Old 11-28-2009, 04:41 AM   #1501
HeadShrinker
Lost for a Reason
HeadShrinker's Avatar
Oddometer: 1,438
Originally Posted by dhillr
The ride west of Richmond fell apart. Mind if I ride with you guys today??
Great!
Whatcha gonna ride?
HeadShrinker screwed with this post 11-28-2009 at 05:10 AM
HeadShrinker is offline   Reply With Quote
Old 11-28-2009, 05:22 AM   #1502
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,411
Thanks, Brian, Dhillr and Mickey for the recommendations on a shop. I appreciate the help.
Pike Bishop is offline   Reply With Quote
Old 11-28-2009, 06:32 AM   #1503
UpST8
turnin gas to noise
UpST8's Avatar
Oddometer: 7,239
Tools
As we approach the colder time of year and folks start thinking of those long over due projects I think it is important to familiarize yourself with the tools and their true uses.....STOLEN FROM TEAM GHETTO Thread in Upstate
Tool Definitions
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, shit!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle ... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit usually smashing the thumb that is holding the object that you are trying to pound into whatever it is that you are working on effectively eliminating the need for manicure care on that thumbnail for weeks. See: Son of a bitch TOOL
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works
particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a bitch TOOL:
Any handy tool that you grab and throw across the garage while yelling, "Son of a bitch" at the top of your lungs. It is also, most often, the next tool that you will need.
WHERE AM I RIDING
cRAzY
UpST8 is offline   Reply With Quote
Old 11-28-2009, 09:38 AM   #1504
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,509
Anybody want a pair of 7/8 pro-taper bars for $25? They are $65 new.
They are the kx-hi bend and aluminum. Nice upgrade to a klr,dr,strom etc if the bend fits you. Short rise with not much sweep.
Probably not worth putting in FM and dealing with shipping but I don't need them laying around. After I raised and moved my seat back, I needed something taller.
108 tall w 56mm sweep.
B.E. Coyote is offline   Reply With Quote
Old 11-28-2009, 11:33 AM   #1505
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
Upst8..... I've used that son of a bitch tool once or twice, works every time
screamin injin is offline   Reply With Quote
Old 11-28-2009, 05:05 PM   #1506
dhillr
dhillr's Avatar
Oddometer: 1,605
Great riding today guys!! Can't wait to get out again!
-Dave
dhillr is offline   Reply With Quote
Old 11-28-2009, 05:22 PM   #1507
Tidewater KLR
High Speed Hiker
Tidewater KLR's Avatar
Oddometer: 763
I sent you a PM.
TWKLR
Tidewater KLR IBA#58468
2003 KLR650 "Fu Manchu"
2012 DL650 Adventure
"A motorcycle in the garage is safe, but that is not what it is made for"
Photo library at http://s9.photobucket.com/albums/a72/Tumbleweed7/
Tidewater KLR is offline   Reply With Quote
Old 11-28-2009, 05:28 PM   #1508
TheWorstKind
In the Wind
TheWorstKind's Avatar
Oddometer: 860
Brian,
if you still have the bars, I'll take 'em!
A fool shows his annoyance at once, but a prudent man overlooks an insult.
Give it more gas, if it doesn't solve the problem it will at least end the suspense.
TheWorstKind is offline   Reply With Quote
Old 11-28-2009, 05:31 PM   #1509
B.E. Coyote
(Super-Genius)
Oddometer: 5,509
Ethan has 1st dibs but if he doesn't want them they are all yours.
Old 11-28-2009, 05:41 PM   #1510
Tidewater KLR
High Speed Hiker
Oddometer: 763
Jim can have them if he wants, otherwise I'll take 'em. It's not a huge priority for me, but the price is right .
Ethan
Old 11-28-2009, 05:52 PM   #1511
B.E. Coyote
(Super-Genius)
Oddometer: 5,509
okay, Jim they are yours
shoot me a pm
Old 11-28-2009, 05:52 PM   #1512
TheWorstKind
In the Wind
Oddometer: 860
I did not see that Ethan had beat me to the punch, so Ethan, if you want them, go for it. I'll be happy to take 'em if you don't want them!
Old 11-28-2009, 06:23 PM   #1513
TheWorstKind
In the Wind
Oddometer: 860
Just got off the phone with Ethan, and being the genuine gentleman he is, he extended the courtesy of allowing me to claim the bars. Thanks Ethan!
Brian, you've got a pm....
Old 11-28-2009, 07:04 PM   #1514
HeadShrinker
Lost for a Reason
Oddometer: 1,438
Saturday
[IMG][/IMG]
With dhillr and Igofar...It was a nice ride today!
Old 11-28-2009, 07:45 PM   #1515
IgoFar
IgoFar's Avatar
Oddometer: 658
-Dave
Absolutely a great day. The roads were great, the dirt was fun, but the deer hunters were a little hairy. Had a ball. Gotta do it again.
IgoFar is offline   Reply With Quote
Times are GMT -7.   It's 07:21 PM.
