Thread Tools Rating: Thread Rating: 621 votes, 4.99 average. Display Modes
Old 11-09-2013, 12:56 AM   #5566
markk9
Oddometer: 187
Originally Posted by Klay View Post
What's the story behind that?
It happened during the original operation Desert Storm. My wingman and I were sent to track down and intermittent radar contact by the AWACS. AWACS suspected a helicopter was flying low and slow trying to avoid detection. While my wingman covered me high at around 10K feet, I went down low for a visual confirm and intercept if possible. While down low searching I saw a tower and went right, missing the tower, but clipped a support steel cable. The tower was not marked on any of the charts we had access to. Made for an exciting ride to the closest runway with enough length to make a landing. Flight back was uneventful. Landing was a bit hair raising, the left main gear would not come down, made a 2 wheel landing and kept the left wing up as long as I could, skidded about 300 yards to a stop, popped the canopy open, jumped and ran as fast as I could towards the crash crew.
markk9 is offline   Reply With Quote
Old 11-09-2013, 01:24 AM   #5567
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,758
Amazing! Good story. The left engine kept running? I imagine some debris went through it.
Old 11-09-2013, 02:01 AM   #5568
markk9
Oddometer: 187
The left engine was still turning and putting out power. Even after sliding in the sand and ingesting tons of sand, both engines were still running. I had to power them off before leaving the cockpit.
Old 11-09-2013, 12:35 PM   #5569
KHJPHOTO
Old Man and the Road
KHJPHOTO's Avatar
Oddometer: 650
The red baron
KHJPHOTO
BMWMOA
BMWRA
IBA #27356
BMW Mileage Award 300,000 and adding to it
www.khjphotography.com
KHJPHOTO is online now   Reply With Quote
Old 11-09-2013, 02:52 PM   #5570
No False Enthusiasm
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 4,884
Thought some might appreciate reading the obit of MG Fredrick (Boots) Blesse, one of the first jet aces:
http://apps.westpointaog.org/Memorials/Article/15183/
NFE
No False Enthusiasm is online now   Reply With Quote
Old 11-09-2013, 02:58 PM   #5571
scurfer
Oddometer: 91
This bird brought me back home.
Why were the tail markings removed?
edit, thought something smelled with your story.
http://www.sportbikes.net/forums/ope...it#post4639806
Markk9, you have the worse luck..
scurfer screwed with this post 11-09-2013 at 03:08 PM
scurfer is offline   Reply With Quote
Old 11-09-2013, 08:49 PM   #5572
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,951
Funny, some one else thought / thinks some thing is up.
I clicked on the link but it needs a log in.
Look, at the moment I got no reason to doubt your story, but that is a 'big aircraft' hanger e.g. 737 / 767 etc (above the doors there is another roller door for the fin)
That grey aircraft is the only aircraft in view, during the first Gulf War there were hundreds of aircraft in the gulf area. Surly there would be more aircraft in a hangar that size.
As well, for a time during HUGE amount of air operations during Gulf War 1, that floor is very clean.
If the Left Main Gear did not extend as stated in the write up, then the left wing would have dragged on the ground then I would expect to see damage to the wing leading edge and underside. Usually aircraft that have an asymmetric gear situation don't slide down the runway in s straight line, usually end up in the grass / dirt / gravel on the side.
those are just my observations, I wouldn't have said anything but some one else noticed something that wasn't right and so that made me ask question as well
Hay Ewe
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 11-09-2013, 09:01 PM   #5573
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,758
I also was thinking that it does look more like a taxiing accident than a wheel-up landing.
Old 11-10-2013, 01:35 AM   #5574
Megamoto
Yes, I do look like this.
Megamoto's Avatar
Oddometer: 3,036
What's written on the chock?
235 MTS???
Guerrilla Moto diplomacy.
Higher level simians as ambassadors of vroom to skewer ignorance and amalgamate ideas globally.
I'm so happy I could whistle through my willie. (Dan Walsh)
Unum bonum Centurio
Megamoto is offline   Reply With Quote
Old 11-10-2013, 10:55 AM   #5575
scurfer
Oddometer: 91
235 MTS???
It's the 325th USAF maintaince group at Tyndall airforce base in FL.
Old 11-10-2013, 12:13 PM   #5576
Audaciter
Audaciter's Avatar
Oddometer: 7,147
What's your link say?
