Thread Tools Rating: Thread Rating: 455 votes, 4.98 average. Display Modes
Old 04-01-2012, 12:44 PM   #2806
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,687
Originally Posted by Mambo Dave View Post
Too dangerous?
Surely the design can be made as stable as regular tails?
Stability is not an issue with proper design. The biggest issue is lack of elevator authority at low speed, as the elevator is out of the prop wash. Also the rudder needs to be stronger to support the elevator loads. It can also be scary to see the tail assembly flapping around during a spin, in a/c such as a Piper Tomahawk.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is online now   Reply With Quote
Old 04-01-2012, 12:48 PM   #2807
Keith
Slabbing it
Keith's Avatar
Oddometer: 906
Originally Posted by No False Enthusiasm View Post
I like it a lot, but never cared for T tails... Piper convinced me to avoid them.
NFE
You mean on the Tomahawk?
Random Crap
Keith is online now   Reply With Quote
Old 04-01-2012, 01:46 PM   #2808
chazbird
Oddometer: 3,553
Plenty of nice T-tail aircraft with excellent elevator authority; King Air 200/300/350, Boeing 727, DC-9, etc. The Arrow, Lance and Tomahawk, Seminoles with T-Tails maybe not so much. (The Beech Ducjess seemed to be fine with a T-tail though) Somewhere there's got be a video of the Tomahawk elevator flapping about in a full stall..I hear that's sobering to experience first hand. With the Arrow one could compensate for its so called limited authority. I noticed in cruise the t-tail Arrow was notably smoother than a standard Arrow, less prop wash, virtually none in fact, over the tail. T-tails also have a larger chance of tailplane stalling in icing conditions. (cruciforms seem to be the worst though) and then some T-tails have unrecoverable stall characteristics (BAC-111, B727) due to the wing blanking the tail during very high AOA.
chazbird is offline   Reply With Quote
Old 04-01-2012, 02:55 PM   #2809
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,687
Exactly right. The a/c listed that do have good elevator response are not usually flown in the slow flight regimes where the Pipers are, or called on to make short/soft field takeoffs where you need to lighten up the nose gear as early as you can. If the a/c is operated correctly within its normal limits, it really is no big deal, the pilot should be aware of the characteristics of anything he chooses to fly.
I don't need to see the video of the t-tail flapping, I saw it first hand on several occasions. Watch the tail on a DC9/B717 on landing sometime. They tail shake pretty good, too.
Old 04-01-2012, 04:34 PM   #2810
EvilGenius OP
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
I want one because they look great for an ultralight and go like stink.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 04-01-2012, 05:17 PM   #2811
PunkinHead
Moobless Adventurer
PunkinHead's Avatar
Oddometer: 5,917
I'm surprised something with wings that small can have such a low stall speed (49 MPH). Gotta love a 1.5 GPH fuel burn.
PunkinHead is offline   Reply With Quote
Old 04-01-2012, 05:35 PM   #2812
EvilGenius OP
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Originally Posted by RedRocker View Post
Be honest, you want everything.
I want everything that's worth wanting.
Old 04-01-2012, 07:35 PM   #2813
chazbird
Oddometer: 3,553
Of the larger T-tail aircraft I've experienced (DC-9, ATR42-72) they are similar to the T-tail Arrow in that when after rotation you lessen back-pressure to a certain extent (depending on stab trim, weight, etc.) The Arrow, however, had considerably less "feel" to it, you pulled a bit with not much feedback, unlike the larger aircraft where there was good aerodynamic feel. True, I've not engaged myself with soft or short field techniques with the larger planes. But rather than bash Piper exclusively, I've never flown the T tailed Cheyennes - maybe they are as nice feeling in elevator feel as a King Air T-tail. But if we must insist on Piper bashing have you ever seen what holds on a Seneca/Lance/Cherokee/Warrior/Archer/Arrow, etc. tail?
Old 04-01-2012, 08:50 PM   #2814
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,073
I've been a part of the "T-Tail Mafia" for years, but only because that is what Lockheed stuck on the back of the C-141 and C-5. Now it's on the C-17, so there must be some merit in it for big cargo pigs...
Here's a little fun fact: The horizontal stabilizer on the C-5 is 65 feet above the ground...that's six stories. But, it measures 68 feet from tip to tip. It's almost a friggin' aircraft in its own right. And I've actually transported a horizontal stabilizer from a -5 inside the aircraft. That was pretty neat.
"Would you care for some left-over bacon?"...said no man, ever.
When life gives you melons, you might be dyslexic.
Heyload is offline   Reply With Quote
Old 04-01-2012, 10:00 PM   #2815
chazbird
Oddometer: 3,553
How do you check for a de-iced tail on the C5? A one off bucket and boom? Helicopter?
Old 04-02-2012, 06:27 AM   #2816
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,073
They use a standard Air Force De-icing truck and spray it up there. If there is really a concern, there is an access ladder that you can get to pretty easily by going through the empennage area (about the size of a C-130 cargo compartment) that goes all the way up to the top of the tail inside the vertical stabilizer, and you can pop a hatch and take a look at the top of the tail. Definitely not a climb you want to make if your claustrophobic, though.
Old 04-02-2012, 09:28 AM   #2817
EvilGenius OP
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
From what I understand its a big for large transport aircraft that cruise at high altitudes. The low temp and pressure at altittude lowers the speed of sound and thus the transonic zone. None of them break the SoS, but in that zone if you're elevator is in line with the wings the buffeting air off the wings creates a sort of dead zone that the elevator sits in. Which results in buffeting of the empanage and/or loss of elevator control (like in the p38s). Putting it up high gives it clean air. As for the smaller low altitude aircraft, I assume the high tail is to keep it away from potential FOD being kicked up by the wheels or props on dirty runways.
Old 04-02-2012, 09:57 AM   #2818
Daniii
geezer
Daniii's Avatar
Oddometer: 23,959
The control surfaces on the C-123 were fabric. We lost an outboard hinge on the right elevator coming into Eglin from an overwater training mission in '75. Tower reported we had "something hanging off our aircraft". I jumped back (I was the Nav) and discovered the problem. I reported to the Pilot that we had more rudder and less elevator than when we took off. As we were doing touch and goes, we declared an emergency and did a hot landing. Turns out many aircraft in the fleet had a crack where our elevator pivot failed.
That was my last mission in the C-123. I decided to become the Group Intel officer, and gave up my flight status. I didn't want to find out where else there were cracks in an aircraft originally designed as a glider.
Originally Posted by unaweep View Post
Your average American is a moran.
Daniii is online now   Reply With Quote
Old 04-02-2012, 12:08 PM   #2819
No False Enthusiasm
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 4,455
I don't mean to be bashing Piper... have flown almost all of the PA-28 series from 140s to 235s, some old Comanches, and a vintage Tri-Pacer and a PA-12. Loved those...
The T-tails on the Tomahawk and the PA-32 just made me uncomfortable at high angles of attack. Never understood the advantage...
Piper returned to conventional tailed PA-32s and continued that configuration on the higher performance Malibu's and Meridians.
Guess I'm just a conventional kind of guy....
NFE
No False Enthusiasm is offline   Reply With Quote
Old 04-02-2012, 01:22 PM   #2820
Gernick
Gernick's Avatar
Oddometer: 3,693
Gernick is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:52 PM.
