11-27-2012, 05:07 AM
#18796 |
What? Where?
Oddometer: 714
Toddzacker,
Jeff is 100% spot on with the tourance tkc combo recommendation. I used to run that combo on my V-Strom and will be going that way again on the GS. An interesting aspect of that set-up is your front and rear will both wear at the same rate, so at about 10k +/- you will need both. Shoe Creek is very do-able on a GS, and honestly isn't all that bad. If you want to give it a try I would recommend starting with a few days over at the newly found "training area" here in town. I would also highly recommend waiting until the creeks drop in the summer and riding with a partner. I was being stupid when I tried it for the first time, 1 it was spring and the creeks where up, 2 I rode it alone, 3 my rear tourance was completely bald. Anytime you want to give the training area a go on the GS just let me know, its a hoot out there!! Only thing keeping away this weekend is the absence of a skid plate, courtesy of last weekend.
-07 R1200GS -03 525EXC IBA# 34681 (SS1000) "luck played a fundamental role" Carlo Boffi |
11-27-2012, 05:11 AM
#18797 | |
What? Where?
Oddometer: 714
That's Great!!! My bike needs a mullet!!! Although I guess its kind of in reverse, party in the front business in the back.
11-27-2012, 05:36 AM
#18798 | |
NO FILTER
Oddometer: 475
I am planning on the training area Saturday for sure & maybe Friday a little. I have all the parts & pieces for the stock skid plate if you would like to use it & them I get you by. I will be in town Wednesday & Friday if you want me to bring it up. Let me know its just collecting dust. On Shoe Creek, would a dry late fallow a reasonable run? Before to much snow & to cold of temps? If I feel comfortable after this weekend, I would like to run up and do a little more challenging stuff Dec 7-9, weather permitting.
"That is one good tasting pickle", Jersey '12 BMWR1200GS '06 F650GS '00 KLR250 '06 RMZ250 |
11-27-2012, 05:56 AM
#18799 |
What? Where?
Oddometer: 714
Todd,
I think I am going to wait until I get a new skid plate before going back out there. A broken case on a Yamaha at the last Cat Herders Campout has got me spooked. I would stay away from Shoe Creek until this Spring if I were you. The stuff out at the "training area" is plenty challenging.
11-27-2012, 06:51 AM
#18800 |
Hookers, my lad.
Oddometer: 6,220
How did I live without making one of these before?
![]() USB Mini (GPS) and Micro (Phone) fast charging from either USB adaptor or 12V socket. I suppose I could have added a switch to toggle between fast charging and data mode, but I think simple is better for this. It's awesome. I'll never not have the right cable. Well, unless I lose it, but I still do have the trident 3-way charger I made a few years ago. It's a linear regulator, though, so not nearly as efficient as a the buck converter on this one and doesn't have USB charging.
"I'm half afraid Skippii's bike might actually be a giant hamster ball that he somehow powers around. With ape hangers." -GailCallsMeKarl |
11-27-2012, 07:47 AM
#18801 | |
Skid plate tester
Oddometer: 1,454
Actually looks pretty cool. Only question is why bother with the separate 12v cig plug. I have a 12v to USB plugs that I use to power my GPS via a USB cable as it is. All I have to do now is have the right cable and I am good to swap. I do like the idea of having a single USB cable with both ends and configured for fast charge though. I might have to google what to do to make one. I know you posted it before. One of my grips is my GPS spending a minute trying to make a USB data connection when I plug it in. Disconnecting the data pins would take care of that i think.
2009 Wee-Strom, 2008 WR250R |
11-27-2012, 08:15 AM
#18802 | |
Oddometer: 7,670
Only comment is why not heatshrink instead of electrical tape? Would have made for a neater job and a heckofalot more durable. .
GB Young Services, LLC Garage Project: http://gbyoung2.smugmug.com/Family/G...11686385_YA8pi |
11-27-2012, 08:22 AM
#18803 | |
Hookers, my lad.
Oddometer: 6,220
I do like the idea of having a single USB cable with both ends and configured for fast charge though. I might have to google what to do to make one. I know you posted it before. One of my grips is my GPS spending a minute trying to make a USB data connection when I plug it in. Disconnecting the data pins would take care of that i think.[/QUOTE] No, you don't disconnect the data pins. You connect them together. White and Green get connected so that the GPS recognizes that it is not plugged into a computer and will pull over an amp of juice out ("fast charge"). If the data pins aren't connected, the GPS thinks it might be connected to a computer, and drawing that much current from a usb port on a computer can damage it, so even if it does go out of "data mode" it will be in "slow charge" mode. On larger displays, this also limits the screen brightness to less than 10%, making it pretty useless other than at night. The same thing goes for cell phones. My phone will even tell me that it's charging really slowly if I don't use the right cable. (Most AC-USB adapters will short the pins on the charger, so you can use a data cable with no problem.) Some older ones leave them open.
11-27-2012, 08:28 AM
#18804 | |
Hookers, my lad.
Oddometer: 6,220
This wasn't really what I've been working on all night. I was actually making a dual constant current source for running LED strings with varying input voltages and # of LEDs. Came out well, runs up to 7 LEDs at 18mA on each transistor with up to 16V supply. It's not as temperature stable as I'd like, but it's good enough.
11-27-2012, 08:31 AM
#18805 |
Oddometer: 20
![]() 'Sorry I missed you guys on Sunday, Saturday was Fun on the YZ, riding with a broken clutch cable definitely improves your cornering speeds. The important thing is...... I Won !! It only cost me eight stiches in my leg.....DOH ! No worries, everybody knows Bumbles Bounce ! Let's do it again soon.Cheers, Bobb |
11-27-2012, 08:44 AM
#18806 | |
Oddometer: 7,670
#18807 | |
squirrel
Oddometer: 1,126
Thinking we needs us some clapped out kdx's to run in the vchss sportsman/oldtimers class, then we can really get out there and break some clavicles with Bob!
11-27-2012, 02:32 PM
#18808 |
BTBlueSkies
Oddometer: 95
11-27-2012, 02:39 PM
#18809 | |
Oddometer: 380
MMmmmmm stitches......always fun!! bet it is muddy back at mud mart today!!! |
11-27-2012, 03:09 PM
#18810 |
NO FILTER
Oddometer: 475
Hopefully it dries up by Friday or I'm gonna be a dirty boy...then Nicole will have to bath me. Actually now that I think about it...I hope it muddy as hell!!!
