Old 04-19-2013, 09:00 PM   #7681
schnutzy
schnutzy's Avatar
Oddometer: 402
Originally Posted by shipman View Post
I wear these over my Doc Martens in the rain, and they keep me dry:
http://www.cyclegear.com/CycleGear/B...9823_59409_199
awesome, that looks like a pretty cool solution
"While it may be to early to drink scotch, it is never to early to think about drinking scotch."
2012 Suzuki TU250x
schnutzy is offline   Reply With Quote
Old 04-24-2013, 03:25 PM   #7682
RidesBeside
Oddometer: 1
vivapowersports.com in El Paso has one now
Originally Posted by LuciferMutt View Post
Suzuki hasn't axed production of this bike yet, have they? I still want one...
Yes I know you can buy used, but these things are rarer than hen's teeth in ABQ...
Saw one today at vivapowersports.com El Paso. 915-834-2305
Good Hunting..
RidesBeside is offline   Reply With Quote
Old 04-24-2013, 04:15 PM   #7683
Bob Loblaw
Oddometer: 1
Got one of these about two years ago (un-red model), put 6k miles on it, then had to put it away for around 8 months. Was a little bit worried that it wouldn't start after all that time (I forgot to disconnect the battery), but it fired right up!
Great little bike!
Bob Loblaw is offline   Reply With Quote
Old 04-25-2013, 01:56 PM   #7684
Reconstructed
Oddometer: 251
Reconstructed is offline   Reply With Quote
Old 04-25-2013, 02:06 PM   #7685
TomSXM
Oddometer: 12
Enjoying mine so much, I've put my Aprilia up for sale
(Contact me if you're interested - '09 Mana 850, 2'042 miles)
TomSXM is offline   Reply With Quote
Old 04-25-2013, 07:01 PM   #7686
Txjack
Oddometer: 28
Lights?
Anyone know if the speedo backlighting is fused? Went for my first night ride after getting new tires& inspection. Thanks NJ-Brett on suggestions for gearing & tires, made quite the difference! p.s. bright lt. indicator works just fine.
Txjack is offline   Reply With Quote
Old 04-25-2013, 08:40 PM   #7687
jhancock
Oddometer: 13
Thanks! Sounds like aftermarket weights would be double that weight and might help w/vibration.
jhancock is offline   Reply With Quote
Old 04-25-2013, 09:09 PM   #7688
rycomm
rycomm's Avatar
Oddometer: 343
I found the same problem on mine on the first night ride. It was a bad bulb. I think it was $2 for two. It is a 1.7 w bulb. There is only one. I think it is 2 10mm nuts that hold speedometer to the top clamp, and 1 Phillips screw that holds the housing in place. The mounting bolts are carriage bolts ,so don't scratch them up holding them with pliers like I did.
Ryan
07 DL650,[COLOR=blue] blue[/COLOR]
07 DRZ400, also[COLOR=blue] blue[/COLOR] for sale
[COLOR=silver]11 TU250X, not [/COLOR][COLOR=blue]blue[/COLOR]
09 WR250R, do these come in any color other than [COLOR="Blue"]blue[/COLOR]?
former rides:98 KLR650, 01 SV650 (another [COLOR=blue]blue[/COLOR] bike),89 KLR650, 92 Bandit 400
rycomm is offline   Reply With Quote
Old 04-26-2013, 07:51 PM   #7689
Moto13
Riding to Relax
Moto13's Avatar
Oddometer: 362
Headlight out...
Hey everyone...Riding season started here in Maine about two weeks ago.
I rode for a few days before encountering a problem. I came out of work at midnight and found my headlight no longer working. I followed my work mate home and have since been trying to figure out what's going on. Here's what I've done so far:
1. got a new lightbulb at VIP...put the new bulb on and ... no go. I inspected both bulbs, and neither seems to have broken filaments.
2. I then thought it must be the fuse. I switched the extra fuse for the one in the slot for the headlight ... still no go.
3. I put the extra fuse and the one that was originally in the headlight slot in the turn signal slot - they both work. I inspected them manually, and of course there's nothing wrong with them. So the problem is not with one of those fuses..
4. I looked at the 30 fuse (main fuse), but I can't get it out...I've never dealt with fuses, so I'm not sure how much I can pull without breaking it. Either way, it makes no sense to me that the main fuse would be broken if everything else on the TU still works.
The TU starts without a problem, the rear light, turn signals, and lights on the dash all work... the only thing that does not work is the headlight.
So... any ideas?
