Thread Tools Rating: Thread Rating: 551 votes, 4.98 average. Display Modes
Old 06-17-2012, 06:28 PM   #3181
koncha
Oddometer: 10,044
Originally Posted by Daniii View Post
I notice a lot of Shermans have extra steel plate armour welded to the side as in this example. I assume that was a weak point in the original design.
That piece covers the crew compartment. It was welded on as an in-field modification. The Germans realized that was a weak point and would aim for it. It was easily penetrable by the 5 cm Pak 38 and even the 3.7cm Pak that was largely obsolete by Normandy. The extra armor gave the crew a chance against the 3.7cm and the 5cm, when fired at an angle.
koncha is offline   Reply With Quote
Old 06-17-2012, 06:37 PM   #3182
Daniii
geezer
Daniii's Avatar
Oddometer: 24,429
Originally Posted by Klay View Post
They up-armored them, too. Looks like a lot of them had Cummins diesel engines, too.
http://en.wikipedia.org/wiki/Super_Sherman
Thanks for the link. ( I guess could have found it myself - but Summerinmain says I'm an idiot )
The use of an air cooled engine developing 400 -600 hp seemed like an impossibility to me (having owned a 36hp VW-split window van) but is seems they worked quite well. The old water cooled vs air cooled argument continues to this day (I have a water-cooled Harley ).
Diesel seems a better solution foe a battle tank than gasoline, for obvious reasons.
I still can't find a link for the square plate I see welded to a lot of Shermans.
Daniii is offline   Reply With Quote
Old 06-17-2012, 07:14 PM   #3183
No False Enthusiasm
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 4,694
The Sherman used an air cooled radial gasoline engine because they were available...
In theater, diesel was not as readily available as gasoline.
Diesel engine is preferable but even M-48s originally were gasoline powered. Later upgrades included the diesel and the 105mm main gun.
The first US main battle tank to use a diesel was the M60.
NFE
No False Enthusiasm is offline   Reply With Quote
Old 06-17-2012, 07:22 PM   #3184
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
The side plates covered sponson (sides over the tracks) ammo storage. The plates over the front were to obviously to protect the driver and hull gunner. All of them were kinda wishful thinking, more for morale purposes than practical. Any penetration to the front plate is likey to produce a mission kill, as the behind armor effects (shrapnel bouncing around inside) don't care where the initial penetration occurs.
JamesG is offline   Reply With Quote
Old 06-17-2012, 08:05 PM   #3185
EvilGenius OP
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Like others have mentioned, it was a field fix for weak points in the armor.
They just slapped thick plates on top ot the most vunerable areas and welded it a few dosen times.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 06-17-2012, 08:12 PM   #3186
EvilGenius OP
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Originally Posted by FPGT72 View Post
I never knew about that airshow....I am going to try to go this year....they have some very cool stuff.
The cavanaugh warbirds looks very intresting....wonder how much of the stuff they fly at that show....have you ever been?
We go every year, the last few they've done it twice a year. Also the last 4-5 I went to the admission was free.
It's usually a saturday and sunday affair with tons of stunt planes, old warbirds and fighter jets. About every other show has helicopter and a-10 demonstrations too.
Randy Ball and his Mig are always there.
Cavanaugh usually has one of their AT-6s, the Skyraider, the OV-1 and either/both the avenger and the wildcat there. They just fly a few circuits, nothing fancy, but nice to see them up there.
The Cavanaugh museum is always worth checking out on the 4th though. They usually have some cool veterans there, give rides in a beautiful old stearman, take the spitfire out for a spin and there's almost always some big WWII bomber stoppig by to give tours and rides.
Old 06-17-2012, 08:14 PM   #3187
No False Enthusiasm
a quiet adventurer
Oddometer: 4,694
The phenomenon is called "spalling"...
From Wiki: http://en.wikipedia.org/wiki/Spall
Antitank warfare
In anti-tank warfare, spalling through mechanical stress is an intended effect of high explosive squash head (HESH) anti-tank shells and many other munitions which may not be powerful enough to pierce the armor of a target. The relatively soft warhead, containing or made of plastic explosive, flattens against the armor plating on tanks and other armored fighting vehicles (AFVs) and explodes, creating a shock wave that travels through the armor as a compression wave and is reflected at the free surface as a tensile wave breaking (tensile stress/strain fracture) the metal on the inside. The resulting spall is dangerous to crew and equipment, and may result in a partial or complete disablement of a vehicle and/or its crew. Many AFVs are equipped with spall liners inside their armor for protection.
A kinetic energy penetrator, if it can defeat the armor, generally causes spalling within the target as well, which helps to destroy/disable the vehicle and/or its crew[1].
For additional protection against HEAT rounds, standoff protection (sandbags, etc) takes the hull outside the focal length of the shaped charge, reducing its effectiveness.
NFE
Old 06-17-2012, 09:55 PM   #3188
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,942
At Tillamook?
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 06-17-2012, 10:18 PM   #3189
koncha
Oddometer: 10,044
I should have been more clear.
The sponson ammo storage on the Sherman wasn't isolated from the crew compartment as it is in modern tanks. On the right side of the Sherman, there are two sponson ammo storage areas and each is roughly bisected by the front and rear edges of the turret race. The left side has only one sponson storage locker located at the front. The plates welded on the sides protected the crew from being killed by a sponson ammo detonation. Protecting the sponson ammo became critical because a discharge would enter the crew compartment instead of blowing out the side or top as in modern tanks.
Old 06-17-2012, 10:53 PM   #3190
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,476
Originally Posted by Bigger Al View Post
At Tillamook?
Yes.
The future is bright, fruitful, and positive.
Old 06-18-2012, 04:15 AM   #3191
FPGT72
Oddometer: 5,958
This is why the germans always aimed for the star on the side of the turret....thin armor and a good chance of a kaboom.
There is a reason the british called them tommy cookers....they are bad tanks.....and went with stalin's idea that quanity has a quality of its own....sherman fits that to a T.
I think we had an I love this tank thread once...but it died....perhaps with the World of Tanks thread doing so well it is time to bring it back to the top.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is offline   Reply With Quote
Old 06-18-2012, 04:33 AM   #3192
No False Enthusiasm
a quiet adventurer
Oddometer: 4,694
Also called "Zippos" after the popular cigarette lighter.
Both flamed easily...
NFE
Old 06-18-2012, 10:52 AM   #3193
mfp4073
mfp4073's Avatar
Oddometer: 2,425
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is online now   Reply With Quote
Old 06-18-2012, 10:55 AM   #3194
mfp4073
mfp4073's Avatar
Oddometer: 2,425
Old 06-18-2012, 11:02 AM   #3195
mfp4073
mfp4073's Avatar
Oddometer: 2,425
http://www.liveleak.com/view?i=27b_1339867680
cant seem to come up with how to post its embedded. But its 16 spitfires flying over in formation at a recent airshow.....thats 16 Merlins singing in chorus. Turn your sound up and enjoy.
Thread Tools
Times are GMT -7.   It's 10:59 PM.
