Old 10-08-2013, 11:13 PM   #8911
boingk
boingk's Avatar
Oddometer: 339
Sounds good to me too. No idea what the internals are on mine but suspect its running a tad lean on part throttle - popping quite loudly every now and then on deceleration with the FMF exhaust.
Will try raising the needle and also verify the jetting while I'm at it.
For reference I'm running an FMF Powerbomb header with Powercore 4 can, Unifilter large-plenum intake, advanced spark timing CDI (3 to 5 degrees across the range) and stage one Hotcam (yes, I know the stories!).
Cheers all.
- boingk
EDIT: Also, I know that oil coolers have been done to death here... but the picture floating around looks overly complicated. Is that the only way to do it or is there another path? I'm thinking of fitting something like this: link
'00 VTR1000F, '97 XR600R, '80 GS850G
boingk screwed with this post 10-08-2013 at 11:26 PM
boingk is offline   Reply With Quote
Old 10-09-2013, 03:14 AM   #8912
Royal Club
Royal Club's Avatar
Oddometer: 392
Cheers all.
- boingk
How'd you get the advanced spark timing?
also, I did this and it did help a bit.
Royal Club is offline   Reply With Quote
Old 10-09-2013, 05:06 AM   #8913
boingk
boingk's Avatar
Oddometer: 339
Looks alright mate but I'm after the oil capacity increase as well.
the cdi was off EBay. Works well, straight outta China for about 20 bucks
Old 10-09-2013, 10:51 AM   #8914
Elvis!
Oddometer: 49
Originally Posted by Elvis! View Post
I got some (probably stupid) questions about the clutch.
http://www.cmsnl.com/honda-xr600r-19.../#.UlK5yDK9KSM
The clutch Basket (3) has some free play in the center, it pivots a little bit. The outer guide (4) is in the exact service limit measure, so i'll replace it, but wanted to know If some play is normal.
All clutch basket springs but one, are loose. I Cant find those springs as a replacement part. Dont know exactly what to do.
Thanks in advance.
*excuse my basic english.
No one?
Elvis! is offline   Reply With Quote
Old 10-09-2013, 01:09 PM   #8915
mcma111
mcma111's Avatar
Oddometer: 11,901
Play? What kind of play?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-09-2013, 03:21 PM   #8916
Mike the Yank
Oddometer: 389
I'm going down the XR400 oil cooler and lines route. When I find one!
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Old 10-09-2013, 05:15 PM   #8917
Elvis!
Oddometer: 49
Some free play. (I dont know If thats the right term in english)
It pivots in the center. Not too much, but in the outer part of the clutch basket, its about 1 mm of movement.
Thanks.
Old 10-09-2013, 05:42 PM   #8918
mcma111
mcma111's Avatar
Oddometer: 11,901
I wouldn't worry about it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-09-2013, 06:00 PM   #8919
Elvis!
Oddometer: 49
Thats what i wanted to hear.
Thank you very much.
Old 10-10-2013, 01:50 PM   #8920
kyle4rley
Oddometer: 13
Originally Posted by kyle4rley View Post
68 pilot for the win! Thanks! Since it has been run lean for so long, is there anything I should be on the lookout for?
wah wah wah. So after a few runs to work and back the popping on decel and stalling all but went away, but there is a hesitation/surge when I want to remain at a constant speed, pulled the plug today and it is really black. so now it's rich. clip position? I don't know.
kyle4rley is offline   Reply With Quote
Old 10-10-2013, 02:03 PM   #8921
mcma111
mcma111's Avatar
Oddometer: 11,901
The clip should be in the #3, center position. What main are you running?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-10-2013, 02:06 PM   #8922
kyle4rley
Oddometer: 13
main is 158 clip is one below that, moving it one spot is enough to lean it out? thanks.
Old 10-10-2013, 02:15 PM   #8923
mcma111
mcma111's Avatar
Oddometer: 11,901
You have the clip in a richer position. Move it up one. If the problem persists go to a 155 main.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-10-2013, 07:09 PM   #8924
Mike the Yank
Oddometer: 389
Since they are a dry sump can't you just dump more oil into frame resi??? Too the over flow point?
Old 10-10-2013, 08:52 PM   #8925
selztoad
Oddometer: 14
In progress
selztoad is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
