Old 03-14-2013, 06:07 PM   #91
red450
WEE-A-BOO
red450's Avatar
Oddometer: 309
Originally Posted by jjdavidson View Post
red450, i made them DIY :(
They look good! I agree, some thermal barrier might be a good idea.
red450 is offline   Reply With Quote
Old 03-14-2013, 06:35 PM   #92
boatpuller
Oddometer: 480
Those are just too cool! (That's a good thing if American slang does not translate well.)
You have to provide better pictures of the frame you built, and details on the tanks themselves, please.
boatpuller is offline   Reply With Quote
Old 03-15-2013, 10:05 AM   #93
jjdavidson
jjdavidson's Avatar
Oddometer: 46
something about how i made them
Thanks.
Ok, i'll try to tell some building instructions. As you see my pics are not so clear, but hope you'll get the idea.
I have 3 mounts for the racket. I had LSL-crashbars where i got 2 and one to front of engine:
left
right
and third mount's place
These are all straight to engine, so they all vibrate the same.
I started making a frames around canisters just cutting and bending some L-shaped steel. Then i sighted them to their places and measured where i wanted to weld mounts (LSL-mounts).
left one here:
Now i could tighten canister frames to their places. I measured the cap beetween canister frames and cut some tube and welded upper and lower tube to canister frames to connect them as one unit (ofcourse i did all welding stuff out of bike). Then i measured where i could weld third mount. And again put this rack on it's place to bike. Now i could thinkabout where to put more tubes to make rack more rigid. Also i added 2 tubes to protect regulator. They are remowable, there's a threaded rod (M6) inside of stainless steel tube (i had to make something that shines...) and dome nuts.
Finally i welded strap holders and painted hole thing.
Something like that, i hope this clears how i made it.
I don't know who is manufacturer of these canisters, but they are made of steel and i think quite good quality. I have one tied to my SkiDoo, and i haven't noticed any leaks even i'm pretty often down and stuck into snow...
And i'm so sorry about my spelling
jjdavidson is offline   Reply With Quote
Old 03-20-2013, 02:37 PM   #94
unlucky1
unlucky1's Avatar
Oddometer: 232
I did some minor adjustments to my Uly's timing and fueling, and it's like a whole new bike!
My timing was WAY advanced - when checking it in prep for my Texas trip this spring, the mark was way left of the hole when the CAS switched over. Maybe that's why I only was getting 33mpg!
I also backed up the 13.6-AFR-across-the-board dyno maps and flashed the Buell race maps onto it and it is way more well-behaved around town and seems to warm up faster and transition on and off throttle smoother.
Now I can run it from 1500-3000 really smoothly where before I used that as a transitional range, and the really super-strong engine braking I was getting from the advanced timing is much more relaxed... gotta re-learn how to ride it now!
2006 Buell Ulysses
1976 Yamaha DT175
1978 Honda XL175
unlucky1 is offline   Reply With Quote
Old 03-21-2013, 07:08 PM   #95
Mr Mark
Oddometer: 25
Fellow Ulyers"..dont know if its kosher to ask on this forum but I was wondering how long it takes after registering over at Badweb. Been weeks, haven't received the activation e-mail, wrote to a moderator.....nothing.......is this normal? Thanks...
07 FJR1300A
06 Uly
72 Commando/Dunstall 810
Stay tuned....more to come.....
Mr Mark is offline   Reply With Quote
Old 03-21-2013, 07:46 PM   #96
red450
WEE-A-BOO
red450's Avatar
Oddometer: 309
I had to submit a few registrations before I finally got the email.
Old 03-22-2013, 02:06 PM   #97
argentcorvid
Some Guy
Oddometer: 481
their messaging system (and entire forum software) is shitty. try every couple of weeks and/or check your spam folder. PM's from users there go missing frequently.
argentcorvid is offline   Reply With Quote
Old 03-25-2013, 06:59 PM   #98
euromedic
Peter...n00b
Oddometer: 145
Originally Posted by scapegoat View Post
I have a Madstad on my 06 and its great. Im 6"3" and get 0 buffeting.
I look forward to similar results, ordered mine today.
Peter
euromedic is offline   Reply With Quote
Old 03-26-2013, 05:01 PM   #99
argentcorvid
Some Guy
Oddometer: 481
California scientific makes a good one too, its a little big though.
Posted during work using magic
Old 03-26-2013, 06:46 PM   #100
lowriderglen
Oddometer: 18
Madstad
My new Madstad arrived today for my '06 Uly. I hope it will warm up enough this weekend to try it out.
lowriderglen is offline   Reply With Quote
Old 03-27-2013, 04:11 PM   #101
unlucky1
unlucky1's Avatar
Oddometer: 232
If you run the Buell long enough, it will be warm enough
2006 Buell Ulysses
1976 Yamaha DT175
1978 Honda XL175
Old 03-31-2013, 03:20 PM   #102
Mr Mark
Oddometer: 25
First hundred miles today....what a hoot this thing is.....very happy......I'm beginning to understand the passion for these beasties.....
That being said, I wanted to share what I did with my muffler to keep it from rotting off in a few months....maybe......lucky enough to only have 1400 miles on the bike, i took the can off, gave it a light sand blast(not much paint on it from factory, kinda understandable why they rust out) , cleaned and prepped, primed and two coats of POR15. Able to withsatnd 600 degrees after it cures,and i fugured after using and seeing it used in close proximity to high performance headers etc, that and I had some in the shed........ it should help......we'll see.....anyone else do anything like this? No sign of trouble after the hundred mile ride....no blisters etc.....
07 FJR1300A
06 Uly
Old 03-31-2013, 05:38 PM   #103
lowriderglen
Oddometer: 18
Por 15
Good idea.....I may try that myself. Just had not thought about that product.
Old 03-31-2013, 08:54 PM   #104
euromedic
Peter...n00b
Oddometer: 145
Another content Madstad customer added.
Peter
Times are GMT -7.   It's 06:19 AM.
