Thread Tools Rating: Thread Rating: 7 votes, 4.14 average. Display Modes
Old 02-06-2011, 05:12 AM   #1516
RogueClimber
"Tacticool"
RogueClimber's Avatar
Oddometer: 934
Hey Smithy
That steel shot adds a certain uniqueness. Great work!
"To the everlasting glory of the Infantry!"
Diligentia -- Vis -- Celeritas
Rob
Save $5 on SmugMug-- zpTBLRFvcME2c
RogueClimber is offline   Reply With Quote
Old 02-06-2011, 06:31 AM   #1517
Honda Scoot
My First Gold Chain
Honda Scoot's Avatar
Oddometer: 299
Did you cast an over sized guard and drop the in the steel shot?
Quite unique - thinking out of the box!
Honda Scoot is offline   Reply With Quote
Old 02-06-2011, 08:50 AM   #1518
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 6,722
Natural materials used on knife handles have a tendancy to shrink or expand, depending on humidity and temperature. Stabilizing them with a polymer solution (I think) replaces all the little air pockets and moisture, so it can't wiggle around and cause gaps or warp or do unpredictable things later on. Poorly stabilized wood has a very plastic look to it - this batch I'm using looks really good to my eye. It's a little heavier than normal wood would be, and is more costly, but it makes for a very high quality handle.
The bronze guard was made by melting about a pound of bronze in a crucible, and adding a cup or so of steel shot, until it was all good and mixed. I then cut out a variety of blocks for use in future guards or other little bits. Casting the guard to shape would have meant very few of the steel shots being exposed, since cutting through their cross section was needed to get the desired effect. It's the first time I've ever seen it done quite this way, and I'm very pleased with how it turned out.
Chris, Proprietor of The Tidewater Forge
Hot iron is my passion. Fire is my mistress. Let's dance.
Smithy is offline   Reply With Quote
Old 02-06-2011, 09:00 AM   #1519
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,073
Let's say that knife goes through a few temp changes.
Is there not a chance those steel parts could work themselves loose from the bronze?
Or do something else weird?
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 02-06-2011, 09:42 AM   #1520
Honda Scoot
My First Gold Chain
Oddometer: 299
Brazed in place
Old 02-06-2011, 02:39 PM   #1521
Smithy
Smithy's Avatar
Oddometer: 6,722
There's an outside chance that any steel piece, not anchored in place by being more than 50% inside from the cut, could come lose at some point - but it would take significant force to dislodge it, not mere temperature variations. They were added to the bronze at around 2200* F.
Old 02-06-2011, 02:40 PM   #1522
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,073
Huh.
Old 02-06-2011, 07:39 PM   #1523
old2wheeler
Former nÔÔb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 710
Wink
The bronze forms a shot shaped sphere around the shot. As long as the bronze hollow sphere goes more than half way around the shot, the shot is captured by the bronze... Ain't likely to come out.
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Old 02-06-2011, 08:08 PM   #1524
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 7,763
That wood is beautiful
I would think heavy is good.
How many hours are you into a knife such as this?
Day Trippin'- Endless Utah
Signal is offline   Reply With Quote
Old 02-06-2011, 08:34 PM   #1525
Smithy
Smithy's Avatar
Oddometer: 6,722
I've never been able to keep an accurate count, as I'm usually multi-tasking several phases of several projects. Figure a couple hours for the forging, a couple more at the grinder, some time to visualize the whole piece... an hour to heat-treat, descale, and 2 more hours to temper the blade... the guard material took an hour to make, another to segment out for a dozen different projects - another hour to grind to general shape, 2 more to cut the slot accurately... Figure a couple hours for the handle shaping, and another couple for fine-tuning everything.
I guess that comes to about 16 or so for a knife like this. I've done a complete blade in a day, but it suffers in quality, so breaking things out into steps certainly helps. One can get burnt out on inspiration, like any art, if one doesn't take time occasionally to just stand back and look at it. Coming up with the handle shape took me some time, and quite a few sketches until I found what I wanted.
If I had nothing else occupying my time, I suppose I could get a couple of these out a week, if it were my full-time job. Which still doesn't come close to replacing my current income, so I'm nowhere near ready to quit my day job. There are some places in the process that would benefit from either an assembly-line approach (heat treating in batches, for instance) or better tooling (a hydraulic press, a better grinder) that would cut hours from my work... but the art part of it just takes time and vision, and that's what makes a hand-made blade great, in my opinion. Metallurgically it should compete with anything factory made, but it must also have a soul, which is hard to get from a CNC-ground piece that has tight tolerances to perfect lines, and may even have some real artistic flow from it's designer, but lacks that X-factor a hand-crafted piece can have.
Old 02-06-2011, 08:48 PM   #1526
Chuck289
Air cooled
Chuck289's Avatar
Oddometer: 2,151
Another pic for no reason. BM 960
-Charles
"This is an environment of welcoming, and you should just get the hell out of here" - Michael Scott
Chuck289 is offline   Reply With Quote
Old 02-06-2011, 09:08 PM   #1527
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 7,763
Much better answer than my question.
Certainly the hands on approach lends itself to the soul of each piece.
Making a large batch, each the same, would certainly loose each knife's identity.
Certanly time intensive, and it shows. FWIW, I was guessing 20 hrs.
Old 02-06-2011, 09:34 PM   #1528
Smithy
Smithy's Avatar
Oddometer: 6,722
Speed comes with practice. For instance, forging would take me longer if I wasn't so comfortable with it. Same with grinding. I have a better sense, after a decade of doing this, where to stop with each grit and move to the next.
I always have to repeat to myself an essential mantra, though...
Slow is smooth, smooth is fast.
Works for lots of skills.
Old 02-06-2011, 10:18 PM   #1529
nimrod
Pog Mo Thoin
nimrod's Avatar
Oddometer: 563
Nice knife and really nice photo!
In my dream, the angel shrugged and said if we fail this time it will be a failure of imagination
and then she placed the world gently in the palm of my hand.
B. Andreas
"Betweem two evils, I always pick the one I never tried before" -Mae West
nimrod is offline   Reply With Quote
Old 02-07-2011, 01:23 AM   #1530
Chuck289
Air cooled
Chuck289's Avatar
Oddometer: 2,151
Thanks. Its too bad that knife is discontinued. Its been my favorite for the last 4 years
-Charles
Thread Tools
Times are GMT -7.   It's 06:35 PM.
