Old 11-13-2013, 09:48 PM   #9121
lucknau
Greenhorn
lucknau's Avatar
Oddometer: 194
Call all XR600R!!!
I'd recommend going the DC route, and whole hog, too, so you can nerd out on accessories. Otherwise, you ought to be able to fix the AC relay issue cheaply. Assuming you're not using LEDs, it could be just that the signal bulb filaments are too low resistance. The summed wattage of two signal bulbs should be less than or equal to the watt rating of your relay.
Oh, and I think you've got the right idea for the AC and DC loads. That's what mine's like, anyway: AC for the headlight, AC for ignition, DC for all else. The ignition and headlight circuits are different wires coming out of the stator, from different coils.
Spotwalla location ID: LUC
lucknau screwed with this post 11-13-2013 at 09:55 PM
lucknau is offline   Reply With Quote
Old 11-14-2013, 08:40 AM   #9122
Beltway
Location: Peoples Republik of Takoma Park, MD (Wash. DC)
Oddometer: 40
Thanks for the help, gents.
I neglected to mention that my turn signals are, in fact, LED. I do have resistors to try in-line, but I thought that would only help with how quickly they blink, not whether or not they blink at all. As of now they are just a steady light. Will try the resistors and report back.
I like the idea of having some DC available for accessories. As of now the Vapor is running off a battery so the backlight won't stay on for long. Annoying at night. I've heard it will run off of AC but haven't confirmed. A GPS and heated grips might be nice someday. Will price up a regulator/rectifier and battery or capacitor. Thanks, lucknau, for confirming that my plan might work.
The carb issue is a much larger one. The Eddy is nice and smooth, but damned if I can get it running in the cold. Will dig deeper and see if I can sort it out. I really don't want to engineer a way to mount another carb at this point. I've done it, and would rather not do it again right now. My preference would be for a plug and play solution, even if it is more expensive. I see that XRsOnly has a Mikuni kit, but I think it is rebored and have read about issues with it. Anyone with first hand experience to share? Info on other options that are well understood and relatively easy to set up would be most appreciated.
Beltway is offline   Reply With Quote
Old 11-14-2013, 09:11 AM   #9123
WantToRideMoar
Oddometer: 311
I'm shocked your LEDs work at all on AC. BTW, resistors will still result in consuming the same amount of power as if you put a conventional incandescent bulb in the system anyways. Getting a turn signal relay that is designed for LED draw levels will result in more power being available for other devices.
I really think you're best served putting your turn signals on a DC circuit. With the rectifier, you can still have DC and not have a battery if you really want. I bypassed the battery and ran off the rectifier, testing all my DC stuff. The backlight on my Vapor flickered very oddly, but the headlamp and turn signals and horn were all fine. A capacitor would even out the backlight issue if I really wanted to go without battery, but I like the battery for situations when I want lights to work without the engine running.
My vapor runs off my battery. I don't think I'd try running it off AC.
You really don't need much battery. I went overboard and have a 3amp 12v AGM battery mounted up underneath my rear fender. But as long as it's 12v, you could get away with a few hundred miliamps. It just has to buffer temporarily low RPM demand, and it'll get charged by just about anything over 2500RPM unless you run the CD player AND the coffee maker at the same time.
WantToRideMoar is offline   Reply With Quote
Old 11-14-2013, 10:10 AM   #9124
Beltway
Oddometer: 40
Thanks, WantToRideMoar. Good point on the power consumption with resistors vs using the proper relay.
I'm leaning hard in the direction of adding a DC circuit. One side of my Ricky stator is unused right now (100w per side), so I might just feed that into a reg./rectifier and wire the horn, brake light, Vapor and turn signals into DC. Seems a better way to go. I already have a nice little 12v Ballistic battery I can use to even out the power. Should fit under my seat or tank with little trouble.
On the carb tip, has anyone used one of these on a XR600?:
http://www.xrsonly.com/mikuni-pumper...t-honda-xr650r
I need to check the diameter of my current carb to see how much additional work would be required to fit it up. I don't want to lose any low RPM torque by fitting something too big.
Old 11-14-2013, 10:59 AM   #9125
mcma111
mcma111's Avatar
Oddometer: 12,101
Carburetor
Beltway,
Here's an idea for you. Install a XR650r carb on your XR600.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-14-2013, 01:18 PM   #9126
Beltway
Oddometer: 40
Originally Posted by mcma111 View Post
Beltway,
Hi mcma111, thanks for chiming in. I've read many of your posts regarding XRs and was hoping you might offer an opinion on the carb issue. I'll look into what putting an XRR carb on my XR6 would entail.
