever see 300f when riding your normal routine get and oil cooler or adapt one
3. the most recomended oil on this site is rotella 15-40 stuff, they also have a synthetic, but I use delo400 which is also a deisel recomended oil and the bike loves it...so does my truck. jajaja
15-40 is a good compromise for wieghts...cold climate go 10 40, really really hot like desert go 20-50...as per the manual...
if your temps never vary more than 15 degrees F. then you can actually run a straight grade oil which is the best.
in fact Im starting to use my oil from the xr in the truck to save some $$ as I change the oil in my bike every 600-800miles...
cheers
Old 02-04-2013, 10:39 AM   #6734
booniebasher
Oddometer: 627
Exlnt
Old 02-04-2013, 12:23 PM   #6735
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,655
short ones
let me share some short ones with ya...
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Times are GMT -7.   It's 01:34 AM.
