Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 01-18-2009, 03:21 PM   #91
hilljak
Hayseed
hilljak's Avatar
Oddometer: 399
Shim size
slo,
the klr shim is 29mm.
hilljak is offline   Reply With Quote
Old 01-18-2009, 03:39 PM   #92
TooSlow4U
2 Wheel Wonder Rider
TooSlow4U's Avatar
Oddometer: 1,090
Originally Posted by hilljak
slo,
Okay, thanks. I'll take a look and see what I can dig up. In the past, I've tried to save all the shims and stash 'em away when scrapping out a cylinder head or motor. I scrapped out a couple CB900C heads last summer.I have a drawer full of big shims. I'll measure them up to make sure they're the 29's.
TooSlow4U is offline   Reply With Quote
Old 01-18-2009, 04:22 PM   #93
hilljak
Hayseed
hilljak's Avatar
Oddometer: 399
my own klrsday.
aint she purdy.... new clutch springs in, old ones still within spec after 24k.
plates luked like new, well almost
have ya ever put one of them little o-rings in the impeller bfor? if not, thar a mutha.
this next pic is what i did most of taday. gettin that shit off the cover was a bitch!!!! dunno what them japs put on the gaskets, buttfuk it sure was hard to get off.... almost 4 ours.
as fer as klrsday, mes dont care whar its at, maybes tpar or O....PAUL.....O...gots the heat and heat is ur friend. at my place, alls i have is sally mander, yah shes hot, but she sure makes ya stink when ya get close ta her.
we need ta get a list of what peeps are wantin ta do ta thar bikes so we have an idea of what ta bring or need.... and enuf time ta do it all.
beer, food and more beer is all i can think of rite now...
ur friend
Old 01-18-2009, 04:38 PM   #94
TooSlow4U
TooSlow4U's Avatar
Oddometer: 1,090
...this next pic is what i did most of taday. gettin that shit off the cover was a bitch!!!! dunno what them japs put on the gaskets, buttfuk it sure was hard to get off.... almost 4 ours.
Ya, those can be a bear sometimes. Been there, done that. Makes ya really appreciate a razor blade and a small right angle die grinder with a 2" red scotch-lok cookie disc for gettin' that nasty gasket off. Takes about 5 minutes that way.
Old 01-18-2009, 06:53 PM   #95
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,596
well, i did get off my ass and do the valve check...and adjust today.
turns out, 3 out of 4 were out of spec. both intakes were @ .002... spec for intake is .004-.008
one exh was @ .004 and the other @.005...spec for exh is .005-.010..
so, i knew i was in for a tear down, got everything apart and shims removed and while looking for my digital micrometer.....found these.
forgot all about these, several shims for old kz 900/1000 engines, guess what, they are same size.
my dog on me again, i know what she is saying here... bout time u got your human ass off that couch and got on these valves, they were TIGHT!!
got valve cover off, along with cam caps...i chose not to remove cams, or timing chain, looked to me like i could get shims out without having to retime engine.
once u get buckets spun around where gap is facing towards you, pry shim off bucket with small screwdriver...and snatch it out with tweezers...or magnet.
u can see gap here..
got hold of shim here..
got em all changed, and all are on loose side, with 2 on very loose side, one actually out of spec @.0115 (exh should be no more than .010)...but was as close as i could get...and figured as valve seats wear...clearance will tighten up and it should come in...i hope.
got er all back together, and she fired right up... .
she is clattering a bit, but i think it is better than being to tight, and am hoping it gets quieter as seats wear.
so, i got some spare shims if you guys need em at the tech day.
tpar1220 is offline   Reply With Quote
Old 01-18-2009, 07:06 PM   #96
Backmarker
Backmarker's Avatar
Oddometer: 1,267
A noisy valve is a happy valve. Good looking dog, smart too!
(Books are for slow learners!) 2011 te-630, 2006 1200 gs adv. (The best color), 2013 KTM 690 Duke , 1984 R80 rt (airhead like its owner!)
Backmarker is offline   Reply With Quote
Old 01-19-2009, 04:34 AM   #97
Eugene
Oddometer: 1,138
Nice write up Tpar.
I've got it easy with the DR. The valve adjustment is a screw/locknut ordeal.
I may end up having something to work on if I pick up another bike before the tech day. I'll have to wait and see. I could always change the brake fluid and fork oil in the DR, which I do every year, if I want something to do.
When were you guys thinking about doing this?
Eugene is offline   Reply With Quote
Old 01-19-2009, 04:46 AM   #98
KneeKicker
KneeKicker's Avatar
Oddometer: 2,630
Originally Posted by Eugene
Nice write up Tpar.
I'd like to see something in the next couple weeks or so just to get everyones ride ready for spring.
My only dilema is deciding what bike needs work more
The DRZ won't even start(not sure what the heck is going on there yet)
And the KLR needs a new fork seal (I'll do both though) probably should check valves and I think there is a way to check the "Doo" I don't know much about the KLR yet.
The question is where are we doing this. A heated garage would be nice.
everything looks cool on motorcycle
"I got so drunk last night I woke this morning and someone had shit my pants" Ron White
KneeKicker is offline   Reply With Quote
Old 01-19-2009, 05:19 AM   #99
Eugene
Oddometer: 1,138
Do you think it's because of the cold? Are the valves within spec?
Old 01-19-2009, 06:31 AM   #100
Backmarker
Backmarker's Avatar
Oddometer: 1,267
I'll offer up my shop. 40x200. Heat,restroom,hot&cold water,fridge (byob),auto lift,m/c lift,m/c tools, tire changing tools, air, complete set of auto/m/c tools,oil change holding tank,internet acc.,etc..sorry the eng. dyno is sold Pretty much just need bike spec. shims etc..
Old 01-19-2009, 07:22 AM   #101
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,596
this weekend is no good for me, my mom is having a mastectomy wed. i told her i would spend weekend with her at her place @ ft. ritner.
any weekend after that, i should be good.
my doo is done, swingarm greased, valves done...wheel bearings still feel good. i could upgrade suspension, but i am in no hurry for that yet.
guess i will just show up to point fingers and laugh at everyone. but i can bring extra shims, micrometer and whatnot.
paul, if we have it at your place, you may want to park that sweet 57chevy outside...don't want some bonehead to drop their bike against it.
i will not park my bike anywhere close to it....i promise.
Old 01-19-2009, 07:47 AM   #102
gtackett
gtackett's Avatar
Oddometer: 703
Pics?
Platterdr, any pics. of the KLR?
Did you sell the XRL?
2006 KLX250
1985 CB700SC
1990 KX250
gtackett is offline   Reply With Quote
Old 01-19-2009, 07:47 AM   #103
Glockowner
Glockowner's Avatar
Oddometer: 322
I am ordering my Doo supplies from EagleMike today, so I am guessing they might not make it by this weekend either.
The next weekend is the super bowl, so that is out.
Feburary 8th, is the pro-bowl, but that I can miss. Seems far enough ahead so that if anyone needs to order anything it should be here by then.
Where are you located Backmarker?
Glockowner is offline   Reply With Quote
Old 01-19-2009, 08:10 AM   #104
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,596
forgot about this.. my new rear tire for tw. duro power grip 26x8x14 atv tire!
maybe i will haul tw there and swap tires, then afterward...paul can lead us around the trails outside of bedford.
big fun indeed!!
Old 01-19-2009, 08:13 AM   #105
Glockowner
Glockowner's Avatar
Oddometer: 322
big fun indeed!!
You makin the TW into a mud bogger?
I bet you wont have trouble getting the rear end to hook up.
Times are GMT -7.   It's 03:27 AM.
