Old 07-17-2013, 03:23 PM   #8011
schnutzy
schnutzy's Avatar
Oddometer: 402
Originally Posted by elmerf View Post
Hahaha ... good catch!
I've been looking at that lustfully for a few days now and finally gave in to temptation and talked to the guy last night.
The craigslist seller got it from a guy in Flagstaff and is hoping to flip it ... which means that it MIGHT just be the nice sounding bike that's mentioned on tu250riders.com from Flagstaff with its missing chain guard.
seeing as how the bike on craigslist doesnt have a chain guard i would guess that to be correct.
"While it may be to early to drink scotch, it is never to early to think about drinking scotch."
2012 Suzuki TU250x
schnutzy is offline   Reply With Quote
Old 07-17-2013, 03:27 PM   #8012
schnutzy
schnutzy's Avatar
Oddometer: 402
so my TU has started squeaking....
only happens when i move forward, doesnt happen if i am just at a light and rev it a little.
i really notice it in second and third gear, or sometimes if i am turning a sharper left hand turn. I am kind of assuming the noise is there all the time, i just cant hear it(due to wind noise, etc) all the time. any body have any thoughts or ideas? i wont have time to investigate till saturday, hopefully it doesnt get to bad tomorrow
2012 Suzuki TU250x
Old 07-17-2013, 07:21 PM   #8013
flammenwurfer
Oddometer: 5
OK tu experts. I think I've decided to pick one up and have found a used 2011 near me with 600 miles on it for $2900. Thing is it's at a car dealership. Every vehicle I've ever bought was from an individual. So how does it work buying from a dealership? Any tips on negotiating a price lower than asking price? Should I take cash and be like I have $2500 right here, give me the bike! :)
flammenwurfer is offline   Reply With Quote
Old 07-18-2013, 08:34 AM   #8014
shipman
don't sweat minutiae
shipman's Avatar
Oddometer: 202
That's exactly what I would do. The worst thing they could do is say no.
Jamie / Bedford, Texas
2011 Suzuki TU250x
I urge you to please notice when you are happy, and exclaim or murmur or think at some point, If this isnt nice, I dont know what is. Kurt Vonnegut
"The secret to happiness is realistic, modest expectations" - Barry Schwartz
shipman is offline   Reply With Quote
Old 07-18-2013, 08:48 AM   #8015
Trailrider200
Trailrider200's Avatar
Oddometer: 342
brake pads. my DR200 does it with the OEM organic pads. if the TU's are sintered bronze they will/could do it also.
1981 CB900C, 1998 GL1500C Valkyrie
2007 DR200
"Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other."
John Adams 10/11/1798
"If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan
Trailrider200 is online now   Reply With Quote
Old 07-18-2013, 09:16 AM   #8016
LoopGaroo
Oddometer: 244
Any advice on getting the big flat-head bolt out of the center of the stator cover? I'm going to check the valve clearances today and the last time I tried to remove that bolt my biggest screwdriver (BIG) kept slipping out and marring the bolt. Last time I resorted to finding TDC by jacking up the bike and turning the rear wheel...
LoopGaroo is online now   Reply With Quote
Old 07-18-2013, 12:53 PM   #8017
NJ-Brett
Brett
Oddometer: 6,719
Tap it loose with a flat face drift.
NJ-Brett is online now   Reply With Quote
Old 07-18-2013, 01:44 PM   #8018
blugg1
Oddometer: 506
I haven't read all the previous posts, but for what it's worth, I bought a red TU250 a couple of years ago, primarily because it just looked cool and for mainly around town trips. Turned out to be basically bullet-proof. Never failed to start instantly. At the time I had an SV 650 for out-of-town travel (turned it into a DR 650).
However, don't expect much zoom from the engine. It likes 50-55 mph, but above that it's clearly out of its comfort zone. I installed a one tooth larger front sprocket. Helped a little bit.
Suspension is minimal; perfectly OK on smooth pavement, wretched on bad pavement. Does not like dirt roads, but then most street bikes don't either.
Seating position is great, unless you're a big guy. I'm not, so it was fine for me.
I finally sold it and bought a 2012 SYM HD 200 EVO. Oddly, it has a much higher highway cruising speed (65-75 mph) than the TU 250. Go figure.
2014 Kawasaki 300 Ninja, 2012 SYM HD200 EVO
blugg1 is offline   Reply With Quote
Old 07-18-2013, 05:08 PM   #8019
Slapie
Slapie's Avatar
Oddometer: 32
Squeak
Shnutzy, I had a weird squeak coming at odd times a few weeks back. I traced it to the speedo cable. Took it off at the tire and some water came out. So I took the inside cable out and greased the hell out of it. Cleared up the squeak for about a month but now it's starting to do it again. Hope this helps.
Slapie is offline   Reply With Quote
Old 07-18-2013, 06:55 PM   #8020
jhancock
Oddometer: 13
I had to replace my speedo because of the water and corrosion in the cable. Still under warranty, so 'Zuki picked up the cost. Anyone find a "fix" to seal the cable conduit better, or do I need to add this to my routine lubrication schedule, too. What to use - PJ1 cable lube?
Sent from my DROID4 using Tapatalk 2
jhancock is offline   Reply With Quote
Old 07-18-2013, 08:01 PM   #8021
schnutzy
schnutzy's Avatar
Oddometer: 402
both things i shall look into.
thanks guys
2012 Suzuki TU250x
Old 07-18-2013, 08:19 PM   #8022
Cruisin'Carolina
Cruisin'Carolina's Avatar
Oddometer: 204
Probaly the best succinct post in the thread
Buy my TU250x!
http://www.advrider.com/forums/showt...5#post21806265
Cruisin'Carolina is offline   Reply With Quote
Old 07-18-2013, 08:41 PM   #8023
blugg1
Oddometer: 506
Cruisin'Carolina,
Thanks. Just felt like cutting to the chase.
Old 07-19-2013, 08:15 AM   #8024
shipman
shipman's Avatar
Oddometer: 202
I can't argue with that assessment, but I also feel it may lean too far in the direction away from fawning enthusiasm and makes it seem like the TU250 can't really do above 55mph. I routinely ride my TU in the 65-75 range on the freeway (actual not indicated).
2011 Suzuki TU250x
Old 07-19-2013, 08:45 AM   #8025
moto827
Oddometer: 11
Also account that the top speed increases with the High Mileage Break-In period for the TU...
moto827 is offline   Reply With Quote
Times are GMT -7.   It's 07:32 PM.
