Old 05-27-2013, 06:03 AM   #8191
Royal Club
Royal Club's Avatar
Oddometer: 392
yeah.. I think I can brew something up.. Still would be nice if someone could donate some old pegs.. even the worn stuff is expensive here.. -_-
Royal Club is offline   Reply With Quote
Old 05-27-2013, 06:21 AM   #8192
joexr
Oddometer: 3,773
I think all you would need is a bushing for a spacer , without welding.
Old 05-28-2013, 03:46 PM   #8193
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,758
Just got my 3rd XR600, this time a 2000 (hello 21st century brakes opposed to those on my 86/87).
Came with an hsr42 carb on it. Runs very well, especially on mid to top. But, has a slight stumble just off idle. Only does it when rolling in the throttle slowly. Seems like a lean condition the way it farts. Here's what I'm thinking to try:
Half turn in on air screw
Half turn out on throttle pump (allow more in)
Drop one clip on needle
On the big end, seems to run just fine as its blowing a little black soot on the fender. Has a fmf powerbomb header and q4 exhaust with spark arrester. Doesn't start hard. But, needs no choke at start up, which seem to contradict my lean on the bottom theory.
Anyone got recommendations on jetting setups? I am at sea level, and is often quite humid.
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 05-28-2013, 03:55 PM   #8194
Royal Club
Royal Club's Avatar
Oddometer: 392
whatever you choose to do, do one thing at a time, not all three!!!
Old 05-28-2013, 08:58 PM   #8195
Dino3310
Oddometer: 673
good excuse to open her up every time and not just 'roll on the throttle'
Dino3310 is offline   Reply With Quote
Old 05-28-2013, 09:02 PM   #8196
Dino3310
Oddometer: 673
Hey nikolic
what bike did the oil cooler come off?
thinking of adding one under my headlight
Old 05-29-2013, 11:01 AM   #8197
nikolic
Oddometer: 479
Originally Posted by Dino3310 View Post
Hey nikolic
yamaha xtz tenere 600!
Home rides ;)
nikolic is offline   Reply With Quote
Old 05-29-2013, 11:57 AM   #8198
elsalvadorklr
southern xr rider
Oddometer: 4,154
great choice...of cooler and installation!
nikolic just be carefull with the copper tubing...it has a tendency to fatigue and crack...its a great material but a little sensitve to vibration and such...
My dad used to make solar panels and we made copper heat tubing to absorb the suns energy...
I learned a lot as a kid about the benefits of copper and how to work with it...
other than that great job! jealous!
elsalvadorklr is offline   Reply With Quote
Old 05-29-2013, 04:10 PM   #8199
martin.kryjom
Oddometer: 50
Tm 40
HI
I have renovated XR 600 R with 628 HRC big bore done by XR only.
Please help me with carb, i have try already 3 of them and results are strange.
1) It was flat side MX by XR only- bike did not start, if star has pure "pumping" effect on the mid range, no power...
2) FCR 40. To start that thing i needed to screw IN Idle screw, then , when engine hot i needed to crew it out to get proper idle . This carb does not have choke. Bike was running unstable up to 1/4 throttle, "pumping" effect, unstable idle and so on. When stop, i needed to screw idle screw in and then start
SET UP
EMR needle
170 main jet
50 pilot jet
Fuel screw: 1 turn out
pilot air jet: 150 (1.5 turn out)
main air jet: 200
3) Mikuni TM 40. Now on the bike.
It starts in the beginning with the choke out, but now to start the bike i need to screw Idle Screw almost all IN .Bike starts but with very high rpm. If i set up idle for proper rpm, it goes down on every stop lights:(.
When i try to make rapid acceleration bike is not responding up to 1/4 throtlle.
I have Mikui set up for Honda XR 600 , but no idea what is that set up as i did not get any manual for that,
How is related idle screw to fuel screw in that carb? What IDLE screw does?
Please help as im loosing my determination to ride that thing again:(
martin.kryjom is offline   Reply With Quote
Old 05-29-2013, 04:36 PM   #8200
elsalvadorklr
southern xr rider
Oddometer: 4,154
martin the issue is you never actually tune the carb you currently have
if you just plop on different carbs from different bikes you are going to end up shooting yourself!
from all this info you just put up all I can say is the fcr40 on the xr6 uses the ncvt needle...
it also needs to be tuned for your specific cam, exhaust etc...
you never did work on the tm38 from xrsonly did you?
the tm40 is a popular carb for the bigger xr650r it may work but whatever settings work on the xr650r will not likey work exactly the same as on the xr6 that is pretty basic info...
tough to help when you dont follow through
Old 05-29-2013, 04:45 PM   #8201
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
^^^^^words of wisdom,right there !
Geoff
96 XR600 currently undergoing a makeover
voltz is offline   Reply With Quote
Old 05-29-2013, 07:11 PM   #8202
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,515
Yessir +1 , small moves and only 1 at a time .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 05-30-2013, 02:57 AM   #8203
Airguitar
Thumpin'!!
Airguitar's Avatar
Oddometer: 400
How wise is Wiseco & co...?
Hi fellow XR600 riders.
Here's a question:- After reading this thread from start to finish, and then more like it on TT, etc. I come up with a common theme. After many people do a rebore and add Wiseco or similar, Hotcam, etc. The bike goes like hell for 3 months and then it's rebuild time with the top end or piston/rings doing a major self-destruct.
I'm an aircraft engineer, and we have a policy of always staying within the design limits of the factory. When you exceed those limits, you SEVERELY, EXPONENTIALLY compromise the reliability of the engine(s). (Read shorten time between rebuilds)
Where is the sense, then, in hot-rodding a 20-year-old bike when you KNOW you're going to be rebuilding it within 2000 miles?
And most likely the bike will let you down when you're 150 miles from help.
My inclination is to keep it standard, go (a bit) slower, but much further for much longer with far fewer surprises downroute. What say you?
1988 Honda XR600R
(Thumping Thunder)
Airguitar is online now   Reply With Quote
Old 05-30-2013, 03:04 AM   #8204
Dino3310
Oddometer: 673
rebuilds half the fun
Old 05-30-2013, 03:07 AM   #8205
Dino3310
Oddometer: 673
sweet cheers mate, it looks primo, you done a good job
Times are GMT -7.   It's 09:46 PM.
