Old 01-18-2010, 07:10 PM   #751
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
Originally Posted by screwit
My 2000 XR6 had the edelbrock on it when I got it. I have not had any problems with it but I also haven't noticed any real benefits over a stock carb either. I have an 01' XR400 with the stock carb and don't think I'm gaining much (throttle response, easier starting etc.) with the Edelbrock. I wouldn't spend the money to buy one if that helps.
It's already got the Edelbrock on it now. Seems ok I guess.
I like the fact that the accelerator pump is adjustable on the fly and the needle is as well.
Utah Moto Ride Reports
trackhead is offline   Reply With Quote
Old 01-18-2010, 07:29 PM   #752
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
The Edlebrock eliminates the bog when you goose the throttle. If that slight bog bothers you , spend 400 on the Edlebrock.
03 Honda XR250R
r00t4rd3d is offline   Reply With Quote
Old 01-18-2010, 07:41 PM   #753
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Only if it's the pumper version.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma screwed with this post 01-18-2010 at 08:43 PM
HeadTrauma is offline   Reply With Quote
Old 01-18-2010, 08:33 PM   #754
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
[quote=HeadTrauma]
The Edlebrock eliminates the bog when you goose the throttle.[/quote
Is there some indication on the carb as to if it's a pumper series?
Edelbrock Quicksilver is the model stamped on it. It has the right side accelerator pump screw and the red nob on the top to dial the needle.
Old 01-18-2010, 08:56 PM   #755
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
accelerator pump = pumper
03 Honda XR250R
Old 01-18-2010, 09:21 PM   #756
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
Got it, thx.
Old 01-19-2010, 06:45 AM   #757
Turbocelica
Turbocelica's Avatar
Oddometer: 244
Carb Assy Advice
I posted the following over in the XR400 thread. I'm posting over here also because the carb types are the same and I'm doing the XR600 next.
I've got my stock carb fully disassembled & cleaned. Should I use any lubricant at any locations to promote smooth operation & longevity? Or just rely on the fuel passing through it for any needed lubrication?
I could see the air/fuel passing through being sufficient for the throttle valve. I'm thinking for the linkage above the throttle valve, the shaft where the throttle cables attach and the contact surfaces of the choke lever. Nothing dripping but maybe a drop smeared then wiped off with a finger. Just enough to get a minimal film on the moving surfaces. If so what type? Motor oil, 3-in-one, Triflow or any other suggestions?
Lastly, how about the idle set screw/knob? Should I leave that bare or I was thinking just a very small amount anti-sieze??
Thanks,
Justin
Turbocelica is offline   Reply With Quote
Old 01-19-2010, 07:26 AM   #758
mcma111
mcma111's Avatar
Oddometer: 12,295
Carb
Yes you can put a dab of anti-seize on the threads of the idle screw but otherwise it's all dry. Anything you put on there WILL attract dirt to build up.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-19-2010, 08:09 AM   #759
esmoff
esmoff's Avatar
Oddometer: 85
Originally Posted by BigNastybrp
I ran 60/160 or 165 main
thanks..
esmoff is offline   Reply With Quote
Old 01-19-2010, 10:08 AM   #760
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Originally Posted by Turbocelica
1.) Should I use any lubricant at any locations to promote smooth operation & longevity? Or just rely on the fuel passing through it for any needed lubrication?
2.) Lastly, how about the idle set screw/knob? Should I leave that bare or I was thinking just a very small amount anti-sieze??
1.) Lube is optional, but I find that the stock XR600 carb works more smoothly, especially older ones with more wear, when the slide and bore has been oiled. Just use some kind of light oil like ATF, thin engine oil, etc. Fuel vapor will eventually wash it away, but I find it usually lasts long enough to be worthwhile.
2.) I don't think the idle screw needs anything if it isn't being frequently adjusted. If it is, then something else is not right. I haven't touched mine in probably two years.
Old 01-19-2010, 02:06 PM   #761
Turbocelica
Oddometer: 244
Carb Assy Advice
Thanks for the replies and advice.
As far as the Idle Screw goes sometimes I'll turn it up a bite for intitial start up when it's cold and hasn't been run in a while. Otherwise it'll die unless I leave the choke on for a real long time. Maybe I have my idle normally set on the low side? I know I don't have much of an ear for idle RPM of a thumper?
Justin
Old 01-19-2010, 02:30 PM   #762
mcma111
mcma111's Avatar
Oddometer: 12,295
Idle
I do the same thing, turn the idle up at start. The reason I suggested anti-seize on the idle screw is my buddy's XR650l's screw seized in his carb due to never turning it. Now it's really stuck!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-19-2010, 02:36 PM   #763
Turbocelica
Oddometer: 244
I think that's what I'll do... Put just a bit on there then wipe it off which will leave a very thin layer behind which should keep it from seizing and hopefully not atract too much dirt. The silver stuff I use pretty much requires solvent or brake cleaner to fully eliminate.
Old 01-19-2010, 02:46 PM   #764
kta
kta's Avatar
Oddometer: 583
With all my XR's I have always modulated the idle screw regularly. I don't even bother with choke on my bikes, I just twist up the idle a turn, 1 kick start, then gradually turn it down as the bike warms up.
Depending on riding conditions, temps, jetting, etc engine temp will vary during riding which has a direct effect on the idle. I do minor adjustments while riding all the time.
Your results may vary.
Ongoing Ride Report: ..... I'll just skip to the Baja part.
Motorcycle Tours in Guatemala
kta is offline   Reply With Quote
Old 01-19-2010, 03:36 PM   #765
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
In contrast, I don't have a choke and still never have to touch the idle screw. YMMV.
Times are GMT -7.   It's 01:12 AM.