[COLOR=orange]2011 Suzuki TU250X[/COLOR]
For strange effects and extraordinary combinations we must go to life itself which is always far more daring than any effort of the imagination.
- Sherlock Holmes (Sir Arthur Conan Doyle)
Moto13 is offline   Reply With Quote
Old 04-26-2013, 08:34 PM   #7690
theUg
Oddometer: 25
Cool2
So, I lurked here long time ago, but then got busy riding TU, so I let this thread to run away. I am now working through it, but still have over 200 pages to go through, so it’s going to take some time still. But I figured I’d introduce meself before everyone participating in this thread crushes to death or sells the TU. Am active on tu250riders.com, though.
So, I have 2011, which I bought that summer, thus it’s almost two years old. I have over 8000 miles on it. No issues whatsoever, save for the usual speedo cable freezing every winter. It’s my primary mode of transportation, day or night, rain or cold (my car has some issues, and I hadn’t bothered to fix since I bought this bike), but I try to avoid needless driving, unless I go on the joy ride or a trip of some sort, hence not a lot of miles. Plus, I commute on the bicycle or the bus to save money sometimes as well. First time owner (I dabbled before but I was fixing my 1971 SL125S more than I ever rode it). MSF, gear most of the time, helmet always.
It’s pretty much stock, save for the 16t sprocket I just put few weeks ago. Still getting used to it, but the stock gearing worked fine for me as well (since I’m first-timer, I don't know any better). I went on 1050km (650 mi) roundtrip in the mountains recently, motorway and state highways, had no trouble keeping 70-75 mph (indicated) with 40 L luggage bag strapped on the back seat, though at times could go faster, but didn’t due to watching my mileage. Also did few trips on dirt, including 190km on forest roads couple years back. The only big trouble spot for me was 2100 m (7000 ft) pass on I-80 in Nevada where I struggled to keep up 55 mph WOT, but I didn’t mind. Besides, trucks were slowing down to almost 40 on that pass, so who cares.
I’ll get more details and pics from those journeys later once I sort some stuff out, but here’s the story of how I smoked a Hardly at the streetlight at downtown Boise (Front and 8th pedestrian crossing) few days ago on my two-fifty. Big-ass loud-pipe bobber style, ape hangers and all, with greaser-type Michael Madsen look-alike at the bars (no gear, obviously). I rolled up in the next lane, gave him a sideways glance. He reciprocated, and rolled a throttle emitting mighty growl.
So, I figured he wanted to play. Obviously, he doesn’t expect much of vintage looking 250, so he wasn’t trying too much. But I took off so hard that I was able to switch into his lane within the first 30 metres so I could make the hole in traffic, leaving him in the dust roaring like a wounded beast behind my back. I think I made him upset, as he was gunning 50 in the 35 speeding away to the Connector few moments later. All the while I was almost laughing with a big TU grin.
2011 Suzuki TU250X
theUg is offline   Reply With Quote
Old 04-27-2013, 07:42 AM   #7691
Prettyboy
BFLB
Prettyboy's Avatar
Oddometer: 566
Well, I got one, and here she is.
It's going to take a while before I can ride, largely because I don't know how, and my MSF course isn't for a few weeks, but especially because the title is going to take 4-6 weeks to get to and from Harrisburg. Ugh.
Prettyboy is offline   Reply With Quote
Old 04-27-2013, 10:49 AM   #7692
Rhompin45
Rhompin45
Oddometer: 251
Well it's a great bike to learn on. They are very forgiving going from being stoped. You don't need a lot of Rpms to get it going and if you rev it to much and let the clutch out you don't really have to worry about the front tire coming off the ground. And if your coming to a stop alittle off balance it's light enough you can catch it with out it falling over. What year is it 11 or 12 how many miles? It looks good.
Rhompin45 is offline   Reply With Quote
Old 04-27-2013, 12:31 PM   #7693
DavesNotHere
Aging squid
DavesNotHere's Avatar
Oddometer: 310
Got a new TU250X today
2014 [COLOR=Red]Red[/COLOR] Honda CBR500R / Location: Colorado
DavesNotHere is offline   Reply With Quote
Old 04-27-2013, 12:59 PM   #7694
Rhompin45
Rhompin45
Oddometer: 251
Are the rear shocks different on the 13 from the pic it looks a little different other than the spring being black?
Old 04-27-2013, 01:02 PM   #7695
Rhompin45
Rhompin45
Oddometer: 251
It looks like there are 12 coils vs 11 on my 2012? Right? Kinda hard to see on my phone
Times are GMT -7.   It's 04:47 AM.
