Old 02-24-2012, 07:47 PM   #556
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,645
Question about the frame mods: is the change in rake of the steering neck always part of what they do? I know you're dealing with language barriers, but do you know if they build bikes where they don't change the angle there?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-24-2012, 09:24 PM   #557
igormortis
igormortis's Avatar
Oddometer: 1,402
I was never sure that they ever changed the rake angle... not by cutting and welding at least. I always thought it was just the relative angle that changed, due to suspension geometry changes.
Somebody please correct me if that’s wrong.
igormortis is offline   Reply With Quote
Old 02-25-2012, 06:19 AM   #558
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Yep, I think that's it. I think the rake rumor is just something that somebody said and it got repeated a bunch of times until it became "fact."
Here they are side by side. Stock and HPNed. The HPN is obviously raked out a bit more, but I can't tell if it's just the whole frame tilted back due to the longer front end or if the steering head itself has been modified.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 02-25-2012 at 07:31 AM
Old 03-03-2012, 09:14 AM   #559
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 253
Originally Posted by Airhead Wrangler View Post
...(able to cut away over half like this: http://hpn.de/pdf/hpn8.pdf Also, anybody want to tell me why this engine has one of the oil cooler lines attached to the LEFT side of the block?)
They changed the oil circulation massively anyway.
The difference between theory and practice practically is larger than the difference between theory and practice theoretically.
BMW Airhead -> www.zeebulon.de/bmw
BMW R1100GS -> www.zeebulon.de/R1100GS
XT 500 -> www.zeebulon.de/xt
Basic_Gerd is offline   Reply With Quote
Old 03-03-2012, 09:41 AM   #560
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 253
Originally Posted by scarygary View Post
thanks for the info.. good to know.
Cyclops offers a H4 version of the Trail Tech that I have been eyeballing..
Anybody has a side view of this headlamp housing? Any room for situating some cabling into it?
Old 03-03-2012, 12:39 PM   #561
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,393
AFAIK, I don't think so.
The Cyclops (in the beginning of its life at least) was a derivative of the Trailtech, with a 7" insert instead of the single filament 8" light.
Here's the link to the Trailtech site, which has some pictures of the back of the light. The halogen version doesn't appear to even have a headlight bucket. The HID one is form fitted to the reflector with no spare space.
I went with the Baja design light for that reason.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 03-04-2012, 10:42 AM   #562
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 253
Thanks a lot - i'll then go for the Baja for the exact same reason. If i'll go for this "Flak floodlight" direction at all...
Old 03-22-2012, 01:04 PM   #563
roadsacallin
'81 R80 G/S, '74 R90S
roadsacallin's Avatar
Oddometer: 156
I asked Claus Pepperl (the P of HPN) specifically if they altered the angle of the steering stem. He said they cut it off and reattach it at a .5 degree steeper angle.
roadsacallin is offline   Reply With Quote
Old 03-22-2012, 01:22 PM   #564
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,606
Well there you have it.
Old 03-22-2012, 03:27 PM   #565
igormortis
igormortis's Avatar
Oddometer: 1,402
How about that. I guess 0.5 of a degree is not something you’d notice by peeping at pix on the internet.
Old 03-22-2012, 04:23 PM   #566
cycleman2
Oddometer: 582
Looking at this picture the angle of the steering head is different between the two bike frames. I see that was confirmed.
2013 DL650 Adv
cycleman2 is online now   Reply With Quote
Old 03-22-2012, 04:35 PM   #567
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,645
Seems like a lot of work for a .5 degree. Any idea why they'd do that?
The reason why I'm asking is because a lot of us are looking at getting frame braces made and having them welded in locally. Of course, we won't be having steering angle changed. Any thoughts?
Old 03-22-2012, 04:42 PM   #568
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,606
I just don't see where they cut and rewelded in this photo. The welds attaching the plates on either side appear to be original MIG welds. The heat coloration at the top of the downtubes where they meet the steering head indicates to me that they may have loaded the frame in a jig and bent the steering head back and then heated these spots to relieve the elastic stresses and keep it permanently bent. Half a degree isn't much.
Old 03-22-2012, 04:56 PM   #569
igormortis
igormortis's Avatar
Oddometer: 1,402
Yeah AW, for me that particular picture has always been the strongest evidence that they don’t cut and re-weld. Who knows? Maybe it’s only for certain frames.
I guess HPN never discussed it with you?
Old 03-23-2012, 12:47 AM   #570
Phreaky Phil
Oddometer: 1,926
I always thought that they added an extra plate to those side plates, ie put another plate over or under the original and welded the edges together. It seems that the stresses on these plates is extension force. The forces on the steering stem is trying to tear the plates in half
Phreaky Phil is offline   Reply With Quote
Times are GMT -7.   It's 06:57 AM.