Cheers.
Old 11-14-2013, 02:07 PM   #9127
focallength
You're Welcome
focallength's Avatar
Oddometer: 4,790
Whirring
Ok, my bike started making a whirr upon start, I hit the magic button, it fires up and there is a decelrating whirr, for about a second. It sounds kike its coming frim the starter. It promotly goes away, no running or starting problems.
Im thinking maybe the starter us goung bad, but theres no extended or difficulty in turning the engine over. Ideas?
Sir, you got run over because you were walking to slow for the speed of traffic.
focallength is offline   Reply With Quote
Old 11-14-2013, 03:19 PM   #9128
mcma111
mcma111's Avatar
Oddometer: 12,101
Cheers.
XRR throttle, cables and the carb. Boom!
I got one to install on my XR but then I got a FCR for it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-14-2013, 03:20 PM   #9129
mcma111
mcma111's Avatar
Oddometer: 12,101
Focal,
You have a starter on your XR??? I thought you sold the XR a long time ago.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-14-2013, 06:20 PM   #9130
drakehouse
Burnin' & Turnin'
drakehouse's Avatar
Oddometer: 122
suggestion on motor work
I'm doing a top end that includes:
new valves - springs - piston .25 over minor o rings gaskets etc.
Is there more I should do?
Should I go deeper into motor. Looking at the cost now as to cost later for another neec I could do now.
Any guidance?
Riddin' for a Livin'
Best to swim against the curent than float down stream
drakehouse is offline   Reply With Quote
Old 11-14-2013, 08:17 PM   #9131
mcma111
mcma111's Avatar
Oddometer: 12,101
drakehouse,
Why valves and springs? Using the OE cam? Then it's unnecessary. What compression ratio is the piston?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-14-2013, 08:51 PM   #9132
drakehouse
Burnin' & Turnin'
drakehouse's Avatar
Oddometer: 122
I took my head and cylinder in to a local shop. (Not dealer related).
He measured springs said outer spring in check. Innet spring are out of spec -too short.
Intake valves are mushrooming -exhaust are pitted. He measured cylinder and reports that it will need enough work to true it so .25 over clean it up. So new piston.
No report on what compression will be when complete.
My big question is cost savings.
I'm this far in to motor - IS there better money spent NOW that may save labor or other cost digging into motor next summer or winter?
Labor and parts above is in the $700 range.
Old 11-14-2013, 09:05 PM   #9133
lucknau
Greenhorn
lucknau's Avatar
Oddometer: 194
Call all XR600R!!!
Whether you need a battery for DC depends on the reg/rect you buy. There's more than just a diode bridge rectifier in the device. Your stator will put out over 50V when your rpms are high enough, and the reg/rect, when it senses greater than around 12 V to 15 V, will drop its output to about 1.5 volts over what it expects to see as the common voltage (i.e. from the battery). If there's no battery, then the common voltage is 0, instead of 12.6. The result is that without a battery all of your crap might work when you're idling, and won't work at all when you're going.
AC or DC is fine for an LED. With AC, though, the LED is off half the time, even though you might not perceive it visually. For both AC and DC, unless there is something limiting current, when lit, an LED is actually a short circuit. The comment above about inline resistors was right. You lose the energy saving bonus if you use an inline resistor. You still get more longevity out of an LED than a bulb, though, unless it's a poorly assembled device. I think the resistor method is a viable option, as a cost saving measure, but really, if you use LED signal bulbs, you ought to eventually spring for an LED flasher relay. The power electronics in the relay will limit current with transistors, and spare that extra power for your toys.
lucknau screwed with this post 11-14-2013 at 09:29 PM
Old 11-14-2013, 10:17 PM   #9134
focallength
You're Welcome
Oddometer: 4,790
Focal,
yeah...wrong forum
Old 11-14-2013, 10:33 PM   #9135
Mike the Yank
Oddometer: 401
Vapor TrailTech will run on anything, 9-400 VAC/VDC no polarity required.
From their PDF http://gallery.trailtech.net/media/i...structions.pdf
Might free up another connection.
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Times are GMT -7.   It's 10:03 PM.
