Old 05-07-2013, 05:48 PM   #8011
kirbi69
Oddometer: 219
sounds like a good deal. for a good tank .
I went with the IMS 4 gallon tank, a good compromise in my opinion. it works great!
the Clarke tank I bought didn't fit good at all. I had to return it. ive heard they sometimes have problems with the way they put the mounting holes in. but I took a gamble anyways, and lost :S
1994 XR600R dual sport
kirbi69 is offline   Reply With Quote
Old 05-07-2013, 07:15 PM   #8012
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
Originally Posted by mcma111 View Post
I'm pretty darn sure that the case hole size is the same for the XR600 as the XL600. I've gotten rid of all of my XL and XR cylinders so I don't have anything to measure except a set of XR cases. I do know when I put the 102mm piston in my XR that it required a larger sleeve.
what capacity did the 102 give and who made the piston ?
were you happy with the outcome etc ?
Geoff
96 XR600 currently undergoing a makeover
voltz is offline   Reply With Quote
Old 05-07-2013, 07:16 PM   #8013
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 631
I happen to have an IMS for sale in the flea market right now...
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 05-07-2013, 08:35 PM   #8014
Captain115
Captain115's Avatar
Oddometer: 278
Hey Geoff,
Not sure if you know, but here's the formula for calculating the capacity of our motors (just the volume of a cylinder formula):
radius of the piston squared multiplied by pi multiplied by the stroke (Our stroke is 80mm)
I usually convert to cm so I don't have to convert from cubic mm to cubic cm at the end. Doesn't matter either way.
So for the stock piston that is 97mm it would be:
97/2 = 48.5mm radius or 4.85cm
4.85^2*pi*8
=591.18cc
For a 102mm piston:
102/2 = 51mm radius
5.1^2*pi*8
=653.7cc
Hope this helps,
Cheers
John
Captain115 is offline   Reply With Quote
Old 05-07-2013, 09:08 PM   #8015
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
Originally Posted by Captain115 View Post
Hey Geoff,
4.85^2*pi*8
=591.18cc
For a 102mm piston:
102/2 = 51mm radius
5.1^2*pi*8
=653.7cc
Hope this helps,
Cheers
John
thanks John,
I knew there was a formula but it's been a long time since I used it :eek:
looks like the 654 I had heard bout was the 102mm oversize
thanks for your post,sometimes it's all too easy to just ask questions instead of
looking things up
Geoff
Old 05-07-2013, 10:14 PM   #8016
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
John
I found this calculation while doing some reading
obviously just a different way of doing what you said maybe a little easier to remember
Engine displacement = bore X bore X stroke X 0.7854 X number of cylinders
Geoff
Old 05-07-2013, 11:48 PM   #8017
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,139
Advice needed on rear sprocket / hub dilemma
So after a 2 year wait I am FINALLY getting a Kush Sprocket sent to me for my 88 XR6. The dilemma is that they are currently making this batch to fit 91-00 models. Which means that the inner diameter of the Kush sprocket is 125mm and the 88-90 wheel hub is 130mm...........So which do I have milled down, the new sprocket inner diameter OR the wheel hub outer flange? PLEASE help me decide.
Honda 520 Kush sprocket.
Suits models:
HONDA 2 (counterbored to suit M10)
XR 600
91-00
XR 650 L
93-09
Dimensions:
153 mm BCD to suit 6x M10 bolts
125 mm center hole.
What is the benefit of a Kush® sprocket with inbuilt cushioning? Considerably longer gear life, less chain and sprocket wear and less wheel hop during compression braking (for off-road, supermoto/motard and enduro bikes ridden on road without a cushioning hub). Kush sprockets were designed as a replacement for the cushioning hub (cush-drive, cush or dampening hub) common in most road going versions of enduro/dual sport motorcycles.
Kush sprockets use a patented design to allow the outer toothed ring to revolve on the inner aluminium plate, using polyurethane dampening to absorb piston pulse, shock loads and vibration. Kush sprockets are engineer designed and tested in Australia. Utilising nitride hardened SCr440 alloy steel, 7075 Aluminium central carrier and high performance polyurethane elastomer dampeners, Kush sprockets provide exceptional high-cycle endurance and durability for all riding conditions.
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 05-08-2013, 02:05 AM   #8018
Royal Club
Royal Club's Avatar
Oddometer: 392
but, even if you mill the sprocket or the hub itself. the boltholes won't align...
Royal Club is offline   Reply With Quote
Old 05-08-2013, 03:27 AM   #8019
RoostMaster
Oddometer: 244
Laugh
Hey Geoff,
4.85^2*pi*8
=591.18cc
For a 102mm piston:
102/2 = 51mm radius
5.1^2*pi*8
=653.7cc
Hope this helps,
Cheers
John
Captain,
that calculates my 'Kenworth 1300 kit' (low comp, 142mm) to be 1284.8cc's.... I got ripped off 15.2cc's ! Don't buy this kit ! OR get that Pi guy to adjust his Pi thingy....
I'll post after it's in...
RoostMaster is offline   Reply With Quote
Old 05-08-2013, 03:31 AM   #8020
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
I was thinking the same
I have never heard of these Kush sprockets : before
Something else to look into
Geoff
Old 05-08-2013, 06:10 AM   #8021
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,139
I noticed that too but with only 3mm difference from BCD I will be able to drill them out to fit pretty easily. Or at least thats what I'm telling myself.
Palmer, ALASKA
2011 Verys ADV
Old 05-08-2013, 02:00 PM   #8022
Royal Club
Royal Club's Avatar
Oddometer: 392
but what about the counterbore?
Old 05-08-2013, 02:33 PM   #8023
mcma111
mcma111's Avatar
Oddometer: 11,877
Bottom line. Don't do it...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 03:38 PM   #8024
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
Chaingang sprockets
it's no Kush drive but supposedly these sprockets outlast others by far,
might be worth a look
http://www.chaingangchainsandsprockets.com.au/
Geoff
Old 05-08-2013, 04:00 PM   #8025
Captain115
Captain115's Avatar
Oddometer: 278
Originally Posted by RoostMaster View Post
Captain,
Ahhh, bastards they're ripping you off haha. I always think it's amusing that engine capacities are often rounded up...though I guess XR600 flows better than XR591.
John
Thanks Geoff, that is definitely easier! I am maths tutor so just went with the standard all cylinder volume formula (area of base x height) but your way is quicker to calulate an approximate value in my head.
Cheers,
John
Captain115 screwed with this post 05-08-2013 at 05:10 PM
Times are GMT -7.   It's 10:54 AM.
