Old 02-08-2013, 06:05 PM   #6781
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by lookfar View Post
How about these??
http://www.ebay.com.au/itm/Honda-XR6...item2325b1a394
I think that the pegs themselves might be the same for all years, but the way that they mount to the frame differs.
I have an '88, and the pegs mount differently than the '87.
Yeah I meant the way of mounting..
Could you be kind to show how they differ? I want some bigger ones on my 87 XR but if the difference is marginal I might be able to adapt the 88 and up to my 87 peg,, euh.. holders?
Originally Posted by elsalvadorklr View Post
my 88´s were tiny so steve sent me some nice xrl ones...cheap upgrade
I made some stainless ones for my klr650 a while ago...nice and big!
I thought about maybe having some made and sending them around the globe to all you nice fellas! jajajaja
If you send me them for free I'll test em
Nah, id pay you, as long as you'd send them as a gift i'm good. Otherwise i'd be needing to pay customs, which is a BITCH
Royal Club is offline   Reply With Quote
Old 02-08-2013, 06:54 PM   #6782
Dino3310
Oddometer: 673
Originally Posted by Alaskajeff View Post
Roost, It's a 1.5 US Gallon (about 5.7L) container. And I used it lats season on a ride, just mounted in a different configuration with a bit more as well and it all worked out fine. I've got the shock spring cranked down about as far as it will go!
That was arriving home after 1100 miles.
amazing how much comfort a sheep skin will give,
Hey Jeff any chance of a photo from the front. Im liking the look of your screen and the hand guards(what make/model).
Dino3310 is offline   Reply With Quote
Old 02-08-2013, 07:20 PM   #6783
elsalvadorklr
southern xr rider
Oddometer: 4,154
yeah I here you about the gifts...and customs! jajaja ask steve how he sends me stuff! jajajaj
so, I will modify mine, make them in stainless and take some pictures...if you like them or anybody else does I can get a batch done and send them out...
My klr ones cost me about $45...beefy, heavy but who gives a crap...they worked...
Ill keep you guys updated
cheers
elsalvadorklr is offline   Reply With Quote
Old 02-08-2013, 07:36 PM   #6784
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,635
Originally Posted by beechum1 View Post
Was it the first goof? That used the same sprocket?
600F. Goof.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 02-09-2013, 12:05 AM   #6785
nikolic
Oddometer: 480
Originally Posted by deejay_xr View Post
Hey Nikolic,
That center cam journal doesn´t look pretty, it´s always that one that bites the dust.
How does it feel when you run your fingernail through it? Any close-up photos?
How are your rocker lobes, are they flattened out?
If you think the piston and bore are still good to go, they probably are. You can have the piston checked out and measured at a shop to be sure if you want. Not just to check the size, but also to see if the shape is still good. Sometimes after a while either the intake or exhaust side, I forget which one, can wear down and the piston loses it's shape.
If you just replace the rings you still need to break them in for a couple 100 km's
Here's the history : it's a nx650 cylinder and piston, think I'll go with the ring anyway, and see what will happen. If it consumes a lot of oil this year I plan on going to 102mm bore. Regarding the head, I saw somewhere in the tread someone grinded down that middle bearing, and after riding it this whole year, and a man riding it before me didn't do the exchange... and the cam isn't damaged... think it's OK now :) .
Home rides ;)
nikolic is offline   Reply With Quote
Old 02-09-2013, 05:13 AM   #6786
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,254
1100 miles, holy butt-numbness Batman !
You know it wasn't that bad. I've gotthe bike set up (bar risers) so I can ride standing pretty comfortably when needed. The 1100 miles was over a weekend so it was broken up fairly well. You know I've had a worse case of "Monkey Butt" riding my 92 Fatboy 300 miles
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 02-09-2013, 05:21 AM   #6787
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,254
Thanks, the screen is a cee bailys model from a XR 650, it fit pretty well on my aftermarket headlight housing. The handguards are a MSR brand I got off ebay I think. Here is a shot or 2 of them.
Rider view
Front view
Side shot closer
Palmer, ALASKA
2011 Verys ADV
Old 02-09-2013, 07:17 AM   #6788
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 679
Headlight
Jeff
Does that headlight housing have LED bulbs in those small holes on each side of the headlight that act as turn signals? How do you think the headlight itself compares to the OEM headlight?
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 02-09-2013, 09:23 AM   #6789
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,254
Originally Posted by mrfixit54016 View Post
Jeff
Yes they are LED's and I now have them wired in as my front signals. In the pictures i still had regular signals installed. But I needed some clearence room for my larger tank so the signals had to go. The LEDs can be used as running lights or signals. And they are pretty bright. The headlight IMHO is brighter than OEM, with thee right H4 bulb installed....I think I'm running a Silverstar Ultra. I've tried a few different ones and this one seems to work best.
Palmer, ALASKA
2011 Verys ADV
Old 02-09-2013, 11:26 AM   #6790
elsalvadorklr
southern xr rider
Oddometer: 4,154
Jeff! are those 7/8 bars without the middle bar?
they look really long and skinny
if so be carefull man!
cheers
nice setup btw...fellow 88er!
Old 02-09-2013, 11:32 AM   #6791
deejay_xr
deejay_xr's Avatar
Oddometer: 496
I don't really understand what you mean.
If you grind down the centre cam journal you would have to weld it up and then have it re-ground to specification again.
Your cam is completely fine? If the damage to the journal is bad, it won't be for long...
How does the bad spot feel?
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 02-09-2013, 12:07 PM   #6792
elsalvadorklr
southern xr rider
Oddometer: 4,154
what I could make out from those pics in my humble opinion was HORRIBLE black oil...
the centre cam journal looked like it had BURNT oil on it which can easily be cleaned up...if its scuffed or pitted,then a regrind or polish is needed...
again my humble opinion
I really also dont understand why its so hard for people to frequently change their oil...its old dirty oil and a combinatiion of other scenarios that does this, mostly running low on oil and the consequent overheating...
BUT damn!
change your oil peeps!!!!!!!!!!!!!!!!!!!!!!!
Old 02-09-2013, 12:33 PM   #6793
Dino3310
Oddometer: 673
Thanks for the photos Jeff
great looking bike mate, looks well set up
Old 02-09-2013, 12:45 PM   #6794
T4EaterJonny
Not too hip...
T4EaterJonny's Avatar
Oddometer: 68
Hey alaska jeff- are those the Kenda 270s tires? I really can't decide on tires if I want to get a 90/10 dirt/street or something I can travel on.
1994 XR600R - Plated. Kenda trackmaster rear, Maxxis front, geared 15/43. Need: Big tank, respring/revalve and lighting. I live in Corona, California if anyone wants to ride!
T4EaterJonny is offline   Reply With Quote
Old 02-09-2013, 03:32 PM   #6795
XStatic450
ouch
Oddometer: 24
Jeff, what length are the risers?
CRF 450X
XR 600R
Tiger 800XC
XStatic450 is offline   Reply With Quote
Times are GMT -7.   It's 10:51 PM.
