Old 05-16-2013, 11:52 AM   #8101
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by The Shred View Post
What tools do I need and how do you remove the swing arm bearings?
as stated many times in this thread, a BFH
Royal Club is offline   Reply With Quote
Old 05-16-2013, 02:23 PM   #8102
The Shred
Airventurer
The Shred's Avatar
Oddometer: 425
Originally Posted by mcma111 View Post
That's for installing bearings. I have a threaded rod and the right size sockets for installing the bearings. The question was how to remove them?
The Shred is offline   Reply With Quote
Old 05-16-2013, 02:28 PM   #8103
The Shred
Airventurer
The Shred's Avatar
Oddometer: 425
I was going to try and punch them out with a hammer, but I thought someone may have a better way. I even read the book. It said take it to a place that has the special tool.
Old 05-16-2013, 02:40 PM   #8104
mcma111
mcma111's Avatar
Oddometer: 12,922
Never mind...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2013, 03:25 PM   #8105
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
Carbide burr and dremel can reach in there and weaken the shell. Using a torch, heat it up and all that old grease will loosen it up and it will just about slide out.
Hate gets you nowhere.
Old 05-16-2013, 03:44 PM   #8106
elsalvadorklr
southern xr rider
Oddometer: 4,154
installing is easy its the old shit that sucks taking out1 jajaja
I once used a handheld drill and hooked up a car battery to it so it wouldnt die on me every 5 minutes then bought a hole saw drill bit the exact size of the bushing/bearing
this was on a 36 year old cb750 swingarm bushing...
it took forever!!!!!!!!!!!!!!!!!!!!! but I installed some nice bronze bushings and thats all she wrote
I have some pics of what I used on my xr6 but man that is deep in my rebuild thread...
good luck
elsalvadorklr is offline   Reply With Quote
Old 05-17-2013, 05:13 AM   #8107
Fourstring
Fourstring's Avatar
Oddometer: 142
Originally Posted by joexr View Post
You've only got to pull off the rocker box.
Anyone have tips for getting the rocker box out of the frame? It's in there pretty tight, but I really don't want to pull the motor to install one O-ring...
Thank God I'm not cool.
Fourstring is offline   Reply With Quote
Old 05-17-2013, 06:54 AM   #8108
Royal Club
Royal Club's Avatar
Oddometer: 392
move it towards the carb, it should have enough space to get it out then..
Old 05-17-2013, 01:52 PM   #8109
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
or take the carb off,makes it pretty easy then
Geoff
96 XR600 currently undergoing a makeover
voltz is online now   Reply With Quote
Old 05-17-2013, 11:27 PM   #8110
Captain115
Captain115's Avatar
Oddometer: 287
Team,
Put everything back together, engine in the frame, everything connected, valve clearance checked.
Poured a little oil through the valve cover holes to lube the top end, the rest in the frame and oil filter holder.
Kicked/rolled the bike until oil came out the bottom banjo.
Choke on, killswitch on (off? whatever, so it could start), a few kicks through with decomp lever in and then a few mighty boots.
Repeated a couple of times, with a small cough and fire each time before it came to life. Sweet.
Let it warm up for 20 seconds or so while checking for noises etc and then rode it out to begin the break in procedure.
First 800 meters all was fine...
Then the knock under acceleration started
Thought it might just need to warm up a little and had to get home anyway, so rode home, trying to listen to if/when this occurred. Didn't seem to happen on deceleration, only on acceleration at slowish speeds, although that may be because it's harder to hear over the wind at higher speeds. So that sucks.
Questions:
What is this noise? Rod knock?
Have I trashed my piston cylinder do you think?
This was the same machinist that did benno's XR (that buggered the first piston) and hence the bore had a tight clearance. A factor, or irrelevant?
Where to now?
Thanks,
John
Captain115 screwed with this post 05-18-2013 at 12:03 AM
Captain115 is offline   Reply With Quote
Old 05-18-2013, 07:54 AM   #8111
Airguitar
Thumpin'!!
