01-19-2010, 08:15 PM
#766 | |
Oddometer: 50
Dave |
01-19-2010, 08:26 PM
#767 | |
Oddometer: 50
It seems even though I thought the valve was not hitting the piston because it was on the down stroke the cam must have been "catching up" with it. I don't think the chain slipped it all fits nice and snug and the tensioner looks good. Thanks for your timely posts and insight, now to tackle the kick starter... .Dave |
01-19-2010, 08:32 PM
#768 |
Oddometer: 7,981
Cam Chain Tensioner
Eggspurt,
Is/was the bolt in the cam chain tensioner shaft? If not then the tensioner was not doing it's job.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
01-25-2010, 01:29 PM
#769 |
Oddometer: 47
As I had a free afternoon I thought I'd make a start on the XR engine swap after it gave out on me just outside of Helmsley at the end of October.
One XR up on its newly purchased stand. One replacement engine from a breaker, with guarantee fast running out, must get it in! Remove side panels: Remove tank and seat: Undo front sprocket stuff, and various control cables: The complicated wiring 4 of the 5 connections that had to be undone: Carb removed and strapped to frame: Exhaust removed too: Drain the metal flake effect oil, not good: Remove all engine mounts: Then lift out engine: Next jobs are to flush out the frame/headstock oil tank, clean the screen filter, clean the replacement engine, touch up a few bits of the frame with paint, mount the new motor, get a front sprocket that matches the splines on the output shaft, connect 5 wires, oil lines and control cables, change oil and filter on new motor, fit bodywork, start the beast up. One thing is that the output shaft on the replacement engine has fewer splines on it than the dead one , any idea what year front sprocket I therefore need to get?
UK expat in Holland, Black K6 GSXR 750, an Xr600R for muddy company. |
01-25-2010, 01:47 PM
#770 | |
whatever
Oddometer: 81
I once had a finger on a shift fork pop off, hit the oil pipe in there which put some restriction on oil delivery, almost a crimp. Still shifted but would have done some damage sooner or later to the top end, luck to get 50% flow through it looking at the pipe - and it is small already.
01-25-2010, 02:08 PM
#771 | |
Semi-Adventurer
Oddometer: 9,828
![]() Also, if you don't want your shaft to end up looking like the pic below, you might want to use only OEM front sprockets.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
01-25-2010, 03:53 PM
#772 |
RENOVATIO:
while its stripped to a rolling chase grab some CT-18 truck wash & kerosene mix 30% ct-18 to 70% kero in a pump spray (garden weed sprayer) from the local hardware store. give the rolling chase a good spray down let soak for 10min then pressure wash. it'll look new again
happy building
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack http://forum.xda-developers.com/ BUILD YOUR OWN PHONE CHEERS: brett MY07 950 SER |
01-25-2010, 04:34 PM
#773 |
Oddometer: 7,981
Splines
Fewer splines = an older model engine. Sorry. I don't know what years.
01-25-2010, 04:58 PM
#774 |
¯\_(ツ)_/¯
Oddometer: 1,246
I think the change from a six-spline countershaft to a 13-spline happened about the time XR600s were given a rear disc brake, so roughly 1991.
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
01-25-2010, 09:01 PM
#775 | |
people throw on a hardend sprockets so the sprocket lasts longer, without thinking of the concequences of doing so
01-25-2010, 09:46 PM
#776 | |
Semi-Adventurer
Oddometer: 9,828
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 MortimerSickle screwed with this post 01-25-2010 at 09:53 PM |
01-26-2010, 05:27 AM
#777 |
r-u-n-n-o-f-t
Oddometer: 12,185
The discussion I remember was that people using the hardened JT sprockets were having problems with the splines being buggered.
Not a huge sample size, but enough to cause alarm....I had two JT's in rotation (a 13t and a 14t), and promptly removed them and went with oem for the stock size, and I believe an AFAM or Sprocket Specialist for the 13t. There was no sign of any damage to the splines, but I'd just put a new 628 in and didn't want to damage the countershaft on a motor I'd just spent money on. The JT's were on there a while with the first motor and no wear. It's quite possible they would have worked fine....internet hysteria and all
'12 VFR 1200 . '13 TR650 Terra . IBA #11735 . 1968-present |
01-26-2010, 08:34 AM
#778 | |
Semi-Adventurer
Oddometer: 9,828
At no point, from purchase at the dealer, through the test results did anyone mention anything about the sprocket being harder than OEM. I hadn't suspected it might have been, because I had been using aftermarket sprockets on my 1979 XL500 since the first replacement, and had never had any problems.
01-26-2010, 12:12 PM
#779 |
One more time
Oddometer: 832
Carb switch
Has anyone put a Keihin 39 FCR on a XR600? If so how hard and was it worth the trouble? As always, any help is appreciated.
screwit screwed with this post 01-26-2010 at 08:46 PM |
01-26-2010, 02:22 PM
#780 |
Oddometer: 47
Thanks for the front sprocket info all.
