Old 05-30-2013, 07:16 AM   #8206
elsalvadorklr
southern xr rider
Oddometer: 4,154
airguitar
I have enjoyed my cast 87 long skirt piston in my 88 engine now for a nice while and enjoy the quietness and great performance too...it also drinks no oil unless Im at wot all the time...
I have come to the conclusion that a good fcr carb or other type pumper carb(I like the simple non pumper flatslide) paired with some nice headers, portwork(dont need this unless you go high comp or cam) maybe and a nice flowing muffler is as good as most need engine wise to modify the xr...
My biggest investment so far has been suspension..both the shock and using usds now...some good brakes and a steering damper down the road would be as much as I would do to keep a long running and relaible bike...
you can go crazy on engine mods...but I think its not what the xr is about really...
I went back to stock, but mostly because Im selling the bike...which seems to be very soon!
my advice...
elsalvadorklr is offline   Reply With Quote
Old 05-30-2013, 07:31 AM   #8207
elsalvadorklr
southern xr rider
Oddometer: 4,154
fcr40 thread and info
for those swithcing to fcrs:
http://www.thumpertalk.com/topic/995...esome-upgrade/
Old 05-30-2013, 11:00 AM   #8208
martin.kryjom
Oddometer: 50
Originally Posted by elsalvadorklr View Post
martin the issue is you never actually tune the carb you currently have
if you just plop on different carbs from different bikes you are going to end up shooting yourself!
from all this info you just put up all I can say is the fcr40 on the xr6 uses the ncvt needle...
it also needs to be tuned for your specific cam, exhaust etc...
you never did work on the tm38 from xrsonly did you?
the tm40 is a popular carb for the bigger xr650r it may work but whatever settings work on the xr650r will not likey work exactly the same as on the xr6 that is pretty basic info...
tough to help when you dont follow through
HI
I change for FCR as it was sold to me as prejetted for XR 600 R. I do not like throttle response of the mx flat side XR only carb.
Anyway. I make today plug test.
Bike starts , runs 20 s, then stoped, then is very very hard to start, like 20 min of kicking.
Then starts , stops and again.
WHen engine is cold, for some short time i have white smoke.
I took out the plug.
Is black as on the picture.
Looks like is too rich.
My set up for that carb is:
EMR needle
170 main jet
50 pilot jet
Fuel screw: 1 turn out
pilot air jet: 150 (1.5 turn out)
main air jet: 200
WHat to do?
martin.kryjom is offline   Reply With Quote
Old 05-30-2013, 12:59 PM   #8209
elsalvadorklr
southern xr rider
Oddometer: 4,154
martin did you read the thread link I posted?
you dont like throttle response because you never jet completely...or fully
no carb will be perfect if you do it this way
that emr needle is wrong you need the ncvt needle for the fcr carbs
good luck
Old 05-30-2013, 01:00 PM   #8210
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by martin.kryjom View Post
HI
EMR needle
170 main jet
50 pilot jet
main air jet: 200
WHat to do?
white smoke?????????????????????????????????????? you got something else going on, maybe engine problems that are making you have CARB problems or carb like issues...
why white smoke?
Old 05-30-2013, 01:21 PM   #8211
martin.kryjom
Oddometer: 50
This what im afraid of, but i have paid XR only for all new engine, I know that they sucks sometimes , but i think they have a lot of expirience and they bulid the engine in proper way...I paid 3,5 k USD + 2k USD for shipment and Duties, i hope that i did not throw that money... I did it in XRonly as in EUROPE in 90's honda was not so popular, and XR only has a great background, may be i made a wrong decision:(
Is only when engine is cold, until it reach around 30 C temperature.
I heard it is quite normal...
Or may be i should check something?
What to do?????
Old 05-30-2013, 01:30 PM   #8212
elsalvadorklr
southern xr rider
Oddometer: 4,154
hmmm well maybe there is water in the oil after shutdown but anyways might be more normal in real cold weather dont know really
dont know what to say...
read some more about the fcr carb I linked the complete way to adapt he fcr to your bike...
