Thread Tools Rating: Thread Rating: 7 votes, 4.14 average. Display Modes
Old 02-25-2011, 07:02 PM   #1636
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 6,727
Originally Posted by TheOtherBart View Post
Smithy, let's say I wanted to make some simple fixed-blade knives. I've made one before, ground from a file, but without any kind of heat treatment either to anneal the steel before shaping or to harden and temper after. Is there a variety of steel that a guy with no heat treatment furnace could make decent blades out of? Something where the recipe could be as loose as "heat to cherry red and toss into some oil, then temper in your wife's oven when she isn't around"?
I would first reccomend learning about Decalescence, that phenomena that happens when carbon goes into/out of solution with the steel. That is "critical" temperature, and much lower than most people think. Cherry Red in strong light is too hot by a few hundred degrees. I posted an excellent series of photos here: http://paleoplanet69529.yuku.com/top...4/Decalescance
Once you heat the steel to that temperature, and the carbon goes into solution, hold it there for 30 seconds or so (for most simple steels... some super alloys need a longer soak at temperature), then remove and quench in warm oil. Old veggie oil is best, doesn't stink like motor oil, and won't stink up the oven when you go to temper it. Old files may be worked this way if you need to redo the heat treatment, then tempered at around 400F in the oven for a couple hours. Some recommend, as do I, a second temper cycle 24 hours later to catch any untempered martensite that converted after your first cycle was done.
To anneal it pre-grinding, heat to critical, then cool very slowly. If you have a forge, an easy method is to simply cut off the fuel supply and air, cover/close, and walk away... the inside will stay warm for a long time, often to the next morning. If you're unable to do that, a bucket of vermiculite or wood ash will do as well, but I often find that heating a second or even third large piece of scrap, and binding the one I'm working between them before putting into the bucket creates a much larger heat mass, that helps the slow-cool. This will soften file steel enough to make stock removal easier... then heat treat when done, as stated above.
And don't blame me when one cracks - it happens to everyone once in a while. Maybe because it's just tuesday. But this recipie should get anyone started.
Chris, Proprietor of The Tidewater Forge
Hot iron is my passion. Fire is my mistress. Let's dance.
Smithy is offline   Reply With Quote
Old 02-25-2011, 07:33 PM   #1637
TheOtherBart
TheOtherBart's Avatar
Oddometer: 1,463
Those are awesome pictures! So what's the best way for a schmoe in his back yard to get the blade up to the critical temp before giving it the french fry treatment? Charcoal grill? Oxy aceylene torch? Mother-in-law glare? And if I were to buy a stick of steel is there one or another more forgiving?
And incidentally I'm going to do this if for no other reason than to use up the 3 gallons of turkey fryer oil I have left over from Thanksgiving. Mmmmmmm, turkey steel...
TheOtherBart is offline   Reply With Quote
Old 02-25-2011, 07:57 PM   #1638
Smithy
Smithy's Avatar
Oddometer: 6,727
Torch will work, if you're careful. Grill will work if you're using hardwood lump, not briquettes, and are patient.
If you're going to go buy steel, I would reccomend a simple 10-series. 1070, 1080, or 1095 are all popular, and most are available from online suppliers. I use the New Jersey Steel Baron, myself, but smaller quantities can be had a little more easily from Admiral Steel - they have quality control issues I like to avoid, but for a beginner they're inconsequential.
Old 02-25-2011, 08:25 PM   #1639
TheOtherBart
Oddometer: 1,463
Excellent, thanks!
Old 02-26-2011, 07:29 PM   #1640
DirtyOldMan
Oddometer: 1,708
I'm fascinated by your craft. You are not only a craftsman but you are good at explaining stuff. Dunno if you teach this skill, but I believe you could.
04 250 RFS
99 640 ADV
13 650 Terra
DirtyOldMan is offline   Reply With Quote
Old 02-26-2011, 08:28 PM   #1641
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Schrade-Walden 153 UH
One of only two known to exist.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
The other one is NIB and is owned by a collector in Australia.
