02-25-2009, 03:27 PM
#61 |
i do have the copper ring thingy to adjust the bearings though... i think it only works for later GS... let me know wRanker :)
94 BMW R100GSPD 79 Suzuki GS750 black 4 in 2 81 Yamaha XT 540 |
02-25-2009, 04:33 PM
#62 | |
dont wish it, do it.
There a Michelin Sirac 120 x 18 rear and a 100 x 18 rear mounted on the front. Locky.
02-26-2009, 04:15 PM
#63 |
More tacos than you
Oddometer: 5,122
Bgood, you mentioned (I think in your thread) something about flipping your rear brake over. Can anyone tell me how exactly does one go about doing that on a G/S or ST? Is it as straight forward as just pulling the arm off and flipping it over?
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
02-26-2009, 04:26 PM
#64 | ||
airhead or nothing
Oddometer: 7,935
![]() Looking back, my bike was sure ugly when I got it!
"punkrocks what it's all about" - J. Strummer Quote:
02-26-2009, 04:57 PM
#65 | |
Dare to be Stupid
Oddometer: 3,799
Remove your rear wheel and look at your brake shoes from the left side of the bike. You'll see one half has an end in the middle and another has an end on the outside and both rest on the cam. With the lever on the bottom like normal, when you apply the brake the cam spins clockwise pushing the shoes into the drum. Notice that the cam isn't symmetrical--one part is flat, the part facing the shoes, the other part is rounded. When you flip the brake lever it will spin counterclockwise. Without modifying the cam the rounded parts would be touching the shoes and would slip--it wouldn't press the shoes into the drum. in other words:
1: modify the cam. Make the rounded sections look like mirror images of the flattened sections. The cam has 2 oil sealing o-rings on it. You'll need to drain the FD before pulling the cam. You may want to replace those o-rings while you're at it. Nathan said there's nothing at the hardware store to match them exactly(he's checked). You have to use the BMW part. 2: flip your shoes. They pivot on a pin up forward and are held in by an e-clip. pull the e-clip, remove the springs, flip the shoes and transfer the springs to the other side so that they'll be on the outside. I haven't flipped mine yet but Nathan told me how to do it and showed me one that he had already done it to. I pulled mine apart hoping to be lazy and get him to do the grinding for me but the shop was too busy. I've got the luxury of having a whole box of these cams in Nathan's attic 5 miles from my front door if I screw up, but it seems pretty straightforward. Normally I do any grinding with a dremel but the face of the cam needs to be really straight and the dremel isn't always the best at that. I'm going to use a file(I know, I hate not using power tools) or maybe a belt sander with some 40 grit. The Ziz wheel might not be a bad option either, the cam's only about an inch across. You're removing metal from it and it's obviously under stress, don't remove more than you have too. I don't need to tell you all this. From what you've done to your bike, it's obvious you can work with your hands. I've got 3 midterms next week, an aunt and a dad in surgery, gobs of statistics homework and another freakin' spanish essay. If you want to wait, as soon as I get through all that I'll go through the process and post up pics on my thread. I may not get around to it for a few weeks though. After all these tests I've got spring break and hopefully I'll be riding this thing every day instead of pulling it apart everyday. Good luck! edit: I guess I should put some kinda 'lawyerly stuff' here saying that 'grinding on your brakes and screwing up could cause them to fail and you to die, so don't sue me since you're warned. well, go ahead and sue! can't get blood from a stone.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind Proud SmugMug User Support ADV: Don't give those cheap bums your discount code bgoodsoil screwed with this post 02-26-2009 at 06:09 PM |
03-02-2009, 06:37 PM
#66 |
More tacos than you
Oddometer: 5,122
Finally. Xmas in March! My parts are here and I'm going to tear it all apart tomorrow night (and hopefully get it most of the way back together). Major mods are imminent. To use a Puttsism, I would consider myself "pissing my pants excited" right now.
03-02-2009, 06:42 PM
#67 |
Finding My Way..
Oddometer: 7,506
Airhead:
What is the shiny metal welded item in the middle of your pic? Is that a new exhaust or something? T. |
03-02-2009, 06:52 PM
#68 |
Dare to be Stupid
Oddometer: 3,799
is somebody getting twin discs!?
hate ta tell ya but fender braces are fashion accessories. They really don't do anything.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind Proud SmugMug User Support ADV: Don't give those cheap bums your discount code |
03-02-2009, 06:56 PM
#69 | |
G(/)S ... what else!
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net |
03-02-2009, 11:21 PM
#70 | ||
More tacos than you
Oddometer: 5,122
As for the fender brace, I'm hoping it'll do SOMETHING. This big ass acerbis fender (sail?) I put on has a tendency to dance a bit above 60mph. Nothing wild, but on straight boring sections I can definitely feel it in the bars and it's a little bit annoying. Luckily it's not constant, but instead requires a bit of sidewind. I'm hoping this thing will stiffen it up at least a little. Quote:
StephenB, thanks for the visual there. I haven't put eyes on my brake shoes in awhile and couldn't recall what that cam looked like from memory. That could be kind of tough to file that thing accurately enough to get even push on both sides of the brake lining. It also doesn't look possible to grind that cam in a way that would maintain the same amount of brake travel when rotating in the other direction without adding material to parts of it.
03-03-2009, 05:22 AM
#71 | |
03-12-2009, 03:36 PM
#72 |
More tacos than you
Oddometer: 5,122
Well, the front end is on, but waiting for a brake hose from galfer which should be here on monday. In the meantime I'd like to install a racetech cartridge emulator which just arrived from 'Soy Anarchisto' today. (Thanks man!)
Anyway, after reading both Anton's description and the one on gunsmoke, I'm questioning which route to pursue here. By installing it in the right leg you are adding more compression damping - adding it to the right leg where it didn't exist previously and leaving the stock compression damping in the left leg. This doesn't seem like it will reduce the harshness of fast bumps as the cartridge is meant to do as you're leaving your stock compression damping (the problem) alone and adding more compression damping to it (making it more harsh). It seems to me that the cartridge is designed to entirely replace the stock compression damping, so it would make the most sense to disable the stock compression damping in the left leg and install the racetech emulator in this leg to replace the stock compression damping entirely. Yet it seems that everyone who installs one of these installs it in the right leg. Anyone want to clear it up for me? As for the rest of the mods, they've gone pretty well. Just a little minor tweaking necessary. I'm hoping to have this sucker on the road next week. Yes, I know I owe some photos. They're coming sometime soon.
03-12-2009, 03:48 PM
#73 | |
Location: Berkshire, England. Just off the Beaten Track!
Oddometer: 2,575
03-12-2009, 04:06 PM
#74 | ||
airhead or nothing
Oddometer: 7,935
If your compression damping is too harsh with only one leg doing the damping work, it would seem that a change of oil and perhaps spring or spring pre-load is also necessary. In re-reading Scot's page it does seem like he is switching beteen right and left as to where the function really lies, and Anton is very clear about this...read his first and third paragraphs. All I can say is that the GV made a big difference in the front end of my old R100GS! Anton does not that you should remove the disc from the rebound valve to allow the compression damping in the right fork leg to work best...
03-12-2009, 04:27 PM
#75 |
Oddometer: 2,330
Which leg did you put your emulator in Solo?
WRT the fender brace--I am getting ready to put one on my GS as well. Seems to me that it should add some more support if I want to mount a fender bag on there for a spare tube, no? |