I dont know who told you it came prejetted but maybe you need to read a bit more and see if you have everything setup
the link I provided has been tested using oxygen co2 sensors with air fuel graphs so that is why I say the needle you are using is wrong...
good luck
Old 05-30-2013, 01:37 PM   #8213
martin.kryjom
Oddometer: 50
What about plug, it shows that is too rich?
May be smaller PJ would help?
I see that im in much different spec then from the link u have sent.
Main jest i have 170, they use 158
PJ i have 50 they use 42. But it looks like they have notrmal engine, no big bore.
White smoke can indicate piston rings damage, is there any other indication of piston ring damage?
Old 05-30-2013, 01:41 PM   #8214
elsalvadorklr
southern xr rider
Oddometer: 4,154
you have 2 issues you need to fix
white smoke
then jetting
the reason you might be having all these problems is because you have some piston rings issues
maybe look for posts about similar issues that you have...
I dont think xrsonly did a good job with your bike
also big bore jetting changes minimally
its when you start modding cams and intakes and timing etc...that big changes occure but even then only a few sized here and there not major like you have
Old 05-30-2013, 02:50 PM   #8215
martin.kryjom
Oddometer: 50
I think problem is found and XR only did good job, i just fucked all up.
I write it for others now , i get the lesson .
Some time ago, around january i have posted on this forum that i have found that my frame after sanding it is full of sand and metal parts.
I have cleaned it out, most of it. However some of the send left and i put all bike together ( MY MISTAKE)
The frame was rubish, i should never do it.
Now the send get intoo the oil and inside to th eengine and distroy piston rings and piston itself ( propablly)
I took oil off the engine 10 min ago, and the plugs ( magnetic plugs ) where full of metal dirt, like from the sending. Magnetic plug from the engine has melted metal on it, what indicates that that dirt come intoo engine somehow.
I made a call to XR only, i say about white smoke, and the 1st question was" DID U SEND THE FRAME BEFORE???"
Now my 2 years project, saving money, lot of work is rubish.
Engine needs to be done again, frame is rubish. It needs another 2-4 k USD to finihs it and i think i will give up. Im stupid , i should never put that engine to that frame, it was done, i should buy new frame and starts all over again.
Now if i wonna XR to run i need to buy not only frame but also engine.
So no good and so sad:(
Old 05-30-2013, 03:36 PM   #8216
Royal Club
Royal Club's Avatar
Oddometer: 392
finally got my 6dollah china yellow color h4 bulb awesome oldskool look! I'll take a pic when I can stop somewhere in the dark.. My neighbours won't appreciate it if I kick the piggy over at this time..
Royal Club is offline   Reply With Quote
Old 05-30-2013, 03:40 PM   #8217
mcma111
mcma111's Avatar
Oddometer: 12,250
What? At 3:30 in the afternoon???
Some neighbors.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-30-2013, 04:23 PM   #8218
Royal Club
Royal Club's Avatar
Oddometer: 392
its 1:23 AM here buddy
Old 05-30-2013, 04:57 PM   #8219
mcma111
mcma111's Avatar
Oddometer: 12,250
Go start that bitch.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-02-2013, 08:31 AM   #8220
The Dogger
Oddometer: 143
Don't give up now man !
Is there an engineering shop that could hone the cylinder for you ? Maybe a new piston , but no need to spend mega bucks ?
Then flush that frame out again ( and again , and again.....) Steve's Engine rebuild thread ( I think ) will show you how many times it needs to be done. Many , many times , but you can be doing that while your new best friend at the work shop sorts the engine out.
There are plenty of people on here who will help you get it back together again if you think the machinist is not familiar enough with this engine
The NCVT needle that you need is Honda part number 16234-MEN-671 . About 30 from David Silver Spares in the UK , I think they're about $10 in the US
Good luck , and do not give up. Report back with progress , we want to see this beast running.
Cheers
The Dogger is offline   Reply With Quote
Times are GMT -7.   It's 12:32 PM.