Stromdog screwed with this post 02-26-2011 at 08:40 PM
Stromdog is offline   Reply With Quote
Old 02-26-2011, 08:52 PM   #1642
Smithy
Smithy's Avatar
Oddometer: 6,727
Thank you. That's a touching compliment.
Old 02-26-2011, 10:05 PM   #1643
Motomedic
Motomedic's Avatar
Oddometer: 1,844
And yet another blade seems to have followed me home...
A CRKT Stubby Razel. Solid little chunk o'steel, and I was intrigued by the blade design. I'll report on it's usefulness later.
My name is Motomedic, and I am a knifeaholic.
Feike
Said James to Red Molly, Now Nortons and Greeves and Indians won't do- they don't have a soul like a Vincent '52
Motomedic is online now   Reply With Quote
Old 02-27-2011, 07:48 AM   #1644
GP640
GP640's Avatar
Oddometer: 2,944
I've been carrying a Razel for a year now.
Great tool but I would look for one with a bit of belly to the blade to
give more versatility.
The clip on the sheath is not well designed. It's a real scratcher.
People do look at me funny when I pull it out of my pocket.
GP640 is online now   Reply With Quote
Old 02-27-2011, 08:23 AM   #1645
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 9,883
Don't forget the old reliable, O-1 tool is also good for oil quench hardening.
When you go to harden, have a good magnet, you want to get the steel hot enough that the magnet will no longer stick, then you can quench.
I triple temper at 50 degrees lower each trip, and freeze the blade overnight between temperings.
"More than any time in history, mankind now faces a crossroads. One path leads to despair and utter hopelessness, the other to total extinction. Let us pray that we have the wisdom to choose correctly." Woody Allen
"*enhance* not enjoy, gramps mcbuzzkill" - Lemon G.
Manuel Garcia O'Kely is offline   Reply With Quote
Old 02-27-2011, 02:59 PM   #1646
TheOtherBart
Oddometer: 1,463
I've read a lot about cryogenic treatments, is an overnight stay in the family chill chest cold enough to make a difference? And when you say "a good magnet", what distinguishes a good one from a not-so-good one? Is my telescoping pick-up magnet good enough?
Old 02-27-2011, 05:49 PM   #1647
tslewisz
tslewisz's Avatar
Oddometer: 2,220
Cool. I have the Wilson version called the "Cop Tool". It's kinda handy.
tslewisz is online now   Reply With Quote
Old 02-27-2011, 05:53 PM   #1648
tslewisz
tslewisz's Avatar
Oddometer: 2,220
Originally Posted by Stromdog View Post
Beautiful work. The sheath looks very well done.
All things considered, the pricing on that machete is a bargain.
I'm putting one of those on my "must have" list. Thanks!
You're welcome. I have about 20 Bark Rivers. I'm confident you won't regret it.
Old 02-27-2011, 07:32 PM   #1649
bigsnowdog
Sylvan Dweller
bigsnowdog's Avatar
Oddometer: 15,519
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I don't disbelieve. How does this seemingly traditional and common looking knife come to be so rare?
2002 GS1150 ADV
Hepco Becker bags
Piaa 959 & 910
NRA life
"It's not true that I had nothing on. I had the radio on."
— Marilyn Monroe
bigsnowdog is offline   Reply With Quote
Old 02-27-2011, 07:53 PM   #1650
bigsnowdog
Sylvan Dweller
bigsnowdog's Avatar
Oddometer: 15,519
Originally Posted by CDS View Post
Well I made this one. My first knife actually. Every part and piece you see, except the screws.
Some more I made
My first and second Auto during construction. I sadly quit making after I finished these.
Very nice. Why did you stop?
2002 GS1150 ADV
Hepco Becker bags
Piaa 959 & 910
NRA life
— Marilyn Monroe
Thread Tools
Times are GMT -7.   It's 05:29 PM.
