Old 01-03-2009, 10:05 PM   #91
RidingQWERTY
RidingQWERTY's Avatar
Oddometer: 18
Originally Posted by bigtrailie
Have any of you found a good way to raise the handlebar height on your XR600? I once heard someone mention using an ATV bar, but I was concerned about the cables being long enough to accommodate the swap. What else have you guys tried?
Some shots of mine with the Zeta risers on top of the original risers - works great.
RidingQWERTY is offline   Reply With Quote
Old 01-03-2009, 10:33 PM   #92
etmoto
etmoto's Avatar
Oddometer: 480
The bar risers looks good with zeta.
etmoto is offline   Reply With Quote
Old 01-03-2009, 10:44 PM   #93
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,226
Originally Posted by lewismedlock
I haven't started my 600R for probably 9 months. I thought that today would be a good day to fire it up. Wrong. It hasn't had any gas in it. I guess that the cork in the petcock dried out because when I put some gas in the tank it leaked.
So, I'm airing out the shop now. Soon I'll go out and check out my petcock.
9 months..... that's how long mine sat, untouched, after I broke both wrists. It started on the first kick even with the old gas. I had mine (05 model) for 8 years. I sold it to a friend who only rides 2 or 3 times per year. He says it still always starts first kick after sitting for months and months. If Honda would bring the xr 600 back with e-start and a 6 speed it would be a huge success.
rufus is offline   Reply With Quote
Old 01-04-2009, 06:54 PM   #94
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 680
Zeta???
Thanks for the photo RidingQWERTY. It looks like you have stacked two lower "riser" sections mounted. Is that correct?
It appears to be:
Stock triple clamp bar mount under a thin riser, under a thicker riser, then bar, then the upper.
I'd be interested in duplicating your set-up. Any problems with throttle cables binding? Thanks again.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 01-04-2009, 07:34 PM   #95
lewismedlock
lewismedlock's Avatar
Oddometer: 13,440
Mine started on about the 10th kick. It's an 86 and I'm the original owner. It doesn't idle worth a damn. I'm going to run it for a while with some Seafoam in the tank. I hope that cleans it out. If not, I'll have to take the carbs off, and twin-carbs are no fun to work on.
I agree with you about bringing back the XR600R. I'd line up to buy an e-start 6 speed.
lewismedlock is offline   Reply With Quote
Old 01-05-2009, 12:43 PM   #96
RidingQWERTY
Oddometer: 18
It appears to be:
When I bought it the fat bars were on it with the small riser which really is just an adapter for the fat bars (Taper Contour CR High bend). The riser I added is a Zeta SX Bar rise kit for 28.6mm bar which gives a 30mm lift (part no. ZE53-0230). Just went straight on bolting into the adapter with the standard bolts. No problems with cables binding at all.
Old 01-05-2009, 01:09 PM   #97
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
You guys looking for bar risers, I saw another set up from a company called Rox that looked very slick. I saw them on one of the XR600 threads here on ADVrider but I can't remember which one, sorry. A google search of Rox will locate the company I should think.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 01-05-2009, 03:57 PM   #98
Bronco Driver
Bronco Driver's Avatar
Oddometer: 175
Xr600r
I am of the opinion the XR600R is perhaps the best do all M/C ever built.
I spent years trying to build a Bike to ride to work/play and race(Usally an alchohol induced thought--Egged on by my riding partner.)
THEN-------I purchased a '95 XR650L-------
Then started transformation.
STRIPED Everything off that was not needed. frame tabs,smog crap haust,stock forks and shock.
Replaced suspension with XR600 pieces(I revalved,springs etc).
built my own pipe center section.Installed Super Trapp.
Fabricated my own dual light system.Rewired complete.(stock wiring harness almost 5 lbs).
Installed HRC 628 cam,springs etc.Degreed cam.
4 gal IMS tank.custom lowered seat.
The result------285 lb(dry)ELECTRIC START XR600
2006 XR650R with too much stuff.
Bronco Driver is offline   Reply With Quote
Old 01-05-2009, 04:06 PM   #99
Bronco Driver
Oddometer: 175
Los Gatos,Ca.
I was born in Los Gatos.
(Old stuff)---AS A KID,WE WOULD RIDE OUR BIKES UP OVER SHANNON RD. TO GUADALUPE DAM TO MT.UMINUN TO OLD SOQUEL HWY. TO TWIN LAKES BEACH .PLAY IN THE OCEAN AND RIDE BACK HOME ..
Old 01-05-2009, 04:44 PM   #100
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Uh... Photos?!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 01-05-2009, 06:20 PM   #101
motowest
Two-wheeled Adventurer
motowest's Avatar
Oddometer: 1,300
Originally Posted by Zombie_Stomp
Uh... Photos?!
yeah, pics please!!!!!
motowest is offline   Reply With Quote
Old 01-05-2009, 08:39 PM   #102
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,338
I'm ordering a set of Rox risers for mine. Even with CR Hi tapers on TAG adaptor/risers, I need a bit more rise for standup riding.
http://www.roxspeedfx.com/cgi-bin/ca...?subcat_id=268
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 01-06-2009, 03:47 PM   #103
Owyhee
Ran when parked
Owyhee's Avatar
Oddometer: 559
I'd have to say that I love my XR600! It's fresh... still has the factory chain from 1999... but it has to be the most reliable thing I own.
After sitting since Dec of 1997 (gas drained) it started on the second kick and ran without stalling! Granted, the carb's float bowl gasket is weeping a bit but fixing that can wait... must ride!
"O"
Owyhee is offline   Reply With Quote
Old 01-06-2009, 04:15 PM   #104
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,895
Mine starts pretty easily after long periods in the garage. Currently I'm trying to contact a local gun welder to fix the rear of the subframe, it's cracking off. I think he's on holidays, but I won't trust the job to any old welder.
And yes, a six speed electric leg XR600R would cause me to sell some other stuff to buy one, air-cooled and all. I love these things, if only I could find a comfy seat!
GodSilla is offline   Reply With Quote
Old 01-06-2009, 04:25 PM   #105
Bronco Driver
Oddometer: 175
Go to The Rally Moto thread.
Times are GMT -7.   It's 04:27 AM.