I registered, but for some reason don't have access to that thread.
- Kris
Audaciter is offline   Reply With Quote
Old 11-10-2013, 12:40 PM   #5577
chazbird
Oddometer: 3,762
More Sherlocking, neither yay or nay.....
They have big hangars in Saudi.
If the 325th were there they probably brought their own chocks.
To work on the plane perhaps they extended and pinned the gear post semi-crash landing.
Hitting a guy wire with any airplane at just about any speed is akin to a wide open chain saw going through a stick of room temperature butter. Maybe here it snapped the wire. Maybe.
chazbird is offline   Reply With Quote
Old 11-10-2013, 12:40 PM   #5578
scurfer
Oddometer: 91
rkk9
World 500 GP Racer
The linke is from Sportbike.net and in the years I've then there a search shows Markk9 (retired Eagle driver Long Live the Eagle) has had many brushes with death including crazy LEO's in pickups to kamakazi bicyclists taking him down on top of the TWO F15's he lost in DS. I have to remember it is the internet.
Gameroom cash: $22539
Sportbike: 2011 Night Rod Special, 2009 Kawi Versys
I have had two close calls with the grim reaper. 1st, during desert storm, my aircraft got hit by a MANPAD while doing a close air support mission. 2nd, while working as LEO on a drug bust, I was stabbed with a knife with a 5" blade, 2 times in the left side of my abdomen and 1 once in the left chest. Being stabbed was a surreal experience, it really didn't hurt, left like I had the wind knocked out of me, then I passed out, came to a few hours later after surgery. I'm lucky to be alive.
2011 H-D Night Rod Special, 2009 Kaw Versys, 2008 Kaw KLR650 (sold)
Old 11-10-2013, 12:56 PM   #5579
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,436
It's their "Jo Momma" type section. After you register you have to wait until a mod opens your account, kinda like our JM and FM, before you can even see it. After you register you can see the other threads, but probably not post.
PineyMountainRacing is offline   Reply With Quote
Old 11-10-2013, 01:59 PM   #5580
ParrotheadJeff
Class A CDL
ParrotheadJeff's Avatar
Oddometer: 1,247
So, I didn't recall seeing this pic and I consider myself to be a bit of a military aviation fan. I did a bit of searching around and found what looks to be a decent source which listed aircraft lost and or damaged in the original Operation Desert storm.
http://www.dstorm.eu/pages/en/other/losses.html
Here are all the F-15s lost or damaged during that conflict that I could find:
30/09/90 F-15E 87-0203/SJ Pilot - Maj. Peter S. Hook - KIA
WSO - Cpt. James P. Poulet - KIA 335th TFS/4th TFW Aircrew was flying a single-ship training mission at maximum gross weight. Prior to deployment, the pilot had an exchange tour with an RAF unit in Scotland. Co-incidentally, the two units were now based together, which allowed the pilot to conduct an intercept with an RAF friend who was also flying on a training mission in the local area. The F-15E pilot had decided to “play” air-to-air against the RAF Jaguar, despite strict orders against making air intercepts. The Jaguar was flying at 100 feet above the ground and the F-15E at 10,000 to 15,000. The pilot attempted to perform a stern conversion with the Jaguar. The tail of the aircraft scrapped the ground three hundred feet before the final impact destroyed the aircraft and killed the aircrew
18/01/91 F-15E 88-1689/SJ Callsign "T-Bird 56"
Pilot - Maj. Thomas F. "Teek" Koritz - KIA
WSO - Maj. Donnie R. "Chief Dimpled Balls" Holland - KIA 335th TFS/4th TFW 16nm SW of Basra AAA
20/01/91 F-15E 88-1692/SJ Callsign "Corvette 03"
Pilot Col. David W. Eberly - POW
Navigator Maj. Thomas E. Griffith - POW 4th TFW Al Qiam SA-2 Story
22/01/91 F-15C 83-0026/FF 71st TFS/1st TFW "Home Station" sitting in the F-15 alert area when damaged by fragments from an intercepted Scud missile
13/02/91 F-15C 514, ex 80-0074 Callsign "Tiger 53"
Pilot - KIA 6th Sqn. RSAF 25m SE of Khamis Mushait crashed
The info provided with and about the pic doesn't seem to fit anything I can find. I'll go do a bit more research...
Learnin' to drive the Big Iron!
ParrotheadJeff is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:37 AM.
