Thread Tools Rating: Thread Rating: 543 votes, 4.98 average. Display Modes
Old 06-15-2012, 06:47 AM   #3121
Beamer Pilot
Obviously a major malf...
Beamer Pilot's Avatar
Oddometer: 189
Originally Posted by Hay Ewe View Post
an Otter with wood paneling - ours are all utility and work hard....
Twin Otter DHC-6 the most fun you can have with your Ray Bans on...
You've never been lost until you've been lost at Mach 2.
Beamer Pilot is offline   Reply With Quote
Old 06-15-2012, 06:49 AM   #3122
Beamer Pilot
Oddometer: 189
TWIN Otter the most fun you can habe with your Ray Bans on...
Old 06-15-2012, 08:05 AM   #3123
chazbird
Oddometer: 3,690
The MS 737 sim model sounds terribly mucked up. Idle thrust on a approach with a 737 don't work out. Are you flying on a ILS or with the VASI (visual angle slope indicator). Most of the reccomended appraches for this airplane are designed for these approach angles, roughly 3 degrees, + or minus a few percentages.
EPR = engine pressure ratio, inlet air versus thrust (main core - by-pass). Think of it as your throttle, via the thrust levers. For a desired approach speed setting this varies somewhat for landing weight and temperature/ air density.
The following will be very useful, although it is 2.7 MB and 320 pages. We may not hear from you for a long time though
http://www.737ng.co.uk/B737%20Classi...g%20Manual.pdf
chazbird is offline   Reply With Quote
Old 06-15-2012, 08:29 AM   #3124
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 5,726
Best jump plane ever.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Upper Italian Lakes report.
http://www.advrider.com/forums/showthread.php?t=160841
South Africa, Swaziland, Botswana ride report
http://www.advrider.com/forums/showthread.php?t=454490
Great CanAm Tour
http://www.advrider.com/forums/showthread.php?t=476605
slideways is offline   Reply With Quote
Old 06-15-2012, 09:01 AM   #3125
Flying-D
Just Passing Through
Flying-D's Avatar
Oddometer: 2,665
Indeed. My first assignment as an Air Force controller was at the Academy where they used a pair for their jump school as well as their demonstration team, The Wings of Blue. I even remember the call signs...Congo 64 and Congo 65. They flew multiple sorties almost daily and were rock-solid reliable aircraft, and I believe that they still fly them. I'll take a turbine single for my lottery airplane though. Lower operating cost and 1/2 the chance of engine failure.
It's really all just stuff...and in the end, none of it means shit.
Flying-D is offline   Reply With Quote
Old 06-15-2012, 09:06 AM   #3126
chazbird
Oddometer: 3,690
OK Twin Otter guru's...what are those vertical strakes on the horizontal stabilizer for? I've seen lots of Twin Otters but not seen that set-up.
Old 06-15-2012, 09:48 AM   #3127
XR650L_Dave
Oddometer: 3,741
They seem to be used whenever there's 'stuff' that's going to be hanging out in the airflow, like skies or floats, or in this case, the open door and maybe people hanging onto the gear.
Can't imagine skies or floats mucks up the airflow for the rudder, so it must have some lateral instability under some conditions.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 06-15-2012, 10:24 AM   #3128
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,437
Using the VASI.
The future is bright, fruitful, and positive.
Old 06-15-2012, 11:46 AM   #3129
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,838
Lots of float planes have extra vertical surfaces at the rear. Its supposed to help with yaw, directional control at slower speeds.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 06-15-2012, 11:49 AM   #3130
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,838
The Twin Otter is back in production by Viking Air in BC who bought the rights from Bombardier / DeHavilland. They also have the rights to the other DeHavilland designs so who knows, maybe they will start making new Beavers. They have a four year backlog for new Twin Otters already.
Rick, Chapleau, ON
Honda Trail CT90
Old 06-15-2012, 11:56 AM   #3131
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,382
Really?
Hmmm
Suddenly a C-27J or an Avanti seem like so much overkill.....
"Would you care for some left-over bacon?"...said no man, ever.
When life gives you melons, you might be dyslexic.
Heyload is online now   Reply With Quote
Old 06-15-2012, 11:59 AM   #3132
chazbird
Oddometer: 3,690
Seen the strakes on float Twin Otters (and float Caravans) but not on wheeled Otters or Caravans, and most jump planes don't seem to have them. I guess you don't have to take them off for wheel operation.
Old 06-15-2012, 12:00 PM   #3133
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 5,726
We used to pull this 20 way chunk off the side of a Twin Otter. 12 people outside the door and 8 inside. Lot of rear CG , drag on the left side of the plane and the weight of 21 skydivers exiting at once does not even phase the Otter.
Great CanAm Tour
Old 06-15-2012, 12:04 PM   #3134
chazbird
Oddometer: 3,690
Alright then, the possible "ultimate" single pilot lottery utility plane for ADV'ers could be the Shorts SD7 Skyvan......ugly as all get out, KLR ugly, but indeed very useful. Operate out of rough strips and roll your bike cargo in/out with the rear ramp. Big enough for sleeping and small shop in there too. The CASA 212 would work too, but its not single pilot. The twin Otter has no roll on/off ramp. I'd post a picture of the Skyvan (AKA Sky Pig) but I am so lame in posting pictures.
Old 06-15-2012, 12:13 PM   #3135
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 5,726
Here, I will help you out.
Great CanAm Tour
Thread Tools
Times are GMT -7.   It's 05:00 PM.