Airguitar's Avatar
Oddometer: 402
Question
Originally Posted by Captain115 View Post
Team,
Questions:
Where to now?
Thanks,
John
Some knocks are exactly as you say.. Rod knock..
Other common faults are:-
Cam chain tensioner.
Lay the bike on its left side. Leave like that for 10 min. Then you can remove the right engine cover without losing too much oil, nor having to drain it. Check the cam chain, the tensioner has an indicator up on the right rear side of the head - a disc with a strip in it that should normally be horizontal. If it's anything else your tensioner is not correctly adjusted or seated.
Inspect the crankcase oil filter screen, check the oil pump dowel that feeds oil to the side cover oil tube is not missing. (They can fall off during assembly and give a lot of grief.) When repacing the cover it can be held in place with a blob of grease to preclude from falling out.
Hope you get it sorted and the offending gremlin hasn't caused too much havoc.
1988 Honda XR600R
(Thumping Thunder)
Airguitar is offline   Reply With Quote
Old 05-18-2013, 11:57 AM   #8112
elsalvadorklr
southern xr rider
Oddometer: 4,154
what is it with machinists man!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so you say its the same machinists as benno...so does that mean that he decided to do the same thing as he did to bennos wuth too tight tolerance or what?
I cant for the life of me understand why machinists are so damn stubborn...I hope to hell its not the same scenario as benno cause it was caused by using oem tolerances or ther abouts on a very nice and loose tolerance forged piston
good luck man
you did check oil flow did you? after starting you must make sure you have flow at the lower banjo, if not it could be your fault...just sayin bud
Old 05-18-2013, 04:46 PM   #8113
Captain115
Captain115's Avatar
Oddometer: 287
Is there a way to figure out if the rod or some bearings are fucked? There is definitely no vertical play in the rod, and the small end is fine. So the million dollar question is it the crank bearings or is the big end of the rod fucked?
The crank bearing that sits in the right case seemed fine when the cases were split, spun ok and didn't seem to have much play in it. I didn't check the left bearing since it is between the flywheel and the crank, but it spun ok?
This is a fairly new rod too I would say, Pro-X rod, probably put in 10,000km ago.
Final piece of information. When I ran it dry before this rebuild, it began making the knocking noise very similar to what it is now except at all times, idle, decelertion, acceleration. Since I've replaced almost everything else, would you think this is just a left-over fucked-up piece from the oil starvation time?
Thanks Airguitar. Cam chain tensioner was install correctly I'm pretty sure, I followed Steve's directions and after a few revolutions, the timing marks still lined up fine.
The oil dowel was worn down slightly but still there and definitely in place, as I was worried about losing it (and I used the grease trick already, thanks!).
Thanks for the help, I have a feeling that it's deeper in the guts though.
good luck man
Yep same machinist, same tolerances etc. However, I don't believe that the knocking would be from this, especially not a piston slap since it is so tight...I just hope that if it is the road/bearings that it hasn't fucked the new cylinder and piston...
I triple checked the oil flow after priming it, and then again after it started. All good, definitely was getting oil to the top end. It isn't an oiling problem per se, I'm leaning towards it being the rod now.
Thanks to both of you for the help! Anyone else like to chime in too?
John
Old 05-18-2013, 05:34 PM   #8114
elsalvadorklr
southern xr rider
Oddometer: 4,154
well I wish yuo luck man, that sucks
couple of things
did you replace the crankshaft end seal that is inside the clutch cover? maybe you are not getting oil to the crank and losing it there
are you sure the inner pipe tube that connects the pump to the inner case is put in correctly?
lastly
I think you soft seized , if you used the same tolerances that benno used first time around I think its only a matter of time man, maybe its scuffed up a bit and rattling...????
dont know
did you clean the crank bearings?
Old 05-18-2013, 08:45 PM   #8115
Airguitar
Thumpin'!!
Airguitar's Avatar
Oddometer: 402
whatever it is it's going to mean open surgery
1988 Honda XR600R
(Thumping Thunder)
Times are GMT -7.   It's 07:09 AM.
